- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ultra 4 with 6.4.0: Volume data is Degraded
- Mark as New
- Bookmark
- Subscribe
- Permalink
I got an email from my NAS saying that Volume data is Degraded.
Fri Dec 11 2015 1:00:33 Volume: Volume data is Degraded. Fri Dec 11 2015 0:12:32 snapshot: Smart Snapshot successfully deleted snapshot 2015_11_13__00_00_41 from share or LUN Pictures. Fri Dec 11 2015 0:12:19 snapshot: Smart Snapshot successfully deleted snapshot 2015_11_13__00_00_40 from share or LUN Documents. Fri Dec 11 2015 0:12:14 snapshot: Smart Snapshot successfully deleted snapshot 2015_11_13__00_00_38 from share or LUN Backup. Fri Dec 11 2015 0:00:39 Miscellaneous: Snapshot c_1449788433 was successfully created for share or LUN Pictures. Fri Dec 11 2015 0:00:32 Miscellaneous: Snapshot c_1449788432 was successfully created for share or LUN Documents. Fri Dec 11 2015 0:00:30 Miscellaneous: Snapshot c_1449788429 was successfully created for share or LUN Backup. Thu Dec 10 2015 19:55:14 Volume: Volume data health changed from Redundant to Degraded.
But looking at my drives all 4 show healthy with green icon.
State ONLINE and Error Count is 0 on all of them.
These are all "old" HDDs so I have not added any new before getting this message.
If one drive is failing, how can I know which one?
What actions can I take? (after backup)
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ultra 4 with 6.4.0: Volume data is Degraded
Disk info logs:
Device: sda Controller: 0 Channel: 0 Model: WDC WD20EARS-00J99B0 Serial: WD-WCAWZ1395124 Firmware: 80.00A80 Class: SATA Sectors: 3907029168 Pool: data PoolType: RAID 5 PoolState: 3 PoolHostId: 5e26b5f2 Health data ; ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 28 Start/Stop Count: 61 Power-On Hours: 36891 Power Cycle Count: 59 Load Cycle Count: 32004 Device: sdb Controller: 0 Channel: 1 Model: WDC WD20EARS-00J99B0 Serial: WD-WCAWZ1499595 Firmware: 80.00A80 Class: SATA Sectors: 3907029168 Pool: data PoolType: RAID 5 PoolState: 3 PoolHostId: 5e26b5f2 Health data ; ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 1 Uncorrectable Sector Count: 0 Temperature: 28 Start/Stop Count: 57 Power-On Hours: 36864 Power Cycle Count: 55 Load Cycle Count: 29812 Device: sdc Controller: 0 Channel: 2 Model: WDC WD30EFRX-68AX9N0 Serial: WD-WMC1T1298310 Firmware: 80.00A80 Class: SATA Sectors: 5860533168 Pool: data PoolType: RAID 5 PoolState: 3 PoolHostId: 5e26b5f2 Health data ; ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 24 Start/Stop Count: 36 Power-On Hours: 23934 Power Cycle Count: 36 Load Cycle Count: 17 Device: sdd Controller: 0 Channel: 3 Model: WDC WD30EFRX-68AX9N0 Serial: WD-WCC1T1604088 Firmware: 80.00A80 Class: SATA Sectors: 5860533168 Pool: data PoolType: RAID 5 PoolState: 3 PoolHostId: 5e26b5f2 Health data ; ATA Error Count: 0 Reallocated Sectors: 0 Reallocation Events: 0 Spin Retry Count: 0 Current Pending Sector Count: 0 Uncorrectable Sector Count: 0 Temperature: 21 Start/Stop Count: 27 Power-On Hours: 16715 Power Cycle Count: 27 Load Cycle Count: 14
- Mark as New
- Bookmark
- Subscribe
- Permalink
Think I found it in the Kernel.log:
Dec 10 19:54:28 Ultra kernel: sd 1:0:0:0: [sdb] tag#20 Add. Sense: Unrecovered read error - auto reallocate failed Dec 10 19:54:28 Ultra kernel: sd 1:0:0:0: [sdb] tag#20 CDB: Write(10) 2a 00 a9 bf e7 c0 00 00 40 00 Dec 10 19:54:28 Ultra kernel: blk_update_request: I/O error, dev sdb, sector 2847926208 Dec 10 19:54:28 Ultra kernel: md/raid:md127: Disk failure on sdb3, disabling device. Dec 10 19:54:28 Ultra kernel: md/raid:md127: Operation continuing on 3 devices. Dec 10 19:54:28 Ultra kernel: sd 1:0:0:0: [sdb] tag#21 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE Dec 10 19:54:28 Ultra kernel: sd 1:0:0:0: [sdb] tag#21 Sense Key : Medium Error [current] [descriptor] Dec 10 19:54:28 Ultra kernel: sd 1:0:0:0: [sdb] tag#21 Add. Sense: Unrecovered read error - auto reallocate failed Dec 10 19:54:28 Ultra kernel: sd 1:0:0:0: [sdb] tag#21 CDB: Read(10) 28 00 6c 69 ad 00 00 00 40 00 Dec 10 19:54:28 Ultra kernel: blk_update_request: I/O error, dev sdb, sector 1818864896 Dec 10 19:54:28 Ultra kernel: ata2: EH complete Dec 10 19:54:30 Ultra kernel: ata2.00: exception Emask 0x0 SAct 0x8000040 SErr 0x0 action 0x0 Dec 10 19:54:30 Ultra kernel: ata2.00: irq_stat 0x40000008 Dec 10 19:54:30 Ultra kernel: ata2.00: failed command: READ FPDMA QUEUED Dec 10 19:54:30 Ultra kernel: ata2.00: cmd 60/08:d8:38:e8:bf/00:00:a9:00:00/40 tag 27 ncq 4096 in Dec 10 19:54:30 Ultra kernel: res 41/40:00:38:e8:bf/00:00:a9:00:00/40 Emask 0x409 (media error) <F> Dec 10 19:54:30 Ultra kernel: ata2.00: status: { DRDY ERR } Dec 10 19:54:30 Ultra kernel: ata2.00: error: { UNC } Dec 10 19:54:30 Ultra kernel: ata2.00: configured for UDMA/133 Dec 10 19:54:30 Ultra kernel: sd 1:0:0:0: [sdb] tag#27 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE Dec 10 19:54:30 Ultra kernel: sd 1:0:0:0: [sdb] tag#27 Sense Key : Medium Error [current] [descriptor] Dec 10 19:54:30 Ultra kernel: sd 1:0:0:0: [sdb] tag#27 Add. Sense: Unrecovered read error - auto reallocate failed Dec 10 19:54:30 Ultra kernel: sd 1:0:0:0: [sdb] tag#27 CDB: Read(10) 28 00 a9 bf e8 38 00 00 08 00 Dec 10 19:54:30 Ultra kernel: blk_update_request: I/O error, dev sdb, sector 2847926328 Dec 10 19:54:30 Ultra kernel: md/raid:md127: read error not correctable (sector 2838489080 on sdb3). Dec 10 19:54:30 Ultra kernel: RAID conf printout: Dec 10 19:54:30 Ultra kernel: --- level:5 rd:4 wd:3 Dec 10 19:54:30 Ultra kernel: disk 0, o:1, dev:sda3 Dec 10 19:54:30 Ultra kernel: disk 1, o:0, dev:sdb3 Dec 10 19:54:30 Ultra kernel: disk 2, o:1, dev:sdc3 Dec 10 19:54:30 Ultra kernel: ata2: EH complete Dec 10 19:54:30 Ultra kernel: disk 3, o:1, dev:sdd3 Dec 10 19:54:30 Ultra kernel: RAID conf printout: Dec 10 19:54:30 Ultra kernel: --- level:5 rd:4 wd:3 Dec 10 19:54:30 Ultra kernel: disk 0, o:1, dev:sda3 Dec 10 19:54:30 Ultra kernel: disk 2, o:1, dev:sdc3 Dec 10 19:54:30 Ultra kernel: disk 3, o:1, dev:sdd3
Seems like the second drive is failing. Strange I couldn't see this from the GUI.
Or am I missing something @mdgm-ntgr, @StephenB?
Thanks !
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's the single "current sector pending count" shown in the SMART stats.
RAID should have recovered the data from the parity block automatically, and it should not have degraded the array. So I'm not sure why it took the drive out of service (and of course the web ui should have told you the drive had failed). Though SMART stats don't tell you everything.
You could power down the system and test the drive with lifeguard in a PC. Or just replace it with a WD30EFRX.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hot-plug worked. System up and running. Thank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi F_L_,
Thanks for your feedback. You may now tag this thread as resolved by clicking the "Accept as solution" button in one of the responses that you received.
Kind regards,
BrianL
NETGEAR Community Team
