× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
New router won't sync with AC1200 range extender.
Havre1977
Tutor
The new router had no trouble connecting to my iPhone, Samsung tablet, printers, Blu-ray plyaers or anything else I have wireless.
When I try to setup the EX6200 extender it's a no go. I have done a reset, tried it WPS and through the website with no luck. Took it to a friends house who has a Netgear Nighthawk R4000P and it synced right with no problem??? I appears the new router doesn't like the old extender for some reason.
Any suggestions would be appreciated.
Thank you.
Message 1 of 4
Accepted Solutions
Havre1977
Tutor
Re: New router won't sync with AC1200 range extender.
Got the Extender working.
Ended up doing a complete reset of the router, setting it back up and doing the same to the extender. They connected on the first try.
 It took more than I thought it would, but like they say the end justifies the means.
Message 3 of 4
All Replies
Guru
1. what router are you connect?
2. what firmware is on the router?
Message 2 of 4
Havre1977
Tutor
Message 3 of 4
Guru
glad to hear you got it working!
Sad it took so much to get going.
I'd mark your issue as solved so others aren't trying to fix it still 🙂
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2004 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
