× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Trust domain stopped working aftrer update to 6.5.1
fragki
I am using a ReadyNas 312 and i had it setup with active directory authentication and enabled trusted domain, which was working perfectly before the upgrade to 6.5.1.
After upgrading i am unable to access the shares over a trusted domain.
Any ideas?
Thnx
Model: RN31221E|ReadyNAS 300 Series 2- Bay
Message 1 of 4
Guru
Re: Trust domain stopped working aftrer update to 6.5.2
@fragki wrote:
I am using a ReadyNas 312 and i had it setup with active directory authentication and enabled trusted domain, which was working perfectly before the upgrade to 6.5.3.
Any ideas?
Thnx
On the versions: 6.5.1 is the current shipping version, 6.5.2 is in beta.  There is no 6.5.3.
Can you clarify which firmware you are using?
Message 2 of 4
fragki
Any update on this?
Thnx
Message 3 of 4
JennC
NETGEAR Employee Retired
Hello fragki,
Please try contacting support, your ReadyNAS 312 is entitled to a lifetime CHAT support.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2321 views
  • 0 kudos
  • 3 in conversation
Announcements
