Readyshare
20 TopicsReady Share does not work
I connected a WD external hard drive to my router. I cannot access it per the instructions. I tried \\readyshare and it doesn't work. What am I doing wrong? The NetGear genie sees the external harddrive as \\readyshare\USB_Storage, yet when I try it I get the following error message "Windows cannot access \\readyshare". I am so frustrated.SolvedLatest frimware for R6400 V1.0.1.34_1.0.24
After installing latest firmware (V1.0.1.34_1.0.24) on Jan 13, I am no longer able to access readyshare via USB 3.0. It was previosuly intermittent until the last firmware update remedied that issue. Win10 Pro x64 V1709 Any insights would be appreciated. ThanksSolvedReadySHARE USB Printer for macos High Sierra - Installation Is Incomplete
Hi, I am having trouble installing the ReadyShare USB Printer (ReadySHARE USB Printer MAC_V2.36) on macOS High Sierra. Whenever the installation completes and the machines reboots, Netgear USB Control Center is giving the following error message " Installation is incomplete! Please reinstall again. " How do i fix this? Or is the software incompatible with High Sierra? Kindly advice. Thanks, DarrenSolvedReadyShare SMB1 Error
Connecting a USB Storage to my router I get the following error when I try to connect. I updated to the latest firmware, but that had no effect. Any ideas? System error 384 has occurred. You can't connect to the file share because it's not secure. This share requires the obsolete SMB1 protocol, which is unsafe and could expose your system to attack. Your system requires SMB2 or higher. For more info on resolving this issue, see: https://go.microsoft.com/fwlink/?linkid=852747SolvedR8000 USB 3.0 not working after updating to Firmware 1.0.3.54
My readyshare drive (external hard drive) plugged into the USB 3.0 port was inaccessible after updating my R8000 firmware to the latest verions 1.0.3.54. The drive wasn't being recognized by the router, by checking the web interface. There was no issue with the drive when plugged into the USB 2.0 port or my laptop. I checked the USB 3.0 port with a couple other external hard drives and usb pen drives. Again with the same results, not recognized in the USB 3.0 port, but working fine in the USB 2.0 port. Resetting back to factory settings didn't help. From there I rolled back to firmware version 1.0.3.48, and then like magic the drive in the USB 3.0 port was being recognized. There seems to be several posts regarding issues with the USB 3.0 port, but the only solutions being offered by support is to try a factory reset. I was very close to contacting support for a hardware replacement since my warranty is close to the end of the one year. My issue isn't hardware, it's with the firmware. I hope there is work being done resolve the issue in a firmware update.Solved3.1KViews0likes2CommentsR7500 - AccessPoint configuration - no ReadyShare Vault possible
Hi, due a change of the ISP I had to change the configuration of my Netgear R7500 to the AP configuration. Till this change I used ReadyShare Vault for backup and restore. After the configuration change, the ReadyShare Vault does not detect any backupdrive anymore. The drive attached to the R7500 is still accessible and usable The firmware is up to date, whats goinng wrong?Solved1.9KViews0likes2CommentsUSB 3 Won't Recognize ReadyShare Drive
I have an R6400 AC1750 router on firmware V1.0.1.24_1.0.18 that will not recognize my Seagate 4TB BackupPlus Hub (formatted in MacOS Journaled per Netgear's instructions). If I plug it in USB 2, it pops up right away in the Readyshare settings page, but nothing on USB 3.0. I have tried restarting the router with the drive plugged in but it does not work. USB 2.0 is not sufficient for my needs, so the inoperability of the USB 3.0 port is a dealbreaker. Is there any solution for this problem? Do I need to do a warranty return?SolvedReadyShare vault doesn't recognise USB drive
I've bought a new R7000 and hooked up a Samsung M3 (2TB) USB drive. The router recognises the drive perfectly and works fine for accessing files through e.g. Windows Explorer. But, Ready Share Vault does not recognise my backup drive and says "No ReadySHARE device detected". I've also tried another Samsung drive (1TB), but it also wasn't recognised. After reading all related posts, I'm unable to get the drive recognised. Please help.Solved9.5KViews0likes6CommentsReadyShare can't find USB drive
Have 2 laptops connected to Readyshare. Been working OK. One laptop had a hard drive die, so I replaced and reloaded win10. The bad drive would still let me get files off of it, so I didn't use ReadyShare After reinstalling everything, both computers can't connect to ReadyShare Simply won't recogize there is a drive attached. Attached drive has its blue light blinking, so I know it's alive. Any ideas on how to fix? BTW the new version of Genie is so slow it is painful to use.Solved
