- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
The Ultimate CPU for Pro 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
The E7600 and the Q6600 are confirmed, but anybody got any further?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: The Ultimate CPU for Pro 6
i am getting a xeon x3230 to try on my pro 6
read somewhere in this forum that it is workable
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
q6600 runs at 2.4
x3230 runs at 2.66
xeon has different instructions more suitable for servers
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am running a Xeon X3230 on my RDP Pro 6...running into some heat issues...I replaced stock fans with different fans and I do not think they move enough air. I have two new jet engines on order to see if they can keep things cool.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The air must flow from the front to the back, and the lateral CPU fan must suck the air in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was running x3210 on my pro6 for more tthan two years with stock fans without any problems.
The x3230 is the q6700, you can check it on http://ark.intel.com/compare/30797,30790
The most powerful of the same family, Kentsfield, should be the QX6850: http://ark.intel.com/products/codename/23489/Kentsfield#@All
But it has a 130W TDP, so you'll have to seriously think about cooling, I guess.
- Mark as New
- Bookmark
- Subscribe
- Permalink
x3230 tdp is 95w
q6700 tdp is 105w
xeon priority is I/O
q priority is program/calculation
- Mark as New
- Bookmark
- Subscribe
- Permalink
Come on, CPU8088, do you really think they are different dyes?
It's just a matter of yields and marketing from Intel...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Would a CPU with a FSB of 1333Mhz work on the Pro 6?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not exactly, cpu8088. It is just a mistake on Intel's Q6700 page. Let's go down to the roots, I mean, datasheets. You can see the links on it on the same page http://ark.intel.com/compare/30797,30790
Check the Q6700 datasheet (http://download.intel.com/design/processor/datashts/31559205.pdf), page 72, table 26: Processor Thermal Specifications. TDP of Q6700 is the same 95W as X3230. And you can compare all other features they are the same. And all independent tests of Q6700 vs X3230 says that they are completely equal in performance. They are just the same chips, the difference only in marketing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure about 1333MHz, Equinox1. Probably not, just 1066MHz, because of Intel Q965, the chipset of Pro6 motherboard, supports only 533/800/1066MHz FSB (http://ark.intel.com/products/27732/Intel-82Q965-Graphics-and-Memory-Controller, again, see the dadasheet for complete description). Also, in Pro6 BIOS (v2.0) I can't see the ability to choose FSB.
I mean, the QX6850 CPU with 1333MHz FSB will probably work on the Pro6, but only with 1066MHz FSB, like the Q6600.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Equinox1,
Yep, reversed the CPU fan and much cooler.
- Mark as New
- Bookmark
- Subscribe
- Permalink
put in x3230 for few days. does not seem noticeable difference from original pentium d. perhaps faster for transcoding but i dont use.
now swapped that with a core2duo E7500 3.0GHz. ui pop up faster and cpu runs cool.
