Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
kernel panic
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-22
05:27 AM
2011-12-22
05:27 AM
kernel panic
hi,
i have a ReadyNAS NV+
i use 4 HDD, X-Raid(HDD:WD1002FBYS * 4)
have a day,my UPS is fault ,cause ReadyNAS NV+ shutdown
i repaired UPS, start ReadyNAS NV+,but always remain in [booting....]
i turn off it
pull out HDD 1,than start it ,
but it say [found a bad disk 1]
i test HDD 1,it is good
i into HDD 1,always remain [found a bad disk 1]
OK,i don't need all data,i want Reset it
i turn it off,pressure reset,open,more than 30 seconds, open
it say [Factory Default Please wait...],but has more than 24 hours :cry: :cry: :cry: :cry:
i try pressure reset 5 seconds,reinstall, invalid,always remain [installing FW...]
i try No HDD,it can run to [err: No disk]
sometime boot finish opportunity to [ kernel panic]
RAIDar------4.3.3
RAIDiator---4.1.8
please help me.........
i turn off it
RAIDar------4.3.3
RAIDiator---4.1.8
Message 1 of 6
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-22
05:53 AM
2011-12-22
05:53 AM
Re: kernel panic
You may wish to run the memory test (http://www.readynas.com/kb/faq/hardware/is_there_a_way_i_can_verify_if_my_memory_is_good)
Please also power down the NAS, remove disks (label order), connect to SATA port on PC and check using vendor tools
It's possible you have one or more bad disks.
Message 2 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-22
06:28 AM
2011-12-22
06:28 AM
Re: kernel panic
OK,thanks.
but
where can i download RAIDiator 3.01??
but
Message 3 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-22
07:25 AM
2011-12-22
07:25 AM
Re: kernel panic
i find RAIDiator-3.01c1-p6 in my pc.
but how can i do upload to NV+ run test??
Message 4 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-22
09:01 AM
2011-12-22
09:01 AM
Re: kernel panic
Why would you want to install such an old obsolete version of RAIDitor? That is the version that was replaced in Feb. 2008. There have been a lot of improvements and enhancements since then, including the support for larger drives, larger volumes and larger block size. Using versions prior to 4.00 you would be limited to 2TB volumes (effectively limiting you to the space afforded by 750GB drives, even if you had 1TB drives installed).
The notes to version 4.00 points to the fact that once you have upgraded to that point, you cannot go back to a prior version (3.x) without performing a factory default which will wipe out all data on your drives.
Message 5 of 6
- Mark as New
- Bookmark
- Subscribe
- Permalink
2011-12-22
05:37 PM
2011-12-22
05:37 PM
Re: kernel panic
ok........
I also found the new version of the test memory function.
i use it,memory test is good.
HDD,I replaced the previously used,only one disk,still there [ERR: No disks]
what can i do now ??
Message 6 of 6
