Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ultra 2 won't shutdown -- reboots instead
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-23
05:24 AM
2012-06-23
05:24 AM
Hi,
I just set up my Ultra2 last week with two Seagate ST2000DL003 disks, and I upgraded it with the newest firmware 4.2.21. I'm moving this weekend and suffering from a bizzare problem. I'm trying to turn it off, but it just turns itself back on after shutdown (essentially rebooting itself). This happens regardless of whether I press the front button twice or shut it down in Frontview.
Any ideas?
Or ideas for where to start debugging this problem? I have enabled the root-SSH addon but haven't made any substantive changes to the system (just apt-getted iostat and strace). I'm new to ReadyNAS, this is my first one.
Thanks!
Daniel
Any ideas?
Thanks!
Daniel
Message 1 of 10
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-23
05:36 AM
2012-06-23
05:36 AM
Re: Ultra 2 won't shutdown -- reboots instead
That's very odd.
What's the output of the following?:
ls -laR /var/spool/frontview
Message 2 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-23
06:32 AM
2012-06-23
06:32 AM
Disconnect network cable from Ultra2 then try power down from front panel. Any USB devices connected? Maybe disconnect those as well.
Message 3 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-23
07:10 AM
2012-06-23
07:10 AM
Also are you able to download the logs (Status > Logs > Download all logs), extract the contents of the zip file and post the contents of bios_ver.log?
Message 4 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-23
01:27 PM
2012-06-23
01:27 PM
Along with the information that has already been requested, I highly recommend you open a support ticket and have a Netgear Support Expert view your unit - http://support.netgear.com/
Message 5 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-23
02:06 PM
2012-06-23
02:06 PM
Can you try it on another power outlet in the house? Just want to make sure theres no issue with the grounding.
Message 6 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-23
07:54 PM
2012-06-23
07:54 PM
Thanks for all the advice! Sorry I haven't been able to reply until now, I've been busy painting my new apartment. 🙂
Here's the spool directory:
# ls -laR /var/spool/frontview
/var/spool/frontview:
total 16
drwxr-xr-x 4 admin admin 4096 2012-06-23 07:52 .
drwxr-xr-x 7 root root 4096 2012-06-22 23:11 ..
drwx------ 2 admin admin 4096 2012-06-22 23:11 boot
drwx------ 2 admin admin 4096 2012-06-22 23:11 shutdown
/var/spool/frontview/boot:
total 8
drwx------ 2 admin admin 4096 2012-06-22 23:11 .
drwxr-xr-x 4 admin admin 4096 2012-06-23 07:52 ..
/var/spool/frontview/shutdown:
total 16
-rw-r--r-- 1 admin admin 194 2012-06-22 23:06 00_Downgrade
-rwx------ 1 admin admin 4060 2012-05-31 14:42 080_Poweron
And bios_ver.log has this:
09/08/2010 ReadyNAS-ProUltra2 V1.4
Does that suggest anything?
I did open a case with netgear support (18832887). They suggested performing an OS reinstall.
So I think my plan is to:
- Try claykin's suggestion of unplugging the ethernet cable and powering down from the front panel.
- If that doesn't work, try support's suggestion of reinstalling the OS.
total 16
total 8
total 16
Message 7 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-23
07:58 PM
2012-06-23
07:58 PM
There is a BIOS update available for your NAS: http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin
It can be installed via Add-Ons > Add New in Frontview.
boezeroen wrote: my bios_ver logfile before update shows:
After update:
11/02/2011 ReadyNAS-ProUltra2 V1.8
Message 8 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-23
08:10 PM
2012-06-23
08:10 PM
No luck --- unplugging the ethernet cable while powering down didn't help. Reinstalling the OS didn't help either. My Netgear still won't shut down. 😕
(I have no USB devices connected. I could try moving it to another outlet, but I'd have to do an "ungraceful" shutdown... and then I might as well just unplug it and move it to my new apartment and worry about it later.)
Any other ideas?
Any other ideas?
Message 9 of 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-06-23
08:13 PM
2012-06-23
08:13 PM
Seems like frontview is doing the right thing, since system.log says "powering off device", "shutting down for system halt", etc. So why... isn't it actually shutting off? Hardware fault??
Jun 22 23:22:38 dpeng-nas chronyd[2614]: Selected source 209.249.181.22
Jun 23 07:51:22 dpeng-nas RAIDiator: Please close this browser session and use RAIDar to reconnect to the device after it is powered back on. System powering off...
Jun 23 07:51:22 dpeng-nas RAIDiator: Powering off device
Jun 23 07:51:32 dpeng-nas shutdown[26827]: shutting down for system halt
Jun 23 07:51:32 dpeng-nas init: Switching to runlevel: 0
Jun 23 07:51:33 dpeng-nas kernel: ata1.00: configured for UDMA/133
Jun 23 07:51:33 dpeng-nas kernel: ata1: EH complete
Jun 23 07:51:33 dpeng-nas kernel: sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
Jun 23 07:51:33 dpeng-nas kernel: ata2.00: configured for UDMA/133
Jun 23 07:51:33 dpeng-nas kernel: ata2: EH complete
Jun 23 07:51:33 dpeng-nas kernel: sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
Jun 23 07:51:35 dpeng-nas avahi-daemon[2568]: Files changed, reloading.
Jun 23 07:51:35 dpeng-nas avahi-daemon[2568]: Service group file /etc/avahi/services/mt-daapd.service vanished, removing services.
Jun 23 07:51:35 dpeng-nas avahi-daemon[2568]: Got SIGHUP, reloading.
Jun 23 07:51:36 dpeng-nas exiting on signal 15
Jun 23 07:52:27 dpeng-nas syslogd 1.4.1#18: restart.
Jun 23 07:52:27 dpeng-nas kernel: klogd 1.4.1#18, log source = /proc/kmsg started.
Jun 23 07:52:27 dpeng-nas kernel: Initializing cgroup subsys cpu
Jun 23 07:52:27 dpeng-nas kernel: Linux version 2.6.37.6.RNx86_64.2.4 (jmaggard@calzone) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Mon May 21 16:00:40 PDT 2012
Jun 23 07:52:27 dpeng-nas kernel: Command line: initrd=initrd.gz reason=normal BOOT_IMAGE=kernel
Jun 23 07:52:27 dpeng-nas kernel: BIOS-provided physical RAM map:
Message 10 of 10
