× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Settings DNS server adds a static route
e__e
Using ReadyNas 6.2.4 (latest as of today)
We have the ReadyNas box on a LAN
- RN = 10.1.1.10/24
- router = 10.1.1.1
We access from time to time, settings etc... the box from a VPN:
- VPN server = 10.1.1.2
- TUN network = 10.0.100.0/24
- TUN host (other end) = 10.0.100.100 (and also DNS server at times)
In order for the RN to "see" the TUN on VPN server, we add a static route via the RN interface Network/Routes to ensure routing from RN to VPN for the TUN network works
- 10.0.100.0/24 => via VPN server (10.1.1.2)
Then remotely, from the other end of the VPN, we can see the RN successfully, and reversely the RN see the other end of the VPN.
Great!
However to perform some tests and other configurations, we had to set a DNS server on the TUN host (the other end), 10.0.100.100, and then set that DNS server on the RN:
- in Network/Links/eth0 (only one interface), DNS
But for some mysterious reasons, the RN added automatically a static route to 10.0.100.100 via 10.1.1.1 (the LAN router!), being more specific, made the RN try to reach the TUN host via the LAN router (10.1.1.1) instead of via the VPN server (10.1.1.2) as it did before, and the LAN router doesn't know (and must not know) the VPN network (10.0.100.0/24).
Before adding the DNS server, the RN routing table showed
Destination   Gateway   Genmask         Flags Metric Ref Use Iface
0.0.0.0 10.1.1.1 0.0.0.0 UG 0 0 0 eth0
10.0.100.0 10.1.1.2 255.255.255.0 UG 0 0 0 eth0
10.1.1.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
and after
10.0.100.100 10.1.1.1 255.255.255.255 UGH 0 0 0 eth0
Bug or feature?
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 2392 views
  • 0 kudos
  • 1 in conversation
Announcements
