× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Volumes not labeled, which bay to insert?
SachinGurgaon
Follower
I got my faulty NAS box replaced with new one. There are 2 volumes not lableded. How do i ensure that i put them in correct bay? Is there any way?
Model: RN31400|ReadyNAS 300 Series 4- Bay (Diskless)
Message 1 of 2
Guru
Re: Volumes not labeled, which bay to insert?
Generally we recommend labeling the disks are you remove them, as it can make troubleshooting easier.  But you can put them in any slot.
If you happen to have a log zip file from the old NAS you can look at disk_info.log - where the disks are listed in slot order, with their serial numbers.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 388 views
  • 0 kudos
  • 2 in conversation
Announcements
