Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
USB Backup
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-06
12:16 PM
2014-01-06
12:16 PM
USB Backup
Thanks for any help you can offer.
I am attempting to connect a large drive in a drive enclosure via a usb port (3tb) - the drive is not "seen" in the admin panel to create a backup to. I have connected a small (8gb) thumb drive and this shows up in a matter of seconds.
(the current device I am working on is an older Duo, but I need the information for a Pro2, and RN314)
Is the size a problem? Is there a file format that I should be working with? (I have a mixed mac/windows environment, so the drive is currently exfat format). (other options are Mac Extended, NTFS)
Am I missing something?
Thanks for your help
Kevin
Kevin
Message 1 of 12
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-06
12:20 PM
2014-01-06
12:20 PM
Re: USB Backup
I think the problem is that you are doing this on the older duo - which doesn't support drives > 2 TB.
Message 2 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-06
02:15 PM
2014-01-06
02:15 PM
Re: USB Backup
Thank you for your reply
I started wondering that - I need to grab another drive (smaller) to test. Do you know if the Pro2, and the 314 support larger drives
Message 3 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-06
04:52 PM
2014-01-06
04:52 PM
Re: USB Backup
Yes, the Pro2 and the 314 support larger drives.
Message 4 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-07
12:44 PM
2014-01-07
12:44 PM
Re: USB Backup
Additional question
Is there a preferable disk format for a newly installed HD?
Thanks
Kevin
Thanks
Kevin
Message 5 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-07
03:37 PM
2014-01-07
03:37 PM
Re: USB Backup
You mean an external drive?
Generally I recommend NTFS. EXT will usually back up faster, but having a backup you can't read on a non-linux PC is (in my opinion) a bad approach.
Message 6 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-08
06:07 AM
2014-01-08
06:07 AM
Re: USB Backup
I used EXT2, purportedly faster at least with my NV+. There's no problem using it with Windows using Linux Reader.
Message 7 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-08
07:16 AM
2014-01-08
07:16 AM
Re: USB Backup
If you go that route, I suggest downloading the software now, and making sure you can read the first backup.
Message 8 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-08
10:19 AM
2014-01-08
10:19 AM
Re: USB Backup
I probably should have kept quiet since I don't know the Pro2 or 314. If they support NTFS that's clearly the best way to go.
Message 9 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-08
12:32 PM
2014-01-08
12:32 PM
Re: USB Backup
EXT is also a reasonable choice.
maxblack wrote: I probably should have kept quiet since I don't know the Pro2 or 314. If they support NTFS that's clearly the best way to go.
Whatever format you pick, you need to make sure you can access the backups before something fails...
Message 10 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-26
01:04 AM
2014-01-26
01:04 AM
Re: USB Backup
Keep in mind the that such a large back up via USB takes a very very (x100) long time.
I have a ReadyNAS Duo v1 with 2TB worth of storage, (only 1.4TB used) this took over 2 weeks to back up (1GB every 15-20 mins) - NTFS share, with Fast USB write enabled - an embarrassing statistic..
Message 11 of 12
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-01-26
04:13 AM
2014-01-26
04:13 AM
Re: USB Backup
Your duo v1 copies to USB at ~2.5 MB/s for NTFS
parkerc wrote: Keep in mind the that such a large back up via USB takes a very very (x100) long time.
These NAS are quicker, but copying over gigabit ethernet would still be a lot faster than USB.
The RN300 series will copy about 16 MB/s over the USB 3 ports, (again NTFS), the pro-2 will do about 13 MB/s. In the case of the pro-2, smallnetbuilder found no speed difference between ntfs and ext performance (with usb).
Over gigabit ethernet you should get 80-100 MB/s speeds. 100 mbit ethernet is slightly slower than the USB speeds above.
Message 12 of 12
