× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Ex6100 No Router Connection
Kangaa00
Using my Netgear Ex6100 in extender mode. Worked fine for the first months now it constantly looses connection with my router. The Router Link LED light will go from Green to off constantly. It won't stay connected for more than 2-4 minutes and will stay off for around 3 minutes before reconnecting.
I have redone the setup process to link it to the router numerous times now. Always looks like it works since all the LED lights turn green but even before I unplug the extender to move it, it will show Router Link connection lost. I have also done the factory reset and still nothing.
Message 1 of 6
DexterJB
NETGEAR Moderator
Re: Ex6100 No Router Connection
Hi @Kangaa00,
Welcome to the community!
1. What is the firmware version of the extender?
2. Have you tried changing the wireless channel of your router?
3. Does the issue persist after relocating the extender?
4. Can your other devices stay connected to main network without issues?
5. Are you connecting the extender to both 2.4GHz and 5GHz bands of your router?
Dexter
Community Team
Message 2 of 6
Kangaa00
Hello,
Where can I locate the information to answer what the firmware I'm using is?
Yes to all the questions #2-5.
Thank you.
Message 3 of 6
DexterJB
NETGEAR Moderator
Hi @Kangaa00,
I have sent you a message. Please check your inbox.
Dexter
Community Team
Message 4 of 6
Guru
@Kangaa00 wrote:
Hello,
Join the extender network and navigate to www.mywifiext.net in your browser.
Message 5 of 6
schumaku
Guru
From reading https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/Ex6100-No-Router-Connection/m-p/1657... one might conclude thee are some known issues, and Netgear does have something at hand @DexterJB please.
Message 6 of 6
Discussion stats
  • 5 replies
  • 1107 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
