Yoshi900's avatar
Yoshi900
Readynas not using full capacity
Hi,
It seems like my readynas 314 will not expand to the new size.
I started with 6tb - 2tb - 6tb - 2tb which gave me ~9tb of space
Then I wanted to upgrade the 2tb disks to 4tb disks. I did this one at a time
6tb - 4tb - 6tb - 2tb which gave me ~10.9tb
I then did the last 2tb so now I have
6tb - 4tb - 6tb - 4tb however I still only have ~10.9tb
I have rebooted a couple of times and I have also reseated / resynced the last added drive already but that didn't expand the raid.
I am running x-raid.
Please help.
I don't know if turning off x-raid and turning it back on again will help here.
I have also reynced the 6tb too.
Running lastest firmware too
  • StephenB's avatar
    You can't do that with XRAID.  When you replace a disk, it either needs
    • to match the size of one that's already in the array
    • to be larger than the biggest disk in the array.
    So you could have upgraded them to 6 TB or something larger.  FWIW, upgrading one of the 2 TB drives to 6 TB would have given you the same space as what you attempted, and would have been a bit cheaper.
    What you'll need to do is save all the data on the NAS to a backup, then do a factory default with all the new disks in place.  That will give you a 14 TB (12.7 TiB)  volume. After that you'll need to recreate your shares, etc and restore the files from the backup.
    Or see if you can exchange the disks for 6 TB models.
    • Yoshi900's avatar
      Yoshi900
      So I already have the 6tb and the 4tb in the nas, it never did an increase to 12.7tb.. it is currently at 10.2tb
      From what I have read it looks like I have to do a factory reset to get the extra storage which is pretty annoying.
      • StephenB's avatar
        What is a bit puzzling here is why you saw any increase in space when you upgraded the first 2 TB drive.  You shouldn't have, unless you previously had 4 TB drives in the array.
        Can you download the log zip file and post mdstat.log?  Cut and paste it in a reply (the </> tool in the toolbar is handy for this).
  • Ok looks like I didn't know about this limitation.
    I have taken out a 6tb drive and used a couple of other drives I had lying around (old 2tb drives) to backup all the data.
    I will then do a factory reset and then copy everything back.
    I need to do this sooner rather than later as I will have too much data to do the backup.
    Personalities : [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
    md124 : active raid1 sda5[0] sdd5[2]
          1953371840 blocks super 1.2 [2/2] [UU]
    md125 : active raid5 sdb4[6] sda4[7] sdd4[5] sdc4[4]
          2929868352 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
    md126 : active raid5 sda3[4] sdd3[6] sdc3[5] sdb3[7]
          2915732352 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
    md127 : active raid1 sdb5[0] sdc5[1]
          3906876864 blocks super 1.2 [2/2] [UU]
    md1 : active raid10 sda2[0] sdd2[3] sdc2[2] sdb2[1]
          1044480 blocks super 1.2 512K chunks 2 near-copies [4/4] [UUUU]
    md0 : active raid1 sda1[4] sdd1[6] sdc1[5] sdb1[7]
          4190208 blocks super 1.2 [4/4] [UUUU]
    unused devices: <none>
    /dev/md/0:
               Version : 1.2
         Creation Time : Tue Sep 16 06:37:21 2014
            Raid Level : raid1
            Array Size : 4190208 (4.00 GiB 4.29 GB)
         Used Dev Size : 4190208 (4.00 GiB 4.29 GB)
          Raid Devices : 4
         Total Devices : 4
           Persistence : Superblock is persistent
           Update Time : Tue May  5 14:02:21 2020
                 State : clean
        Active Devices : 4
       Working Devices : 4
        Failed Devices : 0
         Spare Devices : 0
    Consistency Policy : unknown
                  Name : 7c6ee9a2:0  (local to host 7c6ee9a2)
                  UUID : ea4dc9bb:b9641fec:7678b6d9:3510a15e
                Events : 4993
        Number   Major   Minor   RaidDevice State
           4       8        1        0      active sync   /dev/sda1
           7       8       17        1      active sync   /dev/sdb1
           5       8       33        2      active sync   /dev/sdc1
           6       8       49        3      active sync   /dev/sdd1
    /dev/md/1:
               Version : 1.2
         Creation Time : Mon May  4 20:23:18 2020
            Raid Level : raid10
            Array Size : 1044480 (1020.00 MiB 1069.55 MB)
         Used Dev Size : 522240 (510.00 MiB 534.77 MB)
          Raid Devices : 4
         Total Devices : 4
           Update Time : Tue May  5 03:30:36 2020
                 State : clean
        Active Devices : 4
       Working Devices : 4
        Failed Devices : 0
         Spare Devices : 0
                Layout : near=2
            Chunk Size : 512K
                  Name : 7c6ee9a2:1  (local to host 7c6ee9a2)
                  UUID : 828b88db:80c85fc5:2148475e:2be97175
                Events : 19
           0       8        2        0      active sync set-A   /dev/sda2
           1       8       18        1      active sync set-B   /dev/sdb2
           2       8       34        2      active sync set-A   /dev/sdc2
           3       8       50        3      active sync set-B   /dev/sdd2
    /dev/md/data-0:
               Version : 1.2
            Raid Level : raid5
            Array Size : 2915732352 (2780.66 GiB 2985.71 GB)
         Used Dev Size : 971910784 (926.89 GiB 995.24 GB)
          Raid Devices : 4
         Total Devices : 4
           Update Time : Tue May  5 13:56:12 2020
                 State : clean
        Active Devices : 4
       Working Devices : 4
        Failed Devices : 0
         Spare Devices : 0
                Layout : left-symmetric
            Chunk Size : 64K
                  Name : 7c6ee9a2:data-0  (local to host 7c6ee9a2)
                  UUID : c986ca70:d8d44a62:afac6818:4191584b
                Events : 22588
           4       8        3        0      active sync   /dev/sda3
           7       8       19        1      active sync   /dev/sdb3
           5       8       35        2      active sync   /dev/sdc3
           6       8       51        3      active sync   /dev/sdd3
    /dev/md/data-1:
               Version : 1.2
         Creation Time : Tue Sep 16 16:50:37 2014
            Raid Level : raid5
            Array Size : 2929868352 (2794.14 GiB 3000.19 GB)
         Used Dev Size : 976622784 (931.38 GiB 1000.06 GB)
          Raid Devices : 4
         Total Devices : 4
                 State : clean
        Active Devices : 4
       Working Devices : 4
        Failed Devices : 0
         Spare Devices : 0
            Chunk Size : 64K
                  Name : 7c6ee9a2:data-1  (local to host 7c6ee9a2)
                  UUID : 0b86abbf:17ce2701:6a9dacf8:4258271e
                Events : 21681
           6       8       20        0      active sync   /dev/sdb4
           4       8       36        1      active sync   /dev/sdc4
           5       8       52        2      active sync   /dev/sdd4
           7       8        4        3      active sync   /dev/sda4
    /dev/md/data-2:
               Version : 1.2
         Creation Time : Tue Nov  7 05:15:19 2017
            Raid Level : raid1
            Array Size : 3906876864 (3725.89 GiB 4000.64 GB)
         Used Dev Size : 3906876864 (3725.89 GiB 4000.64 GB)
          Raid Devices : 2
         Total Devices : 2
                 State : clean
        Active Devices : 2
       Working Devices : 2
        Failed Devices : 0
         Spare Devices : 0
                  Name : 7c6ee9a2:data-2  (local to host 7c6ee9a2)
                  UUID : 6b4b7a26:ecf55b8b:602146d5:15b86742
                Events : 948
           0       8       21        0      active sync   /dev/sdb5
           1       8       37        1      active sync   /dev/sdc5
    /dev/md/data-3:
               Version : 1.2
         Creation Time : Fri Jan 10 04:50:20 2020
            Raid Level : raid1
            Array Size : 1953371840 (1862.88 GiB 2000.25 GB)
         Used Dev Size : 1953371840 (1862.88 GiB 2000.25 GB)
          Raid Devices : 2
         Total Devices : 2
                 State : clean
        Active Devices : 2
       Working Devices : 2
        Failed Devices : 0
         Spare Devices : 0
                  Name : 7c6ee9a2:data-3  (local to host 7c6ee9a2)
                  UUID : 5dec4438:e75b6dae:40c357e0:ec4754d2
                Events : 738
           0       8        5        0      active sync   /dev/sda5
           2       8       53        1      active sync   /dev/sdd5
    here is the log from the rn-expand
    -- Reboot --
    May 05 11:52:04 GNAS rn-expand[3516]: Trying auto-expand (in-place)
    May 05 11:52:04 GNAS rn-expand[3516]: Considering inplace auto-expansion for data
    May 05 11:52:04 GNAS rn-expand[3516]: Checking if RAID disk sda is expandable...
    May 05 11:52:04 GNAS rn-expand[3516]: Checking if RAID disk sdb is expandable...
    May 05 11:52:04 GNAS rn-expand[3516]: Trying auto-extend (grow onto additional disks)
    May 05 11:52:04 GNAS rn-expand[3516]: auto_extend: Checking disk sda...
    May 05 11:52:04 GNAS rn-expand[3516]: auto_extend: Checking disk sdb...
    May 05 11:52:04 GNAS rn-expand[3516]: auto_extend: Checking disk sdc...
    May 05 11:52:04 GNAS rn-expand[3516]: auto_extend: Checking disk sdd...
    May 05 11:52:04 GNAS rn-expand[3516]: Trying xraid-expand (tiered expansion)
    May 05 11:52:04 GNAS rn-expand[3516]: Considering X-RAID auto-expansion for data
    May 05 11:52:04 GNAS rn-expand[3516]: Checking if RAID disk sdc is expandable...
    May 05 11:52:04 GNAS rn-expand[3516]: Checking if RAID disk sdd is expandable...
    May 05 11:52:04 GNAS rn-expand[3516]: No enough disks for data-0 to expand [need 2, have 0]
    May 05 11:52:04 GNAS rn-expand[3516]: No enough disks for data-1 to expand [need 2, have 0]
    May 05 11:52:04 GNAS rn-expand[3516]: No enough disks for data-3 to expand [need 2, have 0]
    May 05 11:52:04 GNAS rn-expand[3516]: No enough disks for data-2 to expand [need 2, have 0]
    May 05 11:52:04 GNAS rn-expand[3516]: 0 disks expandable in data
    Even though I am doing the work around (factory reset) there might be something in the logs that someone else can try if they are having the same issue.
    • StephenB's avatar
      It did something I've never seen before:
      /dev/md/data-0:
      Raid Level : raid5
      /dev/md/data-1: Creation Time : Tue Sep 16 16:50:37 2014 Raid Level : raid5 Used Dev Size : 976622784 (931.38 GiB 1000.06 GB)
      /dev/md/data-2: Creation Time : Tue Nov 7 05:15:19 2017 Raid Level : raid1 Used Dev Size : 3906876864 (3725.89 GiB 4000.64 GB) 0 8 21 0 active sync /dev/sdb5 1 8 37 1 active sync /dev/sdc5 /dev/md/data-3: Creation Time : Fri Jan 10 04:50:20 2020
      Raid Level : raid1
       Used Dev Size : 1953371840 (1862.88 GiB 2000.25 GB) 0 8 5 0 active sync /dev/sda5 2 8 53 1 active sync /dev/sdd5
      Normally XRAID just won't expand when you add an intermediate size disk.  But in your case, it apparently did create a jbod RAID group using the first 2 TB of the 4 TB drive, and then converted that to RAID-1 when you installed the second 4 TB drive.  That explains the expansion you saw on the first upgrade, and also why the size didn't follow the normal capacity rule.
      This apparently happened some months ago, so the info in rn_expand.log isn't relevant.
      A factory reset is the best way to get the full volume space.  You'll end up with two RAID groups - 2x4TB RAID-5 + 2x2TB RAID-1.
      • Sandshark's avatar
        Sandshark
        Sensei
        OK, so that final configuration is what I said was actually possible, but not implemented in XRAID. So, maybe Netgear has added some logic in a recent OS update to implement it.  But using the extra 2TB of the first 4TB as JBOD was a really bad thing if you were assuming you had RAID redundancy, since that 2TB did not have redundancy until you added the second 4TB.  At this point, it is anyone's guess what the next step would be if you were to further expand.  Unless you need the additional space right away, you can hold off on the factory default.  But I recommend that you figure out a good time to do it down the road, both to gain the full capacity and to align the volume with a more typical configuration.
ProSupport for Business
