mr6110
4 TopicsMR5200 broke down
Last week at once the battery in my NightHawk M5 said puffff. The screen of my Nighthawk was black..... and no connection no more. After it cooled down I was not able to close the back of the Nighthawk since the battery had become too thick. I thought I could solve this simply by ordering a new battery, but unfortunately the Nighthawk does not recognise the new battery (original W-20). Could be an unlucky one so ordered again a new one, but same issue. Finally I put in my old battery, but in my opinion it is technically not safe. There is no more warranty on this product, since it is 3 years old. But a product in this price-range should not brake down in 3 years, let alone the risk I had with the exploding battery....... Is there anyone with similar issue? And able to solve? Any support of Netgear? If not, I will buy a cheap-brand replacement...... pffft TAG should be MR5200, but this tag is not availableSolvednetgear m6 - 6110- tlaus
Good evening my friends I have a Netgear m6 mr6110 router, Australian version, but I discovered that this version does not support 5G frequencies except n78 only. Is there a way to activate the rest of the 5G frequencies such as n40 - n77 - n28? I am from Saudi Arabia and all of these frequencies work for us. Is there software to solve this problem, my friends?NIGHTHAWK M6 & M6 PRO Connectivity Issue Resolved!
Hello NIGHTHAWK Community, A new software update is now available and being pushed over the air to all AT&T M6 Pro and M6 devices to address the recent Ethernet issue. If your device does not show PRI version 4.10 under Device Information, please check for updates manually from your device. We thank you for your continued patronage! Best, NETGEAR Team
