cm2000
3 TopicsWhy is Xfinity blocking access to the spectrum analyzers?
Copied from a reddit discussion on the unofficial Comcast page. Could not get a definite answer. Recently discovered that port 8080 buy doing a port scan of the modems log in IP that Comcast is blocking the analyzer by http proxy. Why are they blocking this? It wasn't enough that they told modem manufacturers to not display unerrored codewords. Now we can see the analyzers now. There was a short window where I could access it, where I would disconnect the coax cable from the wall plate. Then allow the modem to lose connection, after that I could see it for a few seconds. Before the modem downloaded the configuration file. There was a log in page to get to it as well. Does Netgear use any services on port 8080 with their modems?219Views0likes3CommentsCable Modem for Xfinity (August 2025)
Xfinity identifies the following older Netgear modems as compatible for my location: Netgear CM1100 Netgear CM2000. (I do not require Voice or WiFi in the modem.) Seeking recommendations for whether I should purchase the newest available Netgear modem or should I seek one of these older models? If a newer model, are there any to be avoided?Solved679Views0likes6CommentsIs the Netgear CM2000 end of life now?
Just a question if the Netgear CM2000 is EOL now? I am only using it right now as I dont know when Xfinity will roll out mid split. Once they get it going in my neighborhood I will get the CM3000. Another question is should I not expect any more firmware updates for it?Solved634Views0likes2Comments
