- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Some Folders Not Available in Finder
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am actually using RN526X (it's not in the Model List above). runing 6.6.0 .
I am copying some data onto the server from an external HDD attached to mny Mac. For certain folders that I copy over, the folder is grayed out after the copy and if I click on it, The Finder only shows the folder and not the contents in it. (Se the ordination folder in the screen shot below.
It I sign into the server through the Admin page I can see the contents in the folder and if I go to the folder using the ReadyCloud app on my iPhone, the folder is there and I can see the contents.
I have has this happen on several different shares and can't find a reason for it. I have tried to delete the original folder and copy oit again but get the same results.
Any help would be appreciated.
David
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello dschwartzer,
So, I had to take a look again at the screenshot you sent, xxxx.xxxxxx@gmail.com is a ReadyCloud user I think and that has home share where Pictures folder is and Ordination subfolder is inside Photos. Have you checked if you will get the same results when you move the Ordination folder to the same directory level of Pictures?
There is no really setting on the NAS admin page for subfolder of home shares so it is something that you might need to check in the security and permission settings of the subfolder, I don't know how it is done on Mac, honestly. I hope someone would chime in to share.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Some Folders Not Available in Finder
Hello dschwartzer,
Do you see these contents too when you access it through SMB on a Windows machine? What I am thinking is that maybe these files are not recognizable by Mac.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dear JennaC:
Thanks for your response.
Unfortunately, I do not have access to a Windows machine so I can't verify. That said, the files in this folder are all plain jpeg files. The HDD they are currently on sees then without issue and they were previously stored on a Drobo DAS and I could see the folder and its contents without issue. The same is true for the other folders that this happendd to. I have ben able to see the contents from any other drive and most files were either generic formats (i.e. mp4) or Apple specific files like .dmg.
David
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello dschwartzer,
Can you check if you will be able to get to these files through ReadyCloud app installed to your Mac?
- Mark as New
- Bookmark
- Subscribe
- Permalink
JennaC:
Using the ReadyCloud app on my Mac, I am still not able to access the files in that folder. The folder is grayed out just like in Finder.
Using ReadyCloud in the browser and/or using the readyCloud app on my iPhone, I am able to access the folder. Also, when looking at the Share in the Admin UI I am able to get to the files also.
Let me know if you need anything else.
David
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello dschwartzer,
Do you have other Mac machines that you can try to check if you get the same results? How about turning on AFP on the share where these are then access the share via AFP on the finder?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you still see this problem on ReadyNAS OS 6.6.1 ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have not been able to update my ReadyNAS. The system keeps saying my system is up to date and no updates are available so I am still at 6.6.0.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello dschwartzer,
How about manual update instead?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I looked for that but couldn't find the firmware file to install. Do you have a link?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Dear JennaC:
After another look I found the 6.6.1 firmware file and did update the RN526X. Same condition. The folder is grayed out and I cannot access the contents.
David
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello dschwartzer,
Have you tried copying at least 2-3 files from this folder to another share that has no problem via admin page then try to access that share through finder?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The folder at issue called Ordination contains one photo and two sub-folders. The sub-folders contain all of the photos.
I copied the entire Irdination folder from the Home > Photos share to the main Photos share.
In the Home > Photos share, the Ordination folder is still frayed out in the Finder by in the main Photos share, the Ordination folder and the 2 sub folders are fully accessible via the Finder.
Hope that helps.
David
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello dschwartzer,
I think it may have something to do with the permission of the files and subfolder since they were from a Home share which is a personal share of one of the users.
Do you have a local user name Photos? Normally, the homes shares are named after the local user name and these home shares are in Home share when you get to admin page > Shares or access the NAS shares and get to Home share using admin account.
- Mark as New
- Bookmark
- Subscribe
- Permalink
JennaC:
I'm afraid I wasn't very clear when I tried to expalin this.
No, there is no local user called Photos. What I was trying to explain was that there is a sub-folder in MY Home directory. The path should have said
Home > xxxx.xxxxxx@gmail.com > Photos. The Folder Ordination is inside the Photos folder, which is inside my personal Home folder.
I can also tell you that there is another sub folder within my personbal Photos folder and that one is fully accessible from the Finder.
Does that explain it better?
David
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello dschwartzer,
- Mark as New
- Bookmark
- Subscribe
- Permalink
JennC:
I was not able to move the Ordination folder from the Pictures subfolder but did have another copy of it in the main Pictures share and copied that into the top level of the personal folder. That copy actually did not complete gracefully. The Ordination folder was created but the contents did not copy over. I had to copy the contents seperatly but it ultimately did work in Finder.
I then deleted the grayed out Ordination folder from the User Pictures folder but had to do that from the Admin screen. I had done that before and tried to recopyt the folder and its contents into the Pictures folder but it never worked.
This time, I copied the Ordination folder from the User Home folder to the User Home > Pictures folder and it copied gracefuuly and I can access it via Finder.
I'm not sure why it woirked this time but it would appear that you were correct that there was something wrong with the actual folder or permissions and not the ReadyNAS or OS.
This is now resolved and I appreciate all of your help with this. I will mark it resolved.
David
