R7800
34 TopicsR7850 missing Wireless Bridge mode
AT&T decided to cut off my landline. They politely sent a letter stating that disconnect was scheduled for the end of October. And they've stopped providing repair service on landlines. In doing so, they also cutoff internet access. Nice guys, eh? I have a Starlink router in a nearby building, but it doesn't support ethernet. So I need to get my ethernet network bridged to the Starlink WiFi. The R7850 user manual documents how to configure the router for bridge mode. However, "Wireless Bridge" does not exist in the Advanced -> Advanced Setup menu. I'm running Firmware V1.0.5.84 - the latest for this unit. Has anyone been able to get this model router into bridge mode? Thanks, - Dog Pilot87Views0likes6CommentsR7800 reboots in AP mode
For a long time my R7800 was working fine in normal mode. Recently I got a firewalla and then put R7800 in AP mode . if I do that, the system stays on only for a few minutes and then reboots. before it reboots first the wireless stops working any ideas what could be causing this323Views0likes10CommentsNeed recommendations
Normally I rent the equipment from my ISP but I hate eero (which is the only option for renting) and want to get away from it because it's only controlled via apps and I don't do apps. I need some recommendations. Here is how I plan to use the equipment: Whatever router I go with, I need to be able to connect to it via my desktop computer by typing in the router's ip address the old-school way. I like to be able to turn wireless on or off when I want to, or change the signal strength, and I only want to access it via desktop computer. First I plan to purchase modem and router, or a modem/router combo, to use with ISP #1, who has fiber in the ground that connects to a box that switches to coax cable for final delivery to the house, and therefore we would connect said equipment to the coax. Coax and ethernet cable are in the walls. Then, we will be switching to ISP #2 later; they are currently installing fiber in our neighborhood, and they may end up running fiber all the way to the house so that coax is no longer used for final delivery. If this is the case, will I need to change my equipment or is there equipment I can buy that can do both? And I've read that maybe I should buy modem and router separately instead of doing them as a combo; why is that? Oh and our speed will either be the 500 or 1000 plan. Thanks for any advice provided, much appreciated!192Views0likes6CommentsR7800 antenna numbering
Hello, I would like to connect external 2.4GHz antennas to my R7800 – Nighthawk X4S AC2600. I'm wondering why the four antenna ports are numbered 1, 1, 2, 3 (and not 1 to 4). Is there any difference or some kind of dependency between the ports? I would like to install one antenna on each floor (basement, ground floor, upper floor) and one in the garden. I know that MIMO will no longer work. I am only interested in achieving the greatest possible WLAN coverage, not in bandwidth. I already tested it and the coverage works very well for browsing the internet etc. But I get interruptions sometimes when using MS Teams for example. So the question is if it is ok to use 4 independent antennas or may be only 3 are possible. Which ports should I use then? Btw., I'm using openwrt on the devi ce. Thanks!411Views0likes4CommentsR7800: Reset password text gets automatically changed (MAC)
Hello, I own an R7800 and recently my admin password was not accepted. I have reset all parameters using a safe password from apple password manger and confirmed the security answers for the password recovery. Now when I tried to log in again then it failed on both the log in and the password recovery. I realized that when I click on "continue" the text box of the answers gets changed by a random sentence. It changes the answer: "Barxxx" by "jQmFyY2Vsb25h". This second word I can't control and every time I log into the page it changes randomly. I assume the first "encrypted word" has been stored into the router and now I can't find it anymore. I am afraid the router has been hacked. It happened to me some weeks ago and I could completely reset the router and manage to recover everything but now I can't reset the router anymore. Can you please help? Regards641Views0likes11CommentsAttached Devices Not Displayed
Nighthawk x4s R7800. Functionally it seems to be functioning well, but after logging in to the router it takes a moment and shows the number of attached devices but it will not display what they are. When clicking on the "attached devices" window after it has determined the number the message is "please wait a moment" with a circling icon but it never gets past that point. Also, I tried to update the firmware from V1.0.3.92 and it won't reach out to search for the update on the internet (same endless "please wait a moment" event). Trying to load downloaded firmware on my computer, I can direct it to the file but when I try to upload it I also end up in the endless "please wait a moment" event so the firmware does not get loaded. After trying either of those routes I can back out by just pressing any other button in the menu and everything seems ok other than neither of the mentioned objectives were achieved.279Views0likes2CommentsERR_SSL_KEY_USAGE_INCOMPATIBLE NETGEAR Nighthawk(R) X4S R7800
Hello, I can't connect to the GUI of my NETGEAR Nighthawk(R) X4S R7800 via several browsers like Opera, Ecosia etc. and get the Error: ERR_SSL_KEY_USAGE_INCOMPATIBLE (Firefox works so far) There are patches for several other devices regarding that issue as I read in this community. Is there one as well for "NETGEAR Nighthawk(R) X4S R7800"? I just installed the latest firmware now being V1.0.3.92 Thanks and kind regards455Views0likes9CommentsR7800 is not accept reset!
Hi, I need my old router for my home network. I tried to use my login info but it didn't work. I tried to reset with 7 or 10 sec rules but still gateway IP is 10.0.0.1 and not accepting admin/password login info. I reset many times but result is same; like reset was not working on it. After login tries, it asked me questions about my school and friend but I didn't set anything like that! I'm stuck in a vicious circle! What can I do with this brick to use it like in my old happy days? Thanks,Solved372Views0likes4CommentsR7800 Readyshare doesn't work on Windows 11
I have two Netgear routers. One main R7800 and the other R6400v2 connected to it via patchcod operating in AP mode. Both are connected to 2.5" drives via USB. On Win10, access to the USB drives is problem-free, mapping works fine. On Win11, I can't map drives from R7800 - it displays the message "An extended error has occurred". However, I can map a drive from R6400V2. Interestingly, the system does not remember credentials despite selecting the "Remember login credentials" option (you have to enter login data every time you start the system to access the resource) and you can't map a resource by router name, e.g.: \R6400v2\DISK2 - it only works by IP address, e.g. \192.168.1.1\DISK2. Both routers and the computer are in the same workgroup. In the Win11 network environment, R7800 is visible but R6400v@ isn't. SMB1 is enabled, Insecure Guest Login is enabled. I reset the network settings and it doesn't work. What could be the reason for the lack of access to the USB disk on the R7800 via Win11?Solved566Views0likes4Comments
