Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
All instructions followed - will not connect to network
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-03
10:33 PM
2013-05-03
10:33 PM
I followed all set up instructions, used the genie and cannot connect.
- Found my network
- Confirmed my network's WEP key
- Selected to use the same WEP for the _ext booster
...FAIL. Cannot connect to the _ext network at all
*Tried to do manually
*Tried to set a new password to the _ext, FAIL
the _ext network is probably my strongest in my 2nd floor and recognized by ALL devices, but cannot connect when I correctly enter the WEP
HELP!
- Found my network
HELP!
Message 1 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-08
04:23 AM
2013-05-08
04:23 AM
Re: All instructions followed - will not connect to network
I had a similar issue with my WN1000RP.
Ended up being the channel setting in my WIFI router, set it to 11.
Hope this helps.
Hope this helps.
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-08
08:47 AM
2013-05-08
08:47 AM
I will try that - I am not familiar with 'channel settings'. I have an ActionTech router - what is yours?
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-08
09:22 AM
2013-05-08
09:22 AM
Do not use WEP. Use WPA or WPA2
You need to access actiontec interface via browser and change it.
If need it do the suggested wireless channel but WEP are one of the failure to connect
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-05-08
04:07 PM
2013-05-08
04:07 PM
I have a DLink DIR-300.
For the DLink the channel setting was under manual wireless setup, mine was set to channel 13 just changed it to channel 11 and everything worked fine.
Message 5 of 5
Announcements
