- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Ultra 6 onlife support out of warranty
- Mark as New
- Bookmark
- Subscribe
- Permalink
My volume had a failed disk 1. I replaced the disk and it started to rebuild. during the rebuild i got
ATA error count has increased in the last day. Disk 6: Previous count: 6 Current count: 12 Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk.
i reseat the disk as advised and rebooted the rebuild continued when about 80% done again the same thing happened. Now when i boot it says all disks are good but there is no volumes are data.
This it the rest of the log
Wed Nov 30 20:52:58 EST 2016 | System is up. | |
Wed Nov 30 20:52:58 EST 2016 | The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume. Extra video .BIN HD MyData Series_HD series | |
Wed Nov 30 20:52:43 EST 2016 | Volume scan failed to run properly. | |
Wed Nov 30 20:51:46 EST 2016 | Rebooting device... | |
Wed Nov 30 20:51:46 EST 2016 | Please close this browser session and use RAIDar to reconnect to the device. System rebooting... | |
Wed Nov 30 20:49:58 EST 2016 | System is up. | |
Wed Nov 30 20:49:58 EST 2016 | The paths for the shares listed below could not be found. Typically, this occurs when the ReadyNAS is unable to access the data volume. Extra video .BIN HD MyData Series_HD series | |
Wed Nov 30 20:49:43 EST 2016 | Volume scan failed to run properly. | |
Wed Nov 30 20:46:48 EST 2016 | Powering off device | |
Wed Nov 30 20:46:48 EST 2016 | Please close this browser session and use RAIDar to reconnect to the device after it is powered back on. System powering off... | |
Wed Nov 30 20:46:17 EST 2016 | ATA error count has increased in the last day. Disk 6: Previous count: 6 Current count: 12 Growing SMART errors indicate a disk that may fail soon. If the errors continue to increase, you should be prepared to replace the disk. |
My device is beyond warranty but i dont need see how i can open a support case and how much does this cost.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Ultra 6 onlife support out of warranty
The initial diagnostics for a data recovery attempt are about $200 USD, I believe.
- Mark as New
- Bookmark
- Subscribe
- Permalink
is there any else i can do?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Which disk did you replace? Disk 6?
- Mark as New
- Bookmark
- Subscribe
- Permalink
disk 1 failed i replaced it during the rebuild. disk 6 was giving me problems.
right now the only disk i replaced was 1 during the rebuild twice so far it went into life support mode. now the volume will not mount at all.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you purchased new between 1 June 2014 and 31 May 2016, then you have free lifetime chat support. I'd use that (my.netgear.com), though it won't include data recovery.
Probably the best you can do is try to get the volume forceably mounted, and then back up everything you can. From the sound of it, you have a multiple-disk failure scenario, and RAID-5 can't deal with that.
