× NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. For more details click here.
Orbi WiFi 7 RBE973
Reply
Ultra 6 visible, but not reachable
bartw
Hi,
I have a Ultra6 with 3 x 4TB in it.
The system gave an error (disk error, volume unrpotected) and after a reboot resynced.
But now I cannot access it anymore.
It is visible on the network (using RAIDAR), but I cannot mount the volumes, cannot connect to Frontview.
Unfortunately, apparently I did not active ssh on this device, so not ssh to log into the unit.
I've done a OS Reinstall, but that did not help either.
What are my options ?
TIA,
Bart
Message 1 of 3
Guru
Re: Ultra 6 visible, but not reachable
If you are the original purchaser, then one option is to contact support.netgear.com and arrange for per-incident support.
If you have a current backup, you could of course do a factory reset and rebuilt the NAS (restoring data from backup).
Message 2 of 3
Sandshark
Sensei
What is the status shown in RAIDar?  I have seen a bad drive prevent the volume from mounting.  If you know for sure which drive was reported as bad, try booting without it.  But be warned, if you remove the wrong drive and boot, there is a possibility your volume will be forever lost (assuming it's not already, which is a likely assumtion unless you somehow lost a second drive during all this).
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2026 views
  • 0 kudos
  • 3 in conversation
Announcements
