× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Router needs to restart every time to connect internet
mrmodi
Hello sir,
I have GTPL Broadband Connection. I need to restart it every time for connecting to internet.
As the GTPL technical said that Netgear router release IP as you close your router.
Once i restart router it will release IP. So in IP address it shows 0.0.0.0. So i need to restart router two to three time
Please suggest me any idea.
Model: JNR1010v2|N150 Wireless Router
Message 1 of 19
Accepted Solutions
mrmodi
Re: Router needs to restart every time to connect internet
I tried my best with netgear router. But it is not compatible with gtpl broadband isp. It doesn,'t work properly.
So let me buy another company's router suggested by gtpl broadband technical person.
Message 18 of 19
All Replies
ElaineM
NETGEAR Employee Retired
Hi @mrmodi
Welcome to the community!
What's happening with the router that you need to always restart it?
Is your connection stable when you connect your computer directly to the modem?
If yes, make sure that you select "Use Computer MAC Address" on the router settings.
Message 2 of 19
mrmodi
I have already selected Use Computer MAC Address.
Message 3 of 19
ElaineM
What's the firmware version installed on your router?
See if reflashing/upgrading firmware will help. By the way, if you decided to upgrade do not forget to factory reset the router.
Message 4 of 19
mrmodi
1.0.0.32 firmware version
I did factory reset also but no solution.
Message 5 of 19
ElaineM
Then the router can be considered faulty.
Message 6 of 19
mrmodi
Sorry for delay reply.
I disagree with your reply because it is working perfectly with other broadband service like tikona etc.
It has only issue with gtpl broadband.
Message 7 of 19
netwrks
Master
If you feel it works properly with other ISP's assuming you have recently tried (as in days not months) your router on another ISP Service, then you should be calling your ISP to work, to resolve the issue.
Message 8 of 19
mrmodi
I have borrow my friend's netgear router same as mine and try to test but the same issue happen with that router also. I discussed with gtpl technician about that but he told its netgear router fault. He suggested me to buy other company's router. So i assume that netgear router is not vompatible with gtpl isp service.
Message 9 of 19
ElaineM
@mrmodi What's the brand and model of your modem?
Also, what's the exact model number of your NETGEAR device?
Message 10 of 19
mrmodi
Netgear N150 wireless router jnr1010
Message 11 of 19
mrmodi
JNR1010
Message 12 of 19
ElaineM
What about the modem?
Message 13 of 19
mrmodi
No modem is there. Broadband cable direct connected to netgear router
Model: JNR1010|Router BRIC N150 4 port
Message 14 of 19
ElaineM
So you have an RJ45 cable coming out of the wall and that's directly connected to the NETGEAR?
If you use a PC to connect directly, connection is stable?
Message 15 of 19
mrmodi
Yes.
Message 16 of 19
ElaineM
Is it possible to use another router aside from the ones you used for further isolation?
The one from your friend, connects but it is not stable, right?
Most sites would just recommend to just use the step that was given previously.
Message 17 of 19
mrmodi
Message 18 of 19
ElaineM
Sorry to hear that it didn't work for you.
Hope you'll have a stable connection on your new one.
Have a great day!
Message 19 of 19
Top Contributors
Discussion stats
  • 18 replies
  • 13341 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
