Retired_Member's avatar
Retired_Member
Jun 27, 2013
Disk mount x86 in Linux LVM HELP
So I have a readynas ultra 2 with 2 TB drives that got that whole "Missing shares error" thing.
So I thought that I would take one of the drives, mount it in linux (ive done this b4), and reset the other drive to copy the data.
But it looks like the data partition is missing the superblock and wont mount correctly.
Any ideas? Or a way to force mount the data partition just to copy the data?
knoppix@Microknoppix:~$ sudo su
root@Microknoppix:/home/knoppix# apt-get install mdadm lvm2
Reading package lists... Done
Building dependency tree
Reading state information... Done
lvm2 is already the newest version.
mdadm is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 551 not upgraded.
root@Microknoppix:/home/knoppix# mdadm --assemble --scan
mdadm: /dev/md/1 has been started with 1 drive (out of 2).
mdadm: /dev/md/0 has been started with 1 drive (out of 2).
root@Microknoppix:/home/knoppix# modprobe dm-mod
root@Microknoppix:/home/knoppix# vgscan
Reading all physical volumes. This may take a while...
No volume groups found
root@Microknoppix:/home/knoppix# cat /proc/mdstat
Personalities : [raid1]
md0 : active raid1 sdc1[2]
4193268 blocks super 1.2 [2/1] [U_]
md1 : active raid1 sdc2[2]
524276 blocks super 1.2 [2/1] [U_]
unused devices: <none>
root@Microknoppix:/home/knoppix# mdadm -v --assemble --auto=yes /dev/md2 /dev/sdc3
mdadm: looking for devices for /dev/md2
mdadm: no recogniseable superblock on /dev/sdc3
mdadm: /dev/sdc3 has no superblock - assembly aborted
root@Microknoppix:/home/knoppix# dumpe2fs /dev/md0 | grep -i superblock
dumpe2fs 1.42.4 (12-Jun-2012)
Primary superblock at 0, Group descriptors at 1-1
Backup superblock at 32768, Group descriptors at 32769-32769
Backup superblock at 98304, Group descriptors at 98305-98305
Backup superblock at 163840, Group descriptors at 163841-163841
Backup superblock at 229376, Group descriptors at 229377-229377
Backup superblock at 294912, Group descriptors at 294913-294913
Backup superblock at 819200, Group descriptors at 819201-819201
Backup superblock at 884736, Group descriptors at 884737-884737
  • Retired_Member's avatar
    Retired_Member
    Bump
    Any recommendations for a Linux forum I could get help from?
  • siigna's avatar
    siigna
    NETGEAR Employee Retired
    Looks like you're indeed missing the superblock on that disk. I'll imagine it'll output about the same as your assemble command, but what do you get from 'mdadm -E /dev/sdc3' ?
    You can force a recreation of the superblock, but I wouldn't do this unless you're absolutely sure of what you're doing. You'll need to get the array itself as well as the logical volume up before you can mount the filesystem.
    You can mount /dev/md0 as a regular ext2/3 filesystem (because that's what it is) and you should be able to pull the RAID configuration logs out of /var/log/frontview. If you can post the latest "raid_config_*.log" that contains md2 that would be helpful.
    Retired_Member
    Please ignore the mount device name. These were during different logins. sda, sdb, and sdc from the first post are all the first drive from the array.
    mdadm -E output for all partitions:
    root@Microknoppix:/home/knoppix# mdadm -E /dev/sdb
    /dev/sdb:
    MBR Magic : aa55
    Partition[0] : 3907029167 sectors at 1 (type ee)
    root@Microknoppix:/home/knoppix# mdadm -E /dev/sdb3
    mdadm: No md superblock detected on /dev/sdb3.
    root@Microknoppix:/home/knoppix# mdadm -E /dev/sdb1
    /dev/sdb1:
    Magic : a92b4efc
    Version : 1.2
    Feature Map : 0x0
    Array UUID : 494a7e99:7972ebcc:9b4a1bd1:d55a1de3
    Creation Time : Thu Sep 8 16:33:41 2011
    Raid Level : raid1
    Raid Devices : 2
    Avail Dev Size : 8386560 (4.00 GiB 4.29 GB)
    Array Size : 4193268 (4.00 GiB 4.29 GB)
    Used Dev Size : 8386536 (4.00 GiB 4.29 GB)
    Data Offset : 2048 sectors
    Super Offset : 8 sectors
    State : clean
    Device UUID : 57b9a1e6:9daba6b6:7246f828:f2af845a
    Update Time : Tue Jul 2 01:31:50 2013
    Checksum : 2bcb3495 - correct
    Events : 476276
    Device Role : Active device 0
    Array State : A. ('A' == active, '.' == missing)
    root@Microknoppix:/home/knoppix# mdadm -E /dev/sdb2
    /dev/sdb2:
    Magic : a92b4efc
    Version : 1.2
    Feature Map : 0x0
    Array UUID : 16b0093f:e9ce8e55:6f550c64:9f57fbf3
    Creation Time : Thu Sep 8 16:33:42 2011
    Raid Level : raid1
    Raid Devices : 2
    Avail Dev Size : 1048552 (512.07 MiB 536.86 MB)
    Array Size : 524276 (512.07 MiB 536.86 MB)
    Data Offset : 24 sectors
    State : clean
    Device UUID : cdbaf0c1:7d3f99a3:37786b19:3f1e936a
    Update Time : Thu Jun 27 21:49:16 2013
    Checksum : c59f7e50 - correct
    Events : 255
    Important:
    gdisk output:
    root@ubuntu:/home/ubuntu# gdisk
    GPT fdisk (gdisk) version 0.8.1
    Type device filename, or press <Enter> to exit: /dev/sda
    Partition table scan:
    MBR: protective
    BSD: not present
    APM: not present
    GPT: present
    Found valid GPT with protective MBR; using GPT.
    Command (? for help): p
    Disk /dev/sda: 3907029168 sectors, 1.8 TiB
    Logical sector size: 512 bytes
    Disk identifier (GUID): D2AD91F6-ED10-451B-8466-36F3A01BFE2D
    Partition table holds up to 128 entries
    First usable sector is 34, last usable sector is 3907029134
    Partitions will be aligned on 64-sector boundaries
    Total free space is 4092 sectors (2.0 MiB)
    Number Start (sector) End (sector) Size Code Name
    1 64 8388671 4.0 GiB FD00
    2 8388672 9437247 512.0 MiB FD00
    3 9437248 3907025072 1.8 TiB FD00
    Command (? for help): i
    Partition number (1-3): 1
    Partition GUID code: A19D880F-05FC-4D3B-A006-743F0F84911E (Linux RAID)
    Partition unique GUID: 29CFC302-D112-423D-BA26-B50B9F733F25
    First sector: 64 (at 32.0 KiB)
    Last sector: 8388671 (at 4.0 GiB)
    Partition size: 8388608 sectors (4.0 GiB)
    Attribute flags: 0000000000000000
    Partition name: ''
    Partition number (1-3): 2
    Partition unique GUID: B3B52523-2065-46AC-8D71-C802C2FBD618
    First sector: 8388672 (at 4.0 GiB)
    Last sector: 9437247 (at 4.5 GiB)
    Partition size: 1048576 sectors (512.0 MiB)
    Partition name: ''
    Partition number (1-3): 3
    Partition unique GUID: 08A311D3-C961-4449-9CB1-B0BD32D9B39D
    First sector: 9437248 (at 4.5 GiB)
    Last sector: 3907025072 (at 1.8 TiB)
    Partition size: 3897587825 sectors (1.8 TiB)
    Partition name: ''
    Ill get the logs when i can.
    As far as I can tell, I had power loss during a resync of the drives, so now I have a bad sector and the second drive is stuck as a spare.
    Retired_Member
    Last good configuration:
    ***** RAID configuration log from 2013/05/26 *****
    ***** mdadm -D --scan -v *****
    ARRAY /dev/md/0 level=raid1 num-devices=2 metadata=1.2 name=E091F58AD8E4:0 UUID=494a7e99:7972ebcc:9b4a1bd1:d55a1de3
    devices=/dev/sda1,/dev/sdb1
    ARRAY /dev/md/1 level=raid1 num-devices=2 metadata=1.2 name=E091F58AD8E4:1 UUID=16b0093f:e9ce8e55:6f550c64:9f57fbf3
    devices=/dev/sda2,/dev/sdb2
    ARRAY /dev/md/2 level=raid5 num-devices=2 metadata=1.2 name=E091F58AD8E4:2 UUID=1c784278:8cb4a7bc:b66b10e9:3c012e64
    devices=/dev/sda3,/dev/sdb3
    ***** mdadm -D --scan -vv *****
    /dev/md/0:
    Version : 1.2
    Creation Time : Thu Sep 8 12:33:41 2011
    Raid Level : raid1
    Used Dev Size : 4193268 (4.00 GiB 4.29 GB)
    Raid Devices : 2
    Total Devices : 2
    Persistence : Superblock is persistent
    Update Time : Sun May 26 06:47:01 2013
    State : clean
    Active Devices : 2
    Working Devices : 2
    Failed Devices : 0
    Spare Devices : 0
    Events : 369632
    Number Major Minor RaidDevice State
    2 8 1 0 active sync /dev/sda1
    1 8 17 1 active sync /dev/sdb1
    /dev/md/1:
    Version : 1.2
    Creation Time : Thu Sep 8 12:33:42 2011
    Raid Level : raid1
    Used Dev Size : 524276 (512.07 MiB 536.86 MB)
    Raid Devices : 2
    Total Devices : 2
    State : clean
    Active Devices : 2
    Working Devices : 2
    Failed Devices : 0
    Spare Devices : 0
    Events : 213
    2 8 2 0 active sync /dev/sda2
    1 8 18 1 active sync /dev/sdb2
    /dev/md/2:
    Version : 1.2
    Raid Level : raid5
    Array Size : 1948792704 (1858.51 GiB 1995.56 GB)
    Used Dev Size : 1948792704 (1858.51 GiB 1995.56 GB)
    Raid Devices : 2
    Total Devices : 2
    State : clean
    Active Devices : 2
    Working Devices : 2
    Failed Devices : 0
    Spare Devices : 0
    Layout : left-symmetric
    Chunk Size : 64K
    UUID : 1c784278:8cb4a7bc:b66b10e9:3c012e64
    Events : 5399
    0 8 3 0 active sync /dev/sda3
    1 8 19 1 active sync /dev/sdb3
    ***** mdconfig *****
    Device : /dev/md0
    Create Time : 1315499621
    Update Time : 1369565221
    RAID Level : 1
    RAID Capacity : 4193268
    Disk Size : 4193268
    Chunk Size : 0
    Disks : 2
    RAID Disks : 2
    Active Disks : 2
    Working Disks : 2
    Failed Disks : 0
    Spare Disks : 0
    State : 1 [ Clean ]
    Disk Device RAID Disk Maj/Min Sectors State
    1 /dev/sdb1 1 8/17 8388608 6 [ Active Sync ]
    2 /dev/sda1 0 8/ 1 8388608 6 [ Active Sync ]
    Device : /dev/md1
    Create Time : 1315499622
    RAID Level : 1
    RAID Capacity : 524276
    Disk Size : 524276
    Chunk Size : 0
    Disks : 2
    RAID Disks : 2
    Active Disks : 2
    Working Disks : 2
    Failed Disks : 0
    Spare Disks : 0
    State : 1 [ Clean ]
    1 /dev/sdb2 1 8/18 1048576 6 [ Active Sync ]
    2 /dev/sda2 0 8/ 2 1048576 6 [ Active Sync ]
    Device : /dev/md2
    RAID Level : 5
    RAID Capacity : 1948792704
    Disk Size : 1948792704
    Chunk Size : 65536
    Disks : 2
    RAID Disks : 2
    Active Disks : 2
    Working Disks : 2
    Failed Disks : 0
    Spare Disks : 0
    State : 1 [ Clean ]
    0 /dev/sda3 0 8/ 3 3897587825 6 [ Active Sync ]
    1 /dev/sdb3 1 8/19 3897587825 6 [ Active Sync ]
    After failure:
    ***** RAID configuration log from 2013/06/02 *****
    /dev/md/0:
    Version : 1.2
    Raid Level : raid1
    Raid Devices : 2
    Total Devices : 2
    Update Time : Sun Jun 2 06:47:01 2013
    State : clean, degraded
    Active Devices : 1
    Working Devices : 1
    Failed Devices : 1
    Spare Devices : 0
    Events : 369975
    1 0 0 1 removed
    1 8 17 - faulty spare /dev/sdb1
    /dev/md/1:
    Version : 1.2
    Raid Level : raid1
    Raid Devices : 2
    Total Devices : 2
    Update Time : Sun Jun 2 06:47:02 2013
    Active Devices : 1
    Working Devices : 1
    Failed Devices : 1
    Spare Devices : 0
    Events : 216
    1 0 0 1 removed
    1 8 18 - faulty spare /dev/sdb2
    /dev/md/2:
    Version : 1.2
    Raid Level : raid5
    Raid Devices : 2
    Total Devices : 2
    Active Devices : 1
    Working Devices : 1
    Failed Devices : 1
    Spare Devices : 0
    Chunk Size : 64K
    Events : 5402
    1 0 0 1 removed
    1 8 19 - faulty spare /dev/sdb3
    Device : /dev/md0
    Update Time : 1370170022
    RAID Level : 1
    Disk Size : 4193268
    Chunk Size : 0
    Disks : 2
    RAID Disks : 2
    Active Disks : 1
    Working Disks : 1
    Failed Disks : 1
    Spare Disks : 0
    State : 1 [ Clean ]
    1 /dev/sdb1 -1 8/17 8388608 1 [ Faulty ]
    Device : /dev/md1
    RAID Level : 1
    Disk Size : 524276
    Chunk Size : 0
    Disks : 2
    RAID Disks : 2
    Active Disks : 1
    Working Disks : 1
    Failed Disks : 1
    Spare Disks : 0
    State : 1 [ Clean ]
    1 /dev/sdb2 -1 8/18 1048576 1 [ Faulty ]
    Device : /dev/md2
    RAID Level : 5
    Chunk Size : 65536
    Disks : 2
    RAID Disks : 2
    Active Disks : 1
    Working Disks : 1
    Failed Disks : 1
    Spare Disks : 0
    State : 1 [ Clean ]
    1 /dev/sdb3 -1 8/19 3897587825 1 [ Faulty ]
    Im beginning to think the LVM is the problem not the superblock. How do you recover LVM partition data?
ProSupport for Business
