- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RN214 hangs at 99% booting after update to 6.7.4 (upnphttpd, rddclient failed, dba import failed)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Every once in awhile my Readynas would just shut down. Today I logged in and it said there was a new firmware avialable. I said upgrade but now it will not boot up. It give the following error on the RAIDar - Model X7sB3 Status TFTP_REQ. Firmware 6.7.4
I created a boot USB with the 6.7.4 firmware on the USB but I want to make sure that I do this correctly as I do not want to have it destroy my data.
The readme file says to place the USB stick in the front USB slot and using a paper clip hold the reset button down for 15 seconds while pressing the power button. Howerver the manual say I need to enter the Boot Menu first and the only option it shows is how to boot and reinstall the OS from the internal flash drive on the NAS. I want to make sure I do this correclty as I dont want it to format all of my data and do a factory reset or something awful.
What is the proper procedure to install the latest firmware 6.7.4 on a Readynas 3200 unit.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RN214 hangs at 99% booting after update to 6.7.4 (upnphttpd, rddclient failed, dba import failed
For RN214:
No, the "Reset" button is used to access the Boot Menu, not the USB Boot Recovery.
The USB Boot Recovery uses the Backup button: https://kb.netgear.com/29952/How-do-I-use-the-USB-Recovery-Tool-on-my-ReadyNAS-OS-6-storage-system
- Mark as New
- Bookmark
- Subscribe
- Permalink
Do you have external USB devices connected to your NAS? Does it boot up fine with those disconnected?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not sure what happened but I rebooted off a recovery USB drive and it is now fine.
