- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Volume Maintenance and Bit-rot
- Mark as New
- Bookmark
- Subscribe
- Permalink
My NAS and usage may help with this question?
NAS: RN626
Apps: Plex/Anti-Virus and Photo Hosting
Weekly Backkups of two PCs's Files and images.
Month adds of a few hundred photos/videos.
Hosting of a small Website
Weekly backups from NAS to NAS coming shortly.
So I'm curious to what if any recommendation exists for setting up Volume Maintenance? The only timeline given by the software manual was for scrubbing: Scrubbing cleans and validates all data on a volume and checks the volume for errors. No data is deleted. Folders, LUNs, and snapshots on the volume remain intact. Scrubbing every six to eight weeks is common.
The options are as follows below and the manual doesn't really talk about Disk Test other than it's an option when setting a schedule.
Defrag
Balance
Scrub
Disk Test
Are others using Bit-rot? From the manual: Bit rot protection is available for any folder stored on your ReadyNAS system. On higher-end models it is on by default. Bit rot protection can slow the performance of a system and increase fragmentation, and so is not on by default on lower-end models.
I presume if Bit-Rot isn't used than routine defragmentation wouldnt' be required? I'm guessing the 626 is a lower end NAS since it wasn't on by default but even so I'm uncertain how much I would really need it.
I did manage to find this post but wasn't sure how model and usage dependent those recommendations are: https://community.netgear.com/t5/Using-your-ReadyNAS/Readynas-3220-What-is-recommended-volume-mainte...
Any advice is appreciated, thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Volume Maintenance and Bit-rot
Well, with any file system the need for defrag does depend on usage.
As far as BTRFS goes, updating a file in a share that has a snapshot will fragment that file. That happens even if bit-rot protection is off.
The 626X is at the top of the line of course. Perhaps the manual needs a bit of updating.
Bit-Rot protection is a proprietary netgear feature. "Bit-Rot" occurs when files somehow get corrupted on the disk. The bit-rot protection uses the parity info plus the BTRFS file checksum to recover the file data. The odds of bit-rot on an RN626X are lower than most consumer-NAS because it uses error-correcting RAM.
Enabling Bit-Rot protection also enables CoW all the time.
Personally I run each of the 4 tests once a quarter, spacing them out through the quarter.
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's good feedback as usual. I believe you have a 526 so do you use Bit-rot and if so was there a significant performance hit? I didn't have it turned on when I moved all my data to the new NAS and from what I read it would only help with new files written to the NAS. So I guess the protection would be limited? As for the other tests, I was going to run the defrag/balance twice a month and the scrub (which takes forever) 3 times a year. I dont' really know what the disk test does or if it's necessary as their is no explaination given in the manual.
- Mark as New
- Bookmark
- Subscribe
- Permalink
It's not turned on in my RN102 and RN202 (both are jbod, so it doesn't really apply). The RN526 isn't really set up yet - I'm still kicking the tires on it. It's on at the moment, and I'm planning to leave it on.
It should work on all the files in the shares where it's turned on (even if it is turned on after files are written to the share).
I believe its the long non-destructive SMART test (built into the drive).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Got it on Bit-rot and I intend to do some testing here using a dummy share and files to see what if any hit the 626 takes. I'm sure there is some degration but I'm still not convinced it's needed given my use. Although, if the performance hit is negligible I may just leave it on for added insurance. Especially on files that are rarely accessed such as old pictures/videos. You wouldn't happen to know how long that disk test runs? It probably varies per disk and array size but just ballpark would be enough of an idea. I'm unable to run it manually (unlike defrag/balance/scrub) but I could set the schedule so that it runs instantly. And get that 526 up into production already as this forum is depending on you! You're like a one man team on here and for the most part one of the few that reliably responds to my post regardless of which section I post in.
- Mark as New
- Bookmark
- Subscribe
- Permalink
We link enabling/disabling bit-rot protection to enabling/disabling CoW. The GUI option is set at the share level. So one share could have bit-rot protection enabled and another have it disabled.
Defragmentation breaks the CoW link between current data and snapshots, but it doesn't uncow a file.
CoW should not be used where there are a huge number of modifications made in place to files.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The last run on my RN202 was on the 6 TB drive. It took about 12 hours.
@NASguru wrote:
Got it on Bit-rot ... but I'm still not convinced it's needed given my use.
As mdgm says, some shares definitely shouldn't use it (or snapshots). Torrent download folders is one example - the file is updated every time a block is received, and that creates a lot of fragmentation.
As far as overhead goes, if there are no errors the main overhead is computing the btrfs checksums when data blocks are written and verifying them when data blocks are read. I doubt if you'd see any impact on your 626X unless you are using 10 gbit (and maybe not even then). Though its worth testing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@mdgm wrote:We link enabling/disabling bit-rot protection to enabling/disabling CoW. The GUI option is set at the share level. So one share could have bit-rot protection enabled and another have it disabled.
Ok, the only share where there is a number of modifications going on is the backup share for my PCs and other files. The rest would be photos/vidoes/etc which sounds like may benefit from Bit-rot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@StephenB wrote:
@NASguru wrote:You wouldn't happen to know how long that disk test runs?
@NASguru wrote:Got it on Bit-rot ... but I'm still not convinced it's needed given my use.
Yup, that makes sense and I'm not running Torrent so no worries there. I'll test it either way once I get some time here.
