kevinfff
Feb 19, 2016Tutor
Rysnc or backup to second NAS loses permissions / ACLs
Has anyone noticed that backups from one ReadyNAS to another (both members of Active Directory) screw up the permissions?
We have a production unit RN3220 which hosts our main file sharing system and users' "my documents" folders. Previously these shares were backed up weekly to a USB attached disk, and daily snapshots were made however, following a scare following the firmware upgrade to 6.4.0, we invested in a second ReadyNAS unit (4220S) and I created rsync jobs to copy the files and folders in each of the shares, having first created the same shares with the same permissions on the new NAS.
After another f/w scare (the upgrade to 6.4.2 worked fine on the test systems, but "hung" the production unit) I intended o allow users access to the new NAS unit, as the shares and filepaths would be the same, except for the server name and IP address, however when I checked I saw that the file permissions were screwed - new permissions had been granted and some existing permissions dropped. Netgear have confirmed this is a known issue. I have TBs of files - to fix the ACLs would take hours - even with the editor.
If anyone has a solution for this please advise!
1 Reply
- siignaNETGEAR Employee Retired
ReadyNAS maps Windows SIDs to local UID/GIDs (winbind with a local idmap table). Unfortunately this means that across different ReadyNAS you will have different SID->U/GID mappings, leading to permissions issues.
For more information see: https://www.samba.org/samba/docs/man/Samba-HOWTO-Collection/idmapper.html (Winbind/NSS with the default local IDMAP table)
Exporting the mapping from your source to your destination should resolve the permission issue. You'll need to do it from SSH, an option to do this in the UI is in the works (but hasn't made release yet):
http://ram.kossboss.com/exporting-importing-user-id-maps-samba/
If you have any new users login to the source NAS after the export/import you'll need to do it again to update the destination NAS with the new mapping.
