Orbi WiFi 7 RBE973
Reply
Ultra4 4x2TB -> 4x3TB
mkopel
I am looking to go from 4x2TB -> 4x3TB in my ultra4. If I replace the disks one at a time will the NAS recognize when it has 4x3TB and expand the volume? Or will I have to do a factory reset? I am hoping to do this in place so I don't have to copy all the data from my backup to the new volume. Doing it in place will give me access to the data the entire time, even though it will be a much longer process.
any other gotchas I should be watching out for?
Message 1 of 8
mdgm-ntgr
NETGEAR Employee Retired
Re: Ultra4 4x2TB -> 4x3TB
What disks were installed when you last did a factory default?
You cannot expand your volume by more than 8TB. So if your volume capacity was 2.7TB when you last did a factory default you can't expand past 10.7TB.
Provided you won't hit the 8TB limit replacing the disks one at a time would work. After the resync completes replace the next disk. You may need to reboot a few times before expansion takes place. Wait 5-10 minutes between each reboot.
Message 2 of 8
mkopel
is there a way to tell what the volume capacity was at the last factory default?
Message 3 of 8
Guru
AFAIK only in the logs.
Message 4 of 8
mkopel
which log and what am I looking for. I am pretty good with vi!
Message 5 of 8
Guru
expansion.log has the expansion history. Look for the oldest "Data volume has been successfully expanded to" line (and confirm that it is the original install).
Message 6 of 8
mkopel
I can't find the expansion.log, which directory is it in? thanks for the help here...
Message 7 of 8
Guru
expansion.log is in the downloaded zip of all log files. \var\log\frontview\expand_md.log seems to be the same file.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1554 views
  • 0 kudos
  • 3 in conversation
Announcements
