- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New NV+ power supply - ok to cut off non-essential peripheral connecting wires?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Last night I completed the replacement of my old NV+ V1 power supply (RND4PSU1-10000S) with a new one. The installation went fine and my NV+ is back up and running again.
The only thing I didn't like about the new power supply is the presence of several connecting wires for accessories that are not on the NV+, such as 3 SATA, 2 Molex and 1 FDD. These are bundled separately from the main NV+ connector/wires and are not used at all. I had to use a great amount of ingenuity with plastic ties to bind these unused connections and cram them into the new power supply's fan compartment without reducing the air flow much.
After I had the new power supply installed and working, I thought that maybe I could snip off those unused wires where they exit the power supply housing. This would eliminate an airflow restriction to the new power supply's fan and increase airflow to the power supply's internal components quite a bit. Since these 6 unused connectors are not attached to anything in my NV+, I don't see any problem with cutting them. Of course with my luck, it'll turn into a catastrophy and ruin my new $124 power supply.
Has anyone bought a 3rd party NV+ power supply from eBay, etc. then cut off the extraneous wires? I really don't want to take apart the new power supply to unplug the wires (if they can be unplugged at all) when one snip will do the trick.
Thanks.
Mike
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
* is am giving this info without receiving any money in return, so I can't guarantee that this hack won't be detrimental to your PS, nor void your warranty. It's best to contact Overtek_Ltd in Great Britain to see what your options are.
Michael
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: New NV+ power supply - ok to cut off non-essential peripheral connecting wires?
Hi ScuseMe1,
Haven't used a 3rd party PSU from Ebay or other resellers and I won't recommend cutting out its unnecessary wires. Let's hear from other community members maybe they have used one.
Kind regards,
BrianL
NETGEAR Community
- Mark as New
- Bookmark
- Subscribe
- Permalink
Michael
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ScuseMe1 wrote:
I contacted Jon today over at. where they make the power supply. He said it's ok to cut off the extraneous leads. Just remember not to short out like colors, which may damage the PSU. ...
Don't leave any bare wire exposed. A little heat-shrink tubing will work nicely. Or use electrical tape or wire nuts.
- Mark as New
- Bookmark
- Subscribe
- Permalink
