- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R8000 - WiFi connection is not connecting on all devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R8000 - WiFi connection is not connecting on all devices
What actual firmware number are you on?
What modem is it connected to?
Are you using smart connect?
Is it an issue when they try to connect to 5ghz or 2.4gh?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Connected to a spectrum modem
Not familiar with smart connect.
We had multiple devices in our house that could connect Friday night. Never an issue. 1 device could not connect on Saturday so updated to new firmware and has been a mess ever since. No gaming systems can connect, only 1 TV connects to Netflix. 1/2 of our phones connect. Not all of DirecTV are connected. I have restated internet, modem and reset to the router as well. Same story new day. Any ideas on what is the issue?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anytime you change firmware and are having issues, a reasonable step is to try to factory reset the router and reinstall it.
I'd actually go 1 step further and reinstall the new firmware over a hardwired connection, then factory reset, and reinstall.
Reason why is a reset only removes old settings that can be causing issues. but if it was a problem from the firmware update (like corrupt firmware) it won't fix the problem. Reinstalling can overwrite firmware. So you hit potentially both fixes. The corrupt firmware or an old settings causing issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have done the factory reset twice since Saturday and each time shows updated firmware. Update on Saturday fixed issue but then popped up again yesterday so that made me do the second factory reset. Did not fix issue so will attempt the hardwire connection to see if that works later today.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
