- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Share folders are not visible in the web interface ReadyNAS 316 Firmware: 6.10.3
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello dear community,
I have a problem that a folder can only be accessed through Windows Explorer
\\ x.x.x.x \ "Share name" \ can be seen, but not via the web interface!
Does anyone have any idea? 🙂
Plex Media became active, but it was also edited for a while, and the folders were under,
Now I don't see any folders and snapshots are gone too.
Disk space has not been decided, luckily the data is still there.
Firmware: 6.10.3
6x 3 TB all on green.
Thanks in advance.
greeting
Sergei
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Share folders are not visible in the web interface ReadyNAS 316 Firmware: 6.10.3
Is it possible that this is a private home folder, and not a public share?
If it was in the share list before, then is is a public share.
If the name matches a NAS user account name (including admin), then it is a private home folder.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your answer, my problem is that I have deliberately not made any changes to the system and shares.
I am logged in as an admin and have full access rights.
Only the folders are no longer visible. See the screenshot
- Mark as New
- Bookmark
- Subscribe
- Permalink
It would be wise to make a backup.
After that, you could try running the script here: https://gitlab.codycook.us/readynas-scripts/share_lun_ui_fix.sh
That will require you to enable ssh access on the NAS. Log in as root using the NAS admin password.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you very much,worked great!!!
= [Task] Discovering volumes
== [Info] 1 volume(s) found.
==== [Task] Backing up existing Snapper configs
===== [Info] Success at backing up snapper configs
===== [Task] Removing Snapper Configs
== [Task] Investigating volume /data...
=== [Info] Number of items found : 5
=== [Info] Items found: Bilder Dokumente Franken-Solution Musik Videos
=== [Task] Reviewing Bilder
=== [Info] Found share at /data/Bilder
=== [Task] Recreating share configs.
==== [Info] Done with Share /data/Bilder.
=== [Task] Reviewing Dokumente
=== [Info] Found share at /data/Dokumente
==== [Info] Done with Share /data/Dokumente.
=== [Task] Reviewing Franken-Solution
=== [Info] Found share at /data/Franken-Solution
==== [Info] Done with Share /data/Franken-Solution.
=== [Task] Reviewing Musik
=== [Info] Found share at /data/Musik
==== [Info] Done with Share /data/Musik.
=== [Task] Reviewing Videos
=== [Info] Found share at /data/Videos
==== [Info] Done with Share /data/Videos.
- Mark as New
- Bookmark
- Subscribe
- Permalink
