Hwayoung
Jul 04, 2018Initiate
How to open ports on SRX5308
Hi,
I was recently requested to open 3 ports for CCTVs. So I said YES with confidence as I expericed for a Synology NAS.
First, I created a serivce, and added it to inbound/outbound rules as before. After I completed the adding the ports, I tested it through Open Port Check Tool to see if the ports are open. And I found out they're still closed. I checked the port settings over and over again but I just did the same but not working unlike the NAS.
I still think there's nothing wrong with the firewall configurations. And I'm just wonderking that if the CCTV devices are not using the specific ports or something wrong, does the port checking tool recognize that it's closed?
In short, without connecting the device that I will use, can I open the port in firewall configuraion, and can the port checking tool know if it's open?
Hi Hwayoung,
Welcome to the community! :)
Kindly answer the questions below:
a. Is the SRX5308 set as the main router wherein the Public WAN IP address is registered to it?
b. Do you have access to the settings CCTV cameras to double check if it is using the port numbers you have opened on the SRX5308?
c. How is everything connected? Are the CCTV cameras directly connected tot he SRX5308? It would be best if you post an image or screenshot of your detailed network setup.
Let me share the link below as reference guide:
DaneA
NETGEAR Community Team
- DaneANETGEAR Employee Retired
Hi Hwayoung,
DaneA
I just want to follow-up on this. We’d greatly appreciate your feedback.
DaneA
- HwayoungInitiate
Dear DaneA,
I really appreciate your help.
I found myself what was blocking opening ports. I used to use 192.168.1.18 / 8112 ports.
And CCTV service provider told me they needed to change its IP address to 192.168.1.80. So I added the same rule, but I did not remove the old rules. So I think this might confilct opening port.
I have resolved this issue by removing the old rule, and now everything is okay.
I really appreciate your rapid feedback.
