Rucyj35's avatar
Rucyj35
Which disk format to use when adding
I have a NAS 102 populated with two drives, RAID1, now running out of space.
I've added a further external drive via USB port.
The System sees it, but reports the message:  System: External storage device is connected but the file system is not recognized.
I checked on my PC it was standard Win11 formatted, and accessible. Since it does not come up as potential capacity, I can't use the NAS format function. Suggestions please.
Many thanks.
  • Rucyj35 wrote:
    Yes, that's what I thought.  However, although it was set to sync and GMT, the time was well out. I assumed it was syncing to an American server, so I disabled it and entered the time manually.
    You can configure 0.pool.ntp.org and 1.pool.ntp.org.  That should give you a local server.
    Entering the time manually is generally good enough, but it needs to be re-done periodically because the internal clock will drift.  Also you need to recheck it after a power disruption.
  • StephenB's avatar
    The best strategy is to purchase two NAS-purposed drives (for ex. Seagate Ironwolf), end expand the RAID-1 array.  If you do this, don't purchase WD Reds - they are SMR (shingled magnetic recording).  WD Red Plus are ok.
    NTFS?  Or FAT32????
    Use the Windows Disk Manager to see if there is a second partition on the disk.  (The disk manager calls them "volumes").  If there is, then remove all the partitions using the disk manager.  Then reformat it as NTFS in Windows.
    • Rucyj35's avatar
      Rucyj35
      Excellent, thanks.  I now see the external drive, but it's just an external USB drive, and not being automatically added to the existing Volumes.  When I go into the settings wheel for the drive, I'm offered options to eject it, or format it: EXT 3/4, NTFS (which it already is), and BTRFS.
      What's my action here please?
      • Rucyj35's avatar
        Rucyj35
        Also I have found a log entry:  System: NTP is disabled
ProSupport for Business
