× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Volume is missing after the device has been turned off.
JackDC1
Helo
I hope you can help me.
I have a problem with my ReadyNAS Nv+ V. 2. After the device has been turned off or rebooted the volume is missing.
Message 1 of 4
evan2
NETGEAR Expert
Re: Volume is missing after the device has been turned off.
Message 2 of 4
JackDC1
The logs have been sent
By G-mail
Message 3 of 4
evan2
NETGEAR Expert
Hi JackDC,
I checked logs, all disk smart is OK, but there is I/O error on sdb and sdc when system boot, so system didn't detect adb and sdc's partitions.
May 16 21:32:13 ReadyNAS kernel: sd 0:0:1:0: [sdb] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
May 16 21:32:13 ReadyNAS kernel: sd 0:0:1:0: [sdb] Sense Key : Aborted Command [current] [descriptor]
May 16 21:32:13 ReadyNAS kernel: Descriptor sense data with sense descriptors (in hex):
May 16 21:32:13 ReadyNAS kernel: 72 0b 00 00 00 00 00 0c 00 0a 80 00 00 00 00 00
May 16 21:32:13 ReadyNAS kernel: 00 00 00 00
May 16 21:32:13 ReadyNAS kernel: sd 0:0:1:0: [sdb] Add. Sense: No additional sense information
May 16 21:32:13 ReadyNAS kernel: end_request: I/O error, dev sdb, sector 5860532992
May 16 21:32:13 ReadyNAS kernel: Buffer I/O error on device sdb, logical block 732566624
May 16 21:32:13 ReadyNAS kernel: end_request: I/O error, dev sdb, sector 5860533152
May 16 21:32:13 ReadyNAS kernel: Buffer I/O error on device sdb, logical block 732566644
May 16 21:32:13 ReadyNAS kernel: Buffer I/O error on device sdb, logical block 732566645
May 16 21:32:13 ReadyNAS kernel: sd 0:0:2:0: [sdc] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
May 16 21:32:13 ReadyNAS kernel: sd 0:0:2:0: [sdc] Sense Key : Aborted Command [current] [descriptor]
May 16 21:32:13 ReadyNAS kernel: sd 0:0:2:0: [sdc] Add. Sense: No additional sense information
May 16 21:32:13 ReadyNAS kernel: end_request: I/O error, dev sdc, sector 5860532992
May 16 21:32:13 ReadyNAS kernel: Buffer I/O error on device sdc, logical block 732566624
May 16 21:32:13 ReadyNAS kernel: end_request: I/O error, dev sdc, sector 5860533152
May 16 21:32:13 ReadyNAS kernel: Buffer I/O error on device sdc, logical block 732566644
May 16 21:32:13 ReadyNAS kernel: Buffer I/O error on device sdc, logical block 732566645
Maybe sdb and sdc are locked.
Please open a support case, then our support can remote access your NAS and check the problem.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1292 views
  • 0 kudos
  • 2 in conversation
Announcements
