- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Very long file uploads using CIFS mount
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi.
I use ReadyNas as IP camera storage.
I use dedicated software to transfer file from pc's hard-drive to storage.
Both readynas and hard-drives are pretty new.
Firmware version is 6.5.0 (updated a few days ago)
Files being transfered are about 20MB. There are ~10 files per minute to transfer (transfer is one by one, not paralell).
Computer and storage are connected with 1Gbps local network.
Most of time everything is ok, performance is superb, but:
Once every few recordings (maybe once every 5-10 minutes) transfer hangs. No data is transfered - mv command hangs. It usually takes up to 3 minutes to finalize transfer of single file.
During hangup stack trace of mv command is:
[<ffffffffa0f4d6df>] wait_for_free_request+0xcf/0x1b0 [cifs] [<ffffffffa0f4e128>] cifs_call_async+0x48/0x1e0 [cifs] [<ffffffffa0f2a7e8>] cifs_async_writev+0x1b8/0x2d0 [cifs] [<ffffffffa0f43907>] cifs_writepages+0x547/0x7f0 [cifs] [<ffffffff8114ef1e>] do_writepages+0x1e/0x30 [<ffffffff81143b2a>] __filemap_fdatawrite_range+0xaa/0xf0 [<ffffffff81143bec>] filemap_write_and_wait+0x2c/0x60 [<ffffffffa0f49a75>] cifs_setattr+0xb5/0x9d0 [cifs] [<ffffffff811b77ed>] notify_change+0x20d/0x350 [<ffffffff811cd5d5>] utimes_common+0xc5/0x1b0 [<ffffffff811cd7cc>] do_utimes+0x10c/0x130 [<ffffffff811cd8b7>] SyS_utimensat+0x57/0x80 [<ffffffff8164b91b>] entry_SYSCALL_64_fastpath+0x16/0x6e
No other users access storage, antyvirus is off.
No messages in dmesg log.
What can cause the problem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Very long file uploads using CIFS mount
An update to my thread.
I logged into ReadyNAS via SSH, opened top, and i see, that
kworker/u2:7
is consuming 100% CPU all the time
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello peku33,
What's the model number of the NAS you have?
Can you also describe how the NAS and IP camera are setup in the network?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's ReadyNAS 102 with 2x WD 2GB drives.
8 ip cameras, PC computer and NAS are connected with 1Gbps switch
PC records video from cameras in 1-minute parts. They are stored in local temporary directory. After 10 parts are ready, they are transfered to NAS via linux mv command. NAS is mounted as CIFS. After transfer is complete, there is a cleanup routine that deletes 10 oldest files from NAS and so on.
I think that the major problem is the NAS uses btrfs that has to perform tree balancing after files beeing deleted.
However deleteing 10 files per minute shouldn't degradate performance to zero.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello peku33,
What apps are currently running on the NAS? Have you tried turning them off and see if there is any improvement?
- Mark as New
- Bookmark
- Subscribe
- Permalink
There are no apps running on NAS.
It's absolutely clean, just ssh + cifs enabled.
No apps, no other features, antyvirus is off.
I'm almost sure there is a problem with filesystem tree balancing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you copy-on-write enabled on the share? Do you have snapshots enable on the share? Did you ever run a balance? Did you ever run a defrag?
Can you post the result of the command "btrfs fi us /data"? (Replace /data with /<name_of_your_volume> if different)
- Mark as New
- Bookmark
- Subscribe
- Permalink
root@nas:~# btrfs fi us /data Overall: Device size: 1.81TiB Device allocated: 1.81TiB Device unallocated: 0.00B Device missing: 0.00B Used: 1.80TiB Free (estimated): 11.22GiB (min: 11.22GiB) Data ratio: 1.00 Metadata ratio: 1.99 Global reserve: 96.00MiB (used: 0.00B) Data,single: Size:1.81TiB, Used:1.80TiB /dev/md127 1.81TiB Metadata,single: Size:8.00MiB, Used:0.00B /dev/md127 8.00MiB Metadata,DUP: Size:1.00GiB, Used:221.53MiB /dev/md127 2.00GiB System,single: Size:4.00MiB, Used:0.00B /dev/md127 4.00MiB System,DUP: Size:8.00MiB, Used:256.00KiB /dev/md127 16.00MiB Unallocated: /dev/md127 0.00B root@nas:~#
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your volume is completely full?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, I always keep ~10G free space. This is done by the program from the first post.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So it is 99.5% full. That's the problem I think. If you keep the volume 80% full you should get much better performance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Is there any technical explaination for that?
Loosing 20% (400GB!) of space just to keep the device running is radiculous.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My personal experience says that you want at least 10% free space with any file system. 20% is Netgear's recommendation and I don't know all the reasons for it.
I do know that the BTRFS chunk size is 1 GB, and I suspect the file system is wanting to allocate a new chunk when your problem occurs (and doesn't have one).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your reply.
Could you provide me a link to "Netgear's recommendation"?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Really? You are somehow missing all those warnings in the log every time you restart your NAS?
I don't know if its in a knowledge base article or not, but it is routinely stated here. For instance, mdgm's post on this thread: https://community.netgear.com/t5/ReadyNAS-Hardware-Compatibility/ReadyNas-3220-volume-degraded/td-p/...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I personally never saw it written anywhere (except of course the warnings in the GUI)... but it's not the point, "NETGEAR recommends 20% free space" is a recommendation, not an obligation. That's probably why it's written not anywhere... to avoid confusion between recommandation and obligation.
That said, I understand this can look surprising. But if you consider the following, it actually makes sense:
It's common to ALL filesystems to require 10% free space to have optimum behavior, avoid issues and prevent too much fragmentation (of data and of free space).
BTRFS being a copy-on-write filesystem, it feels more confortable if there is a significant amount of free space. Unfortunately, 10GB is far from being enough.
