× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Ultra4 with OS 6.2.4 slow with RAID-5
bgarwin
Hi,
I added a third 4TB drive to the my ULTRA 4, the write performance degraded to 45MB/s. This is with (X-RAID/RAID5) with 2 drives(X-RAID/RAID-1) the write performance was close to 80MB/s. I would suspect it is a CPU bottleneck if it was close to 100% but it only use about 40-45% CPU.
All drive are identical ST4000DM000, ULTRA4 upgraded with 2GB of memory and SMART test shows everything OK.
I upgraded to 6.2.3/6.2.4 from 6.2.2 about the same time i added the third driver, i'm not sure if it is because of the OS upgrade or the addition of the driver.
Anyone have any idea?
Message 1 of 15
RX
Luminary
Luminary
Re: Ultra4 with OS 6.2.4 slow with RAID-5
How did you test the write performance?
Is the PC you are using connected wired or wireless?
Have you tried connecting the NAS directly to the PC?
Message 2 of 15
bgarwin
Test done from a PC Wired with Cat 5E cable, 1Gb connection through switch Jumbo frame enabled. A 5GB file used to test using copy/paste from windows 8.1 machine.
Message 3 of 15
Guru
RAID-5 write performance is likely slower than RAID-1. With RAID-1, you simply write everything to both disks. With RAID-5 you need to do at least one read along with the two writes (and the read needs to complete before you can issue the second write).
An old ultra-4 review (http://www.smallnetbuilder.com/nas/nas- ... l=&start=2) measured 65 MB/S write speed with ext. BTRFS would be slower - esp. if you have snapshots on. AV protection would also slow the write performance (since that was not tested in the review).
Message 4 of 15
bgarwin
agreed, i didn't expect to have better performance. But I can't explain the 50% performance loss moving from RAID1 t o RIAD5 especially with CPU has free cycles. i do have snapshot enabled but not AV protection, but the same is true for RAID1 both with COW disabled.
Message 5 of 15
Guru
Well, there is disk latency because every parity block update needs to wait for a read to complete. Most performance guides for RAID don't give specifics, but they all agree that RAID-1 has faster write times than RAID-5.
Message 6 of 15
itsjasper
Luminary
StephenB is on the money here. This is the RAID-5 write penalty.
A good article explaining it (with calculations in IOPS) here: http://theithollow.com/2012/03/understa ... d-penalty/
Message 7 of 15
bgarwin
Thank you StephenB , makes sense.
Message 8 of 15
bgarwin
but, if I tested the raid locally I get 148 MB/s
dd if=/dev/zero of=/data/test conv=fdatasync bs=384k count=10k; rm -f /data/test
10240+0 records in
10240+0 records out
4026531840 bytes (4.0 GB) copied, 27.166 s, 148 MB/s
Message 9 of 15
mdgm-ntgr
NETGEAR Employee Retired
What does your top output look like?
Fast sequential writes locally are quite a different thing to real world usage.
Message 10 of 15
bgarwin
I'm running Plex full library scan right now, so results might be not accurate
Top with dd
top - 07:48:10 up 1:22, 2 users, load average: 3.52, 3.20, 3.16
Tasks: 173 total, 1 running, 172 sleeping, 0 stopped, 0 zombie
%Cpu(s): 30.2 us, 39.0 sy, 0.0 ni, 10.5 id, 19.9 wa, 0.0 hi, 0.3 si, 0.0 st
KiB Mem: 2041248 total, 1976140 used, 65108 free, 260 buffers
KiB Swap: 523708 total, 96 used, 523612 free, 377800 cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
21598 root 20 0 1038m 1.0g 584 D 67.8 51.4 0:02.05 dd
10504 root 20 0 364m 36m 8312 S 61.5 1.8 38:15.70 Plex Media Scan
9381 root 20 0 579m 33m 5120 S 3.3 1.7 10:21.67 Plex Media Serv
10549 root 20 0 0 0 0 S 0.7 0.0 0:13.40 btrfs-endio-2
10991 root 20 0 0 0 0 S 0.7 0.0 0:12.24 btrfs-endio-4
21583 root 20 0 28576 1688 1140 R 0.7 0.1 0:00.09 top
4 root 20 0 0 0 0 S 0.3 0.0 0:02.83 kworker/0:0
512 root 20 0 0 0 0 D 0.3 0.0 0:45.01 kswapd0
1253 root 20 0 0 0 0 S 0.3 0.0 1:56.14 md127_raid5
2055 root 20 0 798m 4576 1740 S 0.3 0.2 0:25.79 leafp2p
2439 root 20 0 0 0 0 S 0.3 0.0 0:13.54 btrfs-endio-2
2442 mysql 20 0 475m 36m 852 S 0.3 1.8 0:05.06 mysqld
2672 root 19 -1 1267m 41m 3060 S 0.3 2.1 0:48.04 readynasd
10198 root 35 15 1261m 158m 1852 S 0.3 7.9 8:51.65 python
10550 root 20 0 0 0 0 S 0.3 0.0 0:13.27 btrfs-endio-3
21021 root 20 0 948m 30m 1804 S 0.3 1.5 0:07.30 python
1 root 20 0 45700 3588 904 S 0.0 0.2 0:05.81 systemd
2 root 20 0 0 0 0 S 0.0 0.0 0:00.03 kthreadd
3 root 20 0 0 0 0 S 0.0 0.0 0:05.98 ksoftirqd/0
6 root rt 0 0 0 0 S 0.0 0.0 0:00.06 migration/0
7 root rt 0 0 0 0 S 0.0 0.0 0:00.01 watchdog/0
8 root rt 0 0 0 0 S 0.0 0.0 0:00.06 migration/1
10 root 20 0 0 0 0 S 0.0 0.0 0:05.47 ksoftirqd/1
12 root rt 0 0 0 0 S 0.0 0.0 0:00.01 watchdog/1
13 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 khelper
264 root 20 0 0 0 0 S 0.0 0.0 0:00.00 sync_supers
266 root 20 0 0 0 0 S 0.0 0.0 0:00.00 bdi-default
268 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kblockd
374 root 20 0 0 0 0 S 0.0 0.0 0:00.00 khubd
383 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 md
485 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 rpciod
507 root 20 0 0 0 0 S 0.0 0.0 0:00.00 khungtaskd
577 root 20 0 0 0 0 S 0.0 0.0 0:00.00 fsnotify_mark
594 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 nfsiod
613 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 xfsalloc
614 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 xfs_mru_cache
615 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 xfslogd
628 root 20 0 0 0 0 D 0.0 0.0 0:00.06 mdcsrepair
629 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 crypto
644 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kthrotld
744 root 20 0 0 0 0 S 0.0 0.0 0:00.00 scsi_eh_0
747 root 20 0 0 0 0 S 0.0 0.0 0:00.00 scsi_eh_1
750 root 20 0 0 0 0 S 0.0 0.0 0:00.00 scsi_eh_2
753 root 20 0 0 0 0 S 0.0 0.0 0:00.00 scsi_eh_3
756 root 20 0 0 0 0 S 0.0 0.0 0:00.00 scsi_eh_4
759 root 20 0 0 0 0 S 0.0 0.0 0:00.00 scsi_eh_5
766 root 20 0 0 0 0 S 0.0 0.0 0:00.06 kworker/u:6
772 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 target_completi
773 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 tmr
774 root 20 0 0 0 0 S 0.0 0.0 0:00.00 iscsi_ttx
775 root 20 0 0 0 0 S 0.0 0.0 0:00.00 iscsi_trx
776 root 20 0 0 0 0 S 0.0 0.0 0:00.00 iscsi_ttx
777 root 20 0 0 0 0 S 0.0 0.0 0:00.00 iscsi_trx
778 root 20 0 0 0 0 S 0.0 0.0 0:00.00 iscsi_ttx
top with network copy
top - 07:49:38 up 1:23, 2 users, load average: 3.32, 3.20, 3.17
Tasks: 170 total, 3 running, 167 sleeping, 0 stopped, 0 zombie
%Cpu(s): 35.0 us, 28.7 sy, 0.0 ni, 17.8 id, 1.3 wa, 0.0 hi, 17.1 si, 0.0 st
KiB Mem: 2041248 total, 1915688 used, 125560 free, 408 buffers
KiB Swap: 523708 total, 96 used, 523612 free, 1364204 cached
10504 root 20 0 364m 36m 8324 S 77.8 1.8 39:17.31 Plex Media Scan
10683 guest 20 0 265m 6816 3244 R 29.4 0.3 2:03.91 smbd
1253 root 20 0 0 0 0 R 19.5 0.0 2:02.25 md127_raid5
2153 root 20 0 0 0 0 D 15.5 0.0 1:03.79 flush-btrfs-2
9381 root 20 0 579m 34m 6060 S 2.6 1.7 10:24.24 Plex Media Serv
21583 root 20 0 28576 1696 1144 R 1.3 0.1 0:00.84 top
10 root 20 0 0 0 0 S 1.0 0.0 0:05.60 ksoftirqd/1
2055 root 20 0 798m 4576 1740 S 1.0 0.2 0:26.25 leafp2p
2672 root 19 -1 1267m 41m 3104 S 1.0 2.1 0:48.41 readynasd
10991 root 20 0 0 0 0 S 1.0 0.0 0:12.97 btrfs-endio-4
3 root 20 0 0 0 0 S 0.7 0.0 0:06.13 ksoftirqd/0
2439 root 20 0 0 0 0 S 0.7 0.0 0:14.28 btrfs-endio-2
10198 root 35 15 1261m 158m 1852 S 0.7 7.9 8:51.89 python
10549 root 20 0 0 0 0 S 0.7 0.0 0:14.14 btrfs-endio-2
10550 root 20 0 0 0 0 S 0.7 0.0 0:13.99 btrfs-endio-3
21021 root 20 0 948m 30m 1804 S 0.7 1.5 0:07.36 python
4 root 20 0 0 0 0 S 0.0 0.0 0:02.87 kworker/0:0
12 root rt 0 0 0 0 S 0.0 0.0 0:00.02 watchdog/1
512 root 20 0 0 0 0 S 0.0 0.0 0:46.30 kswapd0
Message 11 of 15
mdgm-ntgr
Plex using a lot of CPU for the library scan would have an impact on the performance of file transfers
Message 12 of 15
bgarwin
I will post results without Plex scan running when I got home. I tried downgrading to 6.2.0 with no improvement, it got to be the RAID-5. but what I suspect is OS6 X86-64 is optimized for 3XX series and up, with review for the 314 scores in the 80MB/s.
I was quite happy with OS6 on the Ultra 4 on RAID-1, but now I'm considering to revert to official firmware.
There is this thread complaining about the performance drop from ROS4 to ROS6 http://www.readynas.com/forum/viewtopic.php?f=21&t=70847#p39348, but i want to hear more from other users about this RIAD-5 on ROS4 for the ULTRA4.
Message 13 of 15
mdgm-ntgr
The Ultra 4 does have a single core CPU. It is the x86_64 ReadyNAS with the least powerful CPU
Message 14 of 15
bgarwin
An update, this issue has nothing to do with netgear OS6 or netgear anything for that matter.
I remembered the CAT6 cable connected to the switch connected to the Readynas was connected to one of the Leviton SNAP on port, this port wasn't securely mounted to the wall hence couldn't firmly secure the port to it, it was moved when we were dusting the house :-S.
anyway, i can get 90MB/S write now after I secured the port.
Many thanks to StephenB and mdgm for their help.
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 2850 views
  • 0 kudos
  • 5 in conversation
Announcements
