× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Sync-ing Files to NAS ......
georgejzeck7244
Hello All -
I own a ReadyNAS Duo (v1). I would like to be able to have folders on my PC synced / backup (Win 7) with my NAS (preferably auto at night). Does Netgear have a solution? Third Party?
Typically I backup from NAS to a ext HD (works fine). Can't get NAS (RAIDar) to backup the other way. Tried "Cobian" and Allway Sync with no luck (couldn't properly get into and 'see" the NAS). I suspect something to do with "FTP" (a foreign topic to me).
Thanks
George
Message 1 of 4
Guru
Re: Sync-ing Files to NAS ......
I'm not familiar with Cobian or Allway Sync.
Personally I use Acronis, which runs on the PCs per schedule and outputs its image files to destination folders on the NAS. It needs the NAS credentials to do that. Acronis is just backing up, it is not 2-way sync.
Frontview can do backup jobs from a PC folder to the NAS, but it can be a little tricky to set up. You need to share the PC folder (on the PC), and often need to use the PC's IP address instead of its name.
If you map the destination share on the duo to a drive letter on the PC, you can find a number of PC tools that will work.
Message 2 of 4
georgejzeck7244
I'll try that. Thanks.
Message 3 of 4
vandermerwe
Master
I use Cobian backup to backup some folders on NAS to PC, and some PC folders to NAS. It works very well. Never had a problem with connection. Have you ensured that the windows username and password is registered as a user on the NAS?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3537 views
  • 0 kudos
  • 3 in conversation
Announcements
