× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Does extender with other party router
Daddysmell
Guide
Is the extender able to work with linksys routers?
Model: WN3000RP|Universal WiFi Range Extender
Message 1 of 9
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: Upgrading Router
Hi @Daddysmell,
You can check the stability of your Internet connection by bypassing the router and connection your computer straight to your ISP's modem and see if the issue occurs. If it does, we recommend contacting your ISP.
Dexter
Community Team
Message 8 of 9
All Replies
DexterJB
NETGEAR Moderator
Re: Does extender with other party router
Hi @Daddysmell,
Welcome to the community!
Yes, most, if not all NETGEAR extenders work with other home routers that use the same wireless standard.
Dexter
Community Team
Message 2 of 9
Daddysmell
Guide
Upgrading Router
I have a r7000 router, Do you think I need to upgrade if , 1) my PS4 is saying no connection 2) everyone in the family is asking what happen to the internet or 3) should I upgrade my internet speed.
Message 3 of 9
DexterJB
NETGEAR Moderator
Hi @Daddysmell,
1. Please make sure that the PS4 is connected to the network either via WiFi or Ethernet.
2. If you are experiencing frequent disconnects, please make sure that the connection from your ISP's modem is stable.
3. That stability/reliability of your Internet connection may not be related to your subscription speed.
Dexter
Community Team
Message 4 of 9
DexterJB
NETGEAR Moderator
Hi @Daddysmell,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 5 of 9
Daddysmell
Guide
Still having the problem.
 I thing I need to upgrand my router. I have several wifi device plus I just add 4 more that run off of Hotspot or I have to us my phone as one.
Message 6 of 9
Daddysmell
Guide
how do I check stabiltiy with my ISP
Message 7 of 9
DexterJB
NETGEAR Moderator
Hi @Daddysmell,
Dexter
Community Team
Message 8 of 9
Daddysmell
Guide
I purchased a AD7200 but I dont know how to use it
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1444 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
