- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
x6 ex77000
- Mark as New
- Bookmark
- Subscribe
- Permalink
x6 ex77000
can you use 2 nighthawk ac2200 x6 ex7700 set up on wps button in a 3 bedroom house .
jerry
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: x6 ex77000
You can but you might have stability issues if they're to close to each other.
Reason why is they're not a full mesh system with a router controlling them. So they just connect to the ssid. IF they're to close, they can end up connecting to each others ssid and not back to the routers.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: x6 ex77000
Make sure the distances are 30feet or a bit more if you have two extenders connected to a host router.
How big is your home?
jerry
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: x6 ex77000
thank you for your reply
house is three bedroom about 1500 sq ft I have a wifi camera on the outside wall of the kitchen which works but it has a poor wifi signal which I am trying to improve .
jerry
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: x6 ex77000
What are the walls in your home made from?
A single router solution should cover 1500 sqft if its centrally located and if the walls aren't made from materials that block wifi.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: x6 ex77000
brick walls with cavity wall insulation .
jerry
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: x6 ex77000
ouch.
Brick is one of the best blockers of wifi.
If there's any way to wire in the extender and use it in access point mode, it'd work better.
As well as if you switch to a full mesh system, hardwiring in the satellites would make a better performing and stable system.
1500sqft isn't that big but the walls are what are causing your issues. I'd investigate either putting in ethernet (if you don't have it) or using moca or powerline adapters.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: x6 ex77000
thank you for your help with this matter .
what is moca .
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: x6 ex77000
ethernet over a coax line. Some homes powerline doesn't work very well. And if they don't have ethernet but do have coax ran throughout, they work well.
https://www.techreviewer.com/tech-answers/moca-vs-powerline/
