× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
AC750 WiF Range Extender won't take password after power failure
MarquesAlan
Follower
We have power failures once and a while. I have my router and modem on a battery back up but there is no way to do that for the extender. When the power comes back on I cannot get my devices to connect to the extender again. I have never changed the password but it says it is incorrect. If I am not at home and this happens I have no way to connect to any of my devices such as my thermostat when they cannot reconnect to the extender using the original password.
Last time I just reset the device and started from scratch all over again but that can't be the easiest solution. Advice? Thank you.
Model: EX6100|AC750 WiFi Range Extender
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: AC750 WiF Range Extender won't take password after power failure
Hello MarquesAlan
Unfortunately resetting and starting over is the easiest solution.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2535 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
