klausn
Jan 26, 2017Tutor
Antivirus scanner how to manage after upgrading to 6.6.1
Hi,
Does anyone know what the next problem is?
After upgrading to Firmware 6.6.1 I can't manage the Antivirus scanner.
Before upgrading I could change the frequences of updating the Antivirus scanner.
Does anyone have an idea?
Please be kind and share with me.
Remarks: the antivirus program is still runnig on background and the led on the main screen (Admin Page) is green!
Hi great you give me the link...... many txs
The way to use the built in anti vrus is for me a bit blury and hard to understand too!
For me I turned it on, then the unit downloaded the app, then it updated the virus files and then it went green and a shield appeared on the unit.
For right now the only controls are "on" and "off".
I think that's a huge problem, hopefully there will be more options soon.
- klausnTutor
Hi,
I read a lot and could not find anything about it.
The programm is still running and updating, but managing or seen in my App isn't possible.
The Antivisus App is disappeared............
:smileysurprised:
- Retired_Member
Any updates on the 6.6.1 firmware and AV issues?
Retired_Member there is the 6.7.0 beta available but no public yet!
- FramerVNETGEAR Employee Retired
Hi pmjc,
Here is the link for the BETA firmware in case you want to check the release notes.
ReadyNASOS 6.7.0-T169 (Beta 2)
