- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
no disks - help
- Mark as New
- Bookmark
- Subscribe
- Permalink
no disks - help
4.5 year old pro 6. Last night it said "system dead" but was still running. The side enclosure fan had completely stopped. I shut down and restarted but it was still off so I shutdown and went to bed. When I got up in the morning it still said shutting down on it. So I held the power button and shut it off. When I got home tonight I powered it on again and the fan started, but the display showed retrying startup for a while and then it showed the readynas 6.4.2 but no disk numbers. My fear is that they overheated. I cannot ssh in. Raidar shows both ports with different IP's instead of one bonded. So I think the system lost it's config somehow. Before I try anything what do you recommend? I have good backups fortunately :-).
steve
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: no disks - help
I'd power down the NAS and test the disks in a pc with vendor diags (seatools for seagate, lifeguard for western digital). If you want to avoid a reset, then label them by slot before removing.
But doing a factory reset might be the fastest way in the end, as there are no delays waiting for advice.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: no disks - help
One thing I forgot to mention that is very strange is I powered down the unit this morning by holding down the power button, when I came home tonight it was on. No one was in the house. The fan was on when I got home and found it in this state though. So I don't know why it came on. I don't remember enabling one of those power on schedules. Maybe the default firmware has wake on lan or something?
Anyhow, I still fear the unit ran overnight with the fan off. The drives are warm at the moment. I pulled the plug and will let it completely cool and then try the unit again. If that still gets nothing I'll start testing the drives. I see no numbers in the little squares so doesn't that mean the drives are not showing as present?
steve
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: no disks - help
I took the drives out for an hour and let them lay on the cool table in front of the nas (my basement stays cool year round). Put them back in and it came up. Everything is back. Happy, but very disconcerting.
Fan is running, but since I've got a fan problem I guess I have some questions.
1. Shouldn't the nas shut itself down if the fan fails? Is there a log I can check to see if that happened or why it failed?
2. When I put the power cord in the unit came up. Apparently something is set to power on automatically. Can I change that? If the thing goes down because of the fan I want it to stay down.
3. There is a note about moving the fan control to the IO card port. Should I do that? Why?
thanks
steve
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: no disks - help
Any comments on my 3 questions?
I'm thinking of replacing the fan and moving connector to the IO card. This should eliminate most of the possibilities for the cause of the issue.
steve
- Mark as New
- Bookmark
- Subscribe
- Permalink
