C7000
27 TopicsMy C7000v2 was working with my Brother printer with WIFI
I have another question and find where to ask it. My C7000v2 was working with my Brother printer with WIFI. It now won't and I'm trying to reconnect it. I go through the process and it asks me to press the WLS button and nothing happens. It's an older C7000 so first off....should the WLS light be lit before I push it. I'm wondering, maybe the thing is shot.530Views0likes2CommentsNighthawk c7000 keeps on resetting wifi
I used nighthawk c7000v2 3 years back and then stored it up. I started using it again with Spectrum. However the wifi keeps on resetting once a day. It can happen at any time of the day. I spoke with Spectrum and went through all the troubleshootinb and they confirmed the issue is not on their end. Does anyone know how to fix this?214Views0likes3CommentsNetgear AC1900 C7000v2 Downstream Light Flashing
I have had the same provider (Xfinity) and the same modem router for about 14 months. I had never had this problem before, but starting last week somewhere around 5 times a day the downstream light will start blinking, and the wifi will go down. This blinking will last a couple minutes, then the wifi will still be down for a minute or so after the light goes back to solid. Sometimes this will happen a few times an hour and sometimes it will be perfectly fine for 6 hours. I have tried reconnecting the coax as well as power cycling a few times but the problem still persists. Does anyone have any ideas on what the issue could possibly be? I have used Xfinity's online wizard which always assures me nothing is wrong, and I could call a tech but would like to be more confident that the problem is actually on the ISP side before potentially having to pay for a tech to come out. Any ideas / recommendations are welcome!Solved731Views0likes11CommentsNighthawk C7000v2 Freezing
Wanted to know if anyone else who purchased this cable modem router has had the issue of the unit just freezing up and it not working. Purchased this in 2023. Had it activated with Spectrum and the issues began. Was on with tech support both Spectrum and Netgear for a straight week. Decided to go back to my old Spectrum supplied modem with my Nighthawk WiFi... Last week, since I still had the unit as a paperweight, decided to try it again. Same thing happened and after a day put it back in the box. Since I no longer have support, has anyone had the same issue and/or has something been off with these units that someone has figured out? I have looked at the community blogs and seems that some people did hard resets, firmware updates to correct the issue but I have also done the same only my results have not made the unit viable.448Views0likes16CommentsNighthawk c7000v2 - Slower Internet After Factory Reset
(sorry to post this here, but i couldn't find the specific topic section for the nighthawk i have). Hello, I had to factory reset my Nighthawk in order to change the passwords on it. When it first came back online, it had no internet at all. After an additional reset and having Comcast send a signal to my unit, the internet has been absolutely abysmal. According to the google speed test, it went from Ultra Fast to just Fine, and Fine is not actually fine because half my webpages don't load. My computer is hardlined in. My phone which is connected to it via wifi, doesn't have a strong enough connected to load pages at all. I contacted Comcast, who determined my unit was the problem. Is there any way for me to get it back to where it was a few days ago? I do have the most current firmware on it. I also left it unplugged for several hours and still nothing. regards, Felix193Views0likes1CommentRandom disconnects: C7000v2 (Nighthawk AC1900)
Throughout the day, I experience random disconnects from the internet for roughly 30 seconds to 1 minute at a time. This will happen seemingly randomly, whether my computer is using the connection through ethernet, or my girlfriend is up late watching TikTok. I have contacted my ISP and gone through all of the regular troubleshooting, and I was hoping that someone could point me in the right direction! My ISP is Breezeline, and I have contacted them repeatedly about this issue, since it has been ongoing since I got their service and the Netgear modem in April. They have issued signal resets, gone through the process of unplugging and reconnection my modem, and even sent out a tech a little over a week ago. The tech said that nothing was wrong on Breezeline's end, and the only thing he did was replace a corroded connection on the outside of the buildings. I attempted to show him the error logs, and he said that he didn't understand what the logs were saying. Either way, a tech came out and could not fix the issue. I'm not sure if this is an ISP issue or a modem issue, but I'm hoping that someone here can help me narrow down the root cause and solution. Below, I have attached my down/upstream channels and the event logs from the most recent times it occurred (twice in the last hour). Please let me know if you need any other information, and thank you in advance for your help! Time Priority Description 2025-6-9, 20:22:52 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0; 2025-6-9, 20:22:03 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0; 2025-6-9, 20:22:00 Notice (6) Honoring MDD; IP provisioning mode = IPv4 2025-6-9, 20:21:47 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0; 2025-6-9, 20:21:14 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0; 2025-6-9, 19:54:47 Notice (6) WiFi Interface [wl0] set to Channel 11 (Side-Band Channel:N/A) - Reason:INTERFERENCE 2025-6-9, 19:48:54 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0; 2025-6-9, 19:48:05 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0; 2025-6-9, 19:48:01 Notice (6) Honoring MDD; IP provisioning mode = IPv4 2025-6-9, 19:47:28 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0; 2025-6-9, 19:47:25 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0; 2025-6-9, 19:46:35 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0; 2025-6-9, 19:46:31 Notice (6) Honoring MDD; IP provisioning mode = IPv4 2025-6-9, 19:46:17 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0; 2025-6-9, 19:45:44 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=54:07:7d:06:43:c8;CMTS-MAC=70:1f:53:99:e2:40;CM-QOS=1.1;CM-VER=3.0; Startup Procedure Procedure Status Comment Acquire Downstream Channel 333000000 Hz Locked Connectivity State OK Operational Boot State OK Operational Security Disabled Disabled IP Provisioning Mode Honor MDD honorMdd(4) Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables 1 Locked QAM256 6 333000000 Hz 3.9 dBmV 42.7 dB 29 82 2 Locked QAM256 1 303000000 Hz 4.1 dBmV 42.9 dB 16 54 3 Locked QAM256 2 309000000 Hz 4.1 dBmV 42.9 dB 27 44 4 Locked QAM256 3 315000000 Hz 4.1 dBmV 42.7 dB 29 121 5 Locked QAM256 4 321000000 Hz 4 dBmV 42.6 dB 24 51 6 Locked QAM256 5 327000000 Hz 4 dBmV 42.6 dB 20 50 7 Locked QAM256 7 339000000 Hz 3.8 dBmV 42.2 dB 17 51 8 Locked QAM256 8 345000000 Hz 3.7 dBmV 42.5 dB 14 54 9 Locked QAM256 9 351000000 Hz 3.8 dBmV 42.7 dB 17 56 10 Locked QAM256 10 357000000 Hz 3.6 dBmV 42.5 dB 13 59 11 Locked QAM256 11 363000000 Hz 3.6 dBmV 42.6 dB 16 58 12 Locked QAM256 12 369000000 Hz 3.7 dBmV 42.7 dB 17 51 13 Locked QAM256 13 375000000 Hz 3.7 dBmV 42.7 dB 29 91 14 Locked QAM256 14 381000000 Hz 3.8 dBmV 42.9 dB 11 56 15 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 16 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 17 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 18 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 19 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 20 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 21 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 22 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 23 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 24 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 5120 Ksym/sec 36800000 Hz 47.5 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 30400000 Hz 48 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 24000000 Hz 47 dBmV 4 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV283Views0likes5CommentsC7800 Nighthawk X4S AC3200 used as Router without Coax Cable
Is there a way with my C7800 Nighthawk X4S AC3200 to configure it to be only a router where I can plug an ethernet cable into one of the internet ports and allow it to connect to another modem and then broadcast the Wi-Fi signal for the internet that comes from an alternate ISP? I want to use this as a router and connect it to a modem from fiber optics that has an Ethernet converter to then plug an Ethernet cable to connect the two devices, but need to know how to configure the Internet ports to be a receiving port and then broadcast the Internet signal wirelessly. Previously, I had Xfinity/Comcast as the ISP, will I also need to change the internal settings to change?397Views0likes1CommentThe Latest C7000 Firmware Update
COX cable here in Macon Georgia just updated my C7000-100NAS with Firmware version v1.01.28. Now my download and upload speed are erratic. I can't even get my 30mbps upload anymore. HEY NETGEAR, ANYONE, is there a fix to this FIRMWARE update?5.8KViews0likes2CommentsNighthawk c7000 - NO AIR PRINT, why?
Why can I connect to my air printers using my iPhones? I have another Netgear WIFI router that I can connect to (on the same network) and have no problems seeing and printing to my air printers from my iPhone. Why is this? How do I fix? -bSolved1.3KViews0likes1Comment
