Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi with Readynas Duo
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-05
02:45 AM
2012-03-05
02:45 AM
i'm looking for a way to connect my ReadyNas Duo through Wifi instead of ethernet cable...
My problem is that i have three ReadyNas and only 2 free slots in my router... So i really need to use wifi with one of them
I came across this item:
http://www.newegg.ca/Product/Product.as ... 6833122373
I'm wondering if it would work with the Readynas. I picked this one because it is made by Netgear so there shouldnt be compatibility issues... Also, it is powered by USB so i wouldn't need an external power adapter
Thanks for help
Thanks for help
Message 1 of 36
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-05
02:55 AM
2012-03-05
02:55 AM
Re: Wifi with Readynas Duo
Don't get that. Get a switch e.g. the GS108T. Connect the switch to the router and plug the ReadyNAS units into the switch. Problem solved.
That way you can access all the NAS units via gigabit ethernet. If your router is not gigabit then you could connect your PCs to the switch as well (if they are connected via ethernet) to get gigabit speeds.
Message 2 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-05
03:42 AM
2012-03-05
03:42 AM
Totally agree. Getting an 8 port gigabit switch is about the same money and will increase your speeds (and is very easy to install). The WNCE2001 would be a horrible way to connect your NAS.
The GS108T is a managed switch, so it includes capabilities you don't really need (and is relatively expensive). I suggest a GS608 or possibly GS108e, which are in the same price range as the wifi adapter. You should avoid the GS108 (with no letter suffix), as it does not include 802.3x flow control (which is often needed when connecting the NAS to 100 mbit equipment, like media streamers).
BTW, you might also find you need to update your ethernet cables, as to get reliable gigabit ethernet you would need cat5e or cat6. The cable type should be printed on the cable, so this is not hard to check.
Message 3 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-06
03:35 AM
2012-03-06
03:35 AM
Thanks for infos. I almost bought this:
http://www.ncix.com/products/index.php? ... omoid=1009
but then i realised it doesnt even include wifi, wtf ?
Is it possible to get a switch supporting wifi n ?
Also, what are other major differences between a router and a switch ? I've never used a switch before.
Message 4 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-06
03:37 AM
2012-03-06
03:37 AM
A switch just provides ethernet. A router will do both ethernet and wireless. Also a router typically can be used as the device that assigns IP addresses.
Message 5 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-06
04:47 AM
2012-03-06
04:47 AM
Just to be clear, you use the switch with your router (it doesn't replace it). In addition to what mdgm said, a router also provides internet access and a firewall to protect your home network. A switch is the right way to expand your [wired] home network. If you also want to upgrade your wifi, then you would want to upgrade your router in addition to adding the switch.
The switch you referenced will solve your problem. You connect all your local ethernet connections to the new switch, and add one more cable between the router and the switch. (You leave the WAN connection on your router alone). Remember that you need cat5e or cat6 cable!
Then your ethernet speeds go up, and you have more connections. Your router continues to work, and you still can access everything over WiFi.
Message 6 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-06
04:58 AM
2012-03-06
04:58 AM
awww i thought i could replace my router with the switch... problem is that i dont have any free power outlet left in this room (and i am already using power surge protectors with 12 outlets)... I'd prefer to buy a switch with wifi, or a router with 5 ports or more, if possible
Thanks for help guys
Message 7 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-06
05:26 AM
2012-03-06
05:26 AM
Yikes. Hopefully you are not overloading your circuits.
anarchoi wrote: awww i thought i could replace my router with the switch... problem is that i dont have any free power outlet left in this room (and i am already using power surge protectors with 12 outlets)... I'd prefer to buy a switch with wifi, or a router with 5 ports or more, if possible
I don't know of any wifi+gigabit routers that have more than 4 ethernet ports, and you can't use a switch without a router.
You probably should have a UPS for the duo anyway, and that would have enough outlets to cover your router and the switch. so that would be one way around your outlet problem.
Message 8 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-06
05:59 AM
2012-03-06
05:59 AM
Is it really worth the money ? I never have electric failture here... My computer has been on 24/7 for years and never had any problem... All of my stuff is plugged in a Belkin surge protector, they guarantee up to $200,000 worth of equippement is something blow up.... should i still get an UPS ?
I don't really want to buy a switch if im still forced to use my router... Anyway the switch would be used only for one ReadyNas Duo, and i dont use it very often (damn i wish i could just plug it with USB)... That's why i wouldn't mind getting wireless connection and i dont care if i get slow speeds... If the NETGEAR WNCE2001 can work with the ReadyNas Duo i may buy it
Another off-topic question, is it normal that i am getting only 10mb/s write speed when i transfer files to any of my ReadyNas Ultra 4 Plus ? I'm using cat6 cables with a Belkin F5D8233-4 router
Message 9 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-06
09:22 AM
2012-03-06
09:22 AM
If you lose power unexpectedly you can corrupt the raid array and lose all your data. The surge protector will not prevent that, and the guarantee won't apply because the equipment will still be functioning. I decided it was certainly worth the money.
anarchoi wrote: Is it really worth the money ?
I guess you need to decide if you care about speed or not. Your post is sending a mixed message.
anarchoi wrote: ... is it normal that i am getting only 10mb/s write speed when i transfer files to any of my ReadyNas Ultra 4 Plus ? I'm using cat6 cables with a Belkin F5D8233-4 router
Do you have a Duo and an ultra 4 plus? If so, are you using the duo for primary storage or backup?
Anyway do you really mean 10 megabits, or do you mean 10 megabytes? Your router is only capable of about 10 megabytes (100 megabits). You should be getting more than 10 mb/s.
BTW, if you are really ok with 100 megabit links, you could replace your router with this: http://www.amazon.com/D-Link-DIR-632-Wi ... 039&sr=8-1 Newer gigabit wifi routers seem to have settled on 4 ports, but a few of the older 100 mbit models have more.
Message 10 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-06
12:33 PM
2012-03-06
12:33 PM
Sorry, let me give more details
First i bought a ReadyNad Duo and realised i couldn't use it with 3TB drives. So i bought a ReadyNas Ultra Plus and really liked it, so i bought another.
Those two ReadyNas Ultras are my primary stockage NAS. I care about the speed of my Ultras.
Now i'm left with another ReadyNad Duo i didn't know what to do with, so i'm using it to store old files. I really don't care about the speed of my ReadyNas Duo since it is almost read-only.
I meant that when i am transferring files from windows to NAS, windows tell me the speed is 10mb/s. This is really slow and i have same problem on all of my NAS.
Message 11 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-06
07:33 PM
2012-03-06
07:33 PM
Considering maybe getting an UPS, but i have a few questions :
- Is it dangerous to plug my UPS into my belkin surge protector ? usually it is not recommanded to plug an extension into a surge protector, is it the same thing with an UPS
- APC and UPS is the same thing or not ?
i'd use my apc with computer with 400w power supply and two ReadyNas Ultra Plus
What APC would you recommend me ?
This one looks interessing and is very popular on newegg:
http://www.newegg.ca/Product/Product.as ... 6842102082
Good choice ? Enough watts for all of my stuff ?
Message 12 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-06
07:39 PM
2012-03-06
07:39 PM
Windows reports speeds in megabytes per second (MB/s). This is 80 megabits per second (80 mb/s) which as fast as your Belkin router can go. It is not a gigabit router, and you need a gigabit network to see the speeds the Ultra is capable of.
anarchoi wrote: I meant that when i am transferring files from windows to NAS, windows tell me the speed is 10mb/s. This is really slow and i have same problem on all of my NAS.
One option is to replace your router with a Gigabit one - for instance the Netgear WNDR4500 or the Belkin F9K1103. I have the WNDR4500 and find it works very well.
Keeping your existing router and adding in the gigabit switch (finding a way to power it!) is a cheaper way to get the same performance boost with the ultras, and avoids the need to use WiFi with the Duo.
Got it, that explains things. The WNCE2001 should work with a new N router. Your current Belkin is pre-standard ("Draft N"), which might be a problem. Either way the Duo would probably drop below 10 MB/s, perhaps as low as to 4-6. If you go this route, you might as well get the WNCE3001, as street prices are about the same. The 3001 supports dual band (2.4 Ghz and 5 Ghz). Though personally I would go with the gigabit switch.
anarchoi wrote: ...Now i'm left with another ReadyNas Duo i didn't know what to do with, so i'm using it to store old files. I really don't care about the speed of my ReadyNas Duo since it is almost read-only.
APC is a brand of UPS, your link is a Cyberpower. I have two somewhat larger units (http://www.newegg.ca/Product/Product.as ... 6842102070). I plug them into the wall, not the surge protector. Though I don't think you will do any damage by plugging it into the surge. (You can plug the surge protector into one of the switched outlets of the UPS too).
anarchoi wrote: Considering maybe getting an UPS, but i have a few questions :
Connecting your PC and 3 NASes to a single UPS means the UPS won't run very long. Though you are mostly wanting to have it run long enough to get a clean shutdown. The UPS can only be monitored directly by one computer (or NAS) over a USB port. The ReadyNAS can also get the status over the network, but if you do that you also need to connect your router (and switch if you get one) to the UPS as well. There is a software package that can also let the PC monitor the UPS from the ReadyNAS, you might search for it.
Message 13 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-06
07:41 PM
2012-03-06
07:41 PM
You should buy a UPS with surge protection and not plug it into a surge protector.
APC is one brand of UPS available. They are other brands such as CyberPower.
Have a look at the watts your devices use. You should not load the UPS with more than 80% load. If you put too heavy a load (over 80%) on the UPS the battery will drain too quickly in the event of a power failure shortening it's life.
Message 14 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-06
08:00 PM
2012-03-06
08:00 PM
Keep in mind that your devices use less than their power supply spec. These UPS units have an LCD panel which can tell you how much power is actually being used.
mdgm wrote: Have a look at the watts your devices use. You should not load the UPS with more than 80% load. If you put too heavy a load (over 80%) on the UPS the battery will drain too quickly in the event of a power failure shortening it's life.
I would get the somewhat larger unit (the 1350). If there is too much draw either drop the PC for now or buy a second unit just for it.
Message 15 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-06
09:18 PM
2012-03-06
09:18 PM
This forum is so useful ! You are answering questions i've had for months !
Oh i didn't know that, and i thought my router was gigabit, damn !
If i buy a switch, would i also need to upgrade my router to get gigabit speed between my computer and my NAS ?
Could i still stream divx movies with those speeds or would it be a problem ?
Ok i get it now...
So let's say i only plug my two ReadyNas Ultra4 into the UPS... How long do you think the battery would last ?
Also, is there a way ReadyNas can detect the UPS is running on battery, so it could automatically clean-shutdown ? If i'm sleeping during a power shortage i will be unable to clean-shutdown my NAS !
Definatly gonna buy an UPS tonight or tomorrow... Just need to decide between CP1000AVRLCD or CP1000AVRLCD ... price difference isn't huge, i might as well buy the best one...
Just wondering, how much watts does an Ultra4 consume ?
Ok i get it now...
Message 16 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-06
10:49 PM
2012-03-06
10:49 PM
Ok i finally decided to buy the CP1350AVRLCD from newegg... One problem solved !
Been looking for a solution to the other problem and i came across this:
http://www.newegg.ca/Product/Product.as ... 6833122446
newegg lists it as a "firewall" and netgear says it is a router :
http://www.netgear.fr/images/FVS318N_fr65-36060.pdf
Can i use it as a router and just replace my belkin with it ? I don't even know the difference between a normal router and hardware firewall 😕
Message 17 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-07
04:03 AM
2012-03-07
04:03 AM
The FVS318N is a business router with gigabit ethernet and 802.11n (the only one I found when I went looking for 8 ports). There are a couple of older versions (FVS318, FVS318G) that you wouldn't want.
anarchoi wrote: Ok i finally decided to buy the CP1350AVRLCD from newegg... One problem solved !
Since it is a business router, it has lots of features you wouldn't need, making it more confusing to setup/configure than an normal home router. Also, it did not score very well in the smallnetbuilder review (http://www.smallnetbuilder.com/security ... l-reviewed). A high end home router (including both the Netgear WNDR4500 or the Belkin F9K1103) have about 2x the WiFi speeds of the FVS318N.
However, you certainly could replace your Belkin with it, which would be one way to solve your power limitation. Though the UPS will give you more outlets (4 surge protected, 4 more with surge+battery backup), so maybe that is no longer so critical.
No. You connect your computer and NAS devices to the switch, and then connect the switch to your existing Belkin. All your home wired devices will get gigabit speeds (the router is needed to set up the connection but all the local wired traffic stays on the switch, and never goes to the router). The link between the router and the switch is not gigabit, but is faster than your internet service and your wifi. If later on you want 5 Ghz wifi, you can upgrade your router to a new dual-band version then.
anarchoi wrote: If i buy a switch, would i also need to upgrade my router to get gigabit speed between my computer and my NAS ?
You should be able to stream SD content and some HD content, though likely you would have problems if you were trying to use the Duo for something else at the same time.
anarchoi wrote: Could i still stream divx movies with those speeds or would it be a problem ?
The Ultra4 typically uses 52 watts, so you'd have a load around 105 watts if the disks were spinning. If you add in a little more for the router and switch (which you need to do if you want to share the UPS with 2 NAS) you'd have maybe 130 watts. I believe this will get you about 40 minutes of protection with the 1350 - enough for short outages, and certainly long enough for a clean shutdown.
anarchoi wrote: So let's say i only plug my two ReadyNas Ultra4 into the UPS... How long do you think the battery would last ?
Yes. You plug the USB cable into the back port of one of the Ultras. You can then set up the second Ultra to get the status over ethernet. Of course you then need to make sure that ethernet is working when the power fails. (hence plugging in the switch and router to the UPS as well). I manually set the shutdown on the second NAS to be quicker than the default, because I want to make sure the network doesn't go down first. (There is a UPS configuration menu in Frontview under system->power).
anarchoi wrote: Also, is there a way ReadyNas can detect the UPS is running on battery, so it could automatically clean-shutdown ? If i'm sleeping during a power shortage i will be unable to clean-shutdown my NAS !
Some UPS models aren't detected/monitored properly by the ReadyNAS, however the CP1350AVRLCD works with my Pro 6 and my Duo/NV+.
Message 18 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-07
06:40 AM
2012-03-07
06:40 AM
Thank you very much for your time ! I think it answers all my question
So i'll either buy the FVS318N-100NAS router or the GS108E-100NAS switch... I'll probably buy but i'll wait until tomorrow to think about it. There's an huge price difference, but all my power outlets are overloaded here so i dont want to add another thing...
It took me 3 days to transfer the files to my NAS when i bought it so i'm really glad i'll get gigabit speeds! hehe
Good to know that the UPS is detected by Raidair, that was my last question !
Message 19 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-07
09:34 AM
2012-03-07
09:34 AM
Last question i promise !
i'm about to buy that belkin router. Only thing i'm concerned about is the wireless standard, like you pointed out.
I made some researshes on "draft n" wifi but i'm confused... From what i understand it is a standard that was released early. Some says you can upgrade firmware and get full speed with latest "n" standard, but others says you can't
Also, you said earlier that this class of router usually have a wireless standard twice faster... what's this standard you were talking about ? is it really worth the difference ? (i'm probably sure all wifi devices in my home are only wifi N but future-proofing is always a plus)
Thanks again!
Thanks again!
Message 20 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-07
11:04 AM
2012-03-07
11:04 AM
The IEEE is responsible for 802.xx standards, but had trouble locking down 802.11n. Eventually the WiFi alliance decided to stop waiting, and started certifying "draft N" routers. Upgrade paths to the full standard would be the responsibility of the supplier, I am not sure what Belkin did for your current model. Though that is a past issue, 802.11n is fully standardized now.
anarchoi wrote: i'm about to buy that belkin router. Only thing i'm concerned about is the wireless standard, like you pointed out.
The newer one I suggested is current, so it should meet the spec. Note I don't own it, so I am only pointing that it has quite good test results. It also appears to be reasonably priced. Test results are here: http://www.smallnetbuilder.com/wireless ... r-reviewed 5 Ghz was not a strong point for the Belkin, so that is something to keep in mind.
The 2x difference is what is shown on the performance tests with 802.11n. If you look at 2.4 Ghz downlink speed on routers built by mainstream companies, you will find that the test results range between 20 mb/s and 50 mb/s (again this is based on smallnetbuilder testing). The FVS318N came in at 31.2. Whether this is worth the money depends on what you use WiFi for.
anarchoi wrote: Also, you said earlier that this class of router usually have a wireless standard twice faster... what's this standard you were talking about ? is it really worth the difference ?
Message 21 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-07
11:30 AM
2012-03-07
11:30 AM
damn i'm stupid, i meant i was about to buy the netgear router not the belkin one, sorry, i don't know why i wrote belkin, need some sleep i think.
i want to buy this one:
http://www.directcanada.com/products/?s ... re=NETGEAR
earlier you said "draft n" wifi might be a problem, thats why i was asking the question since the 8-port netgear router is also "draft n"
for example this article is saying we shouldnt buy "draft n", but it's old...
http://wifinetnews.com/archives/006507.html
Message 22 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-07
01:15 PM
2012-03-07
01:15 PM
I don't know why the directcanada site says it is "draft n" - that has to be incorrect, no router introduced in Q4 2011 would be draft n. 802.11n was completed in October 2009.
anarchoi wrote: damn i'm stupid, i meant i was about to buy the netgear router not the belkin one, sorry, i don't know why i wrote belkin, need some sleep i think.
Message 23 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-07
07:12 PM
2012-03-07
07:12 PM
Ok, maybe that's why it isn't listed as "draft n" at newegg.
Just bought the router from DirectCanada... Guess all my problems are solved now. Thanks again 🙂
Message 24 of 36
- Mark as New
- Bookmark
- Subscribe
- Permalink
2012-03-08
06:38 AM
2012-03-08
06:38 AM
i suppose those yellow ethernet cables that came with my ReadyNas aren't cat5 or cat6 ?
Message 25 of 36
