orbi 770 series
127 TopicsClients on Orbi Wi-Fi receive an IPv6 default gateway from an Orbi unit
I have a similar problem... My BGW320 is set to passthrough to my ORBI RBE770+2 satellites... Clients on Orbi Wi-Fi receive an IPv6 default gateway from an Orbi unit (fe80::ca10:2fff:fe40:e8a5, MAC C8:10:2F:40:E8:A5), an fd2a:7f4:ca8c::/64 ULA prefix, and an IPv6 DNS server fd2a:7f4:ca8c::1. The Orbi should not be doing this in AP mode. Samsung TVs on Orbi Wi-Fi fail Netflix (NW-2-5) and Prime Video. The same TV wired directly to the Firewalla streams fine. IPv4 is correct on both paths. No IPv6 setting is visible in the Orbi web UI in AP mode. Firmware: V12.1.7.23 How do I stop the Orbi from advertising IPv6 in AP mode?44Views0likes12CommentsThe 770 Series Sucks
I bought the 770 Series Tri-Band Wifi 7 Mesh 3-pack, and I consistently have trouble with my wifi. I often lose the signal (several times daily), and it makes it difficult to enjoy any streaming servies. I never had this problem with my old Orbi system, which I only got rid of because Netgear no longer supports it. What can I do?57Views0likes2CommentsWiFi network will disappear suddenly, undetectable by any device in the house
I have this same issue, or very similar, with an Orbi 770 (RBE771), but the problem is at the router, not the satellite. WiFi network will disappear suddenly, undetectable by any device in the house. But I can hardwire into the Orbi router with Ethernet and connect just fine (modem and internet working perfectly). Dashboard says the WiFi status is "GOOD" but no WiFi devices can connect. This persists until the system is power cycled to reboot it. The maddening part is that it seems to happen randomly. Very frustrating.55Views0likes2CommentsOrbi 772 backhaul through MoCa
Hi everyone, I hope someone can help point me in the right direction, because both I (and Copilot, Gemini, and ChatGPT) have run out of ideas. I recently purchased a new mesh system (Netgear Orbi 772) consisting of one router and one satellite. My internet connection is delivered to the house via fiber, and I want to distribute it through my existing coax cabling (TV antenna cables and outlets throughout the house). My setup is as follows: Fiber Modem ↓ TP-Link AC1200 Router ↓ goCoax MoCA Adapter ↓ 5-2400 MHz 6-port coax splitter ↓ goCoax MoCA Adapter (Room 1) → Orbi Router goCoax MoCA Adapter (Room 2) → Orbi Satellite The coax network is only being used to carry internet traffic. The main Orbi router works perfectly, but the satellite keeps showing as "Disconnected". It's worth mentioning that the router and satellite are too far apart to communicate wirelessly, so they must use the coax/MoCA network for backhaul. Additional information: Wi-Fi is disabled on the TP-Link router. The Orbi system is running in AP Mode. Both goCoax adapters show the expected MoCA link LEDs. I have swapped: Both Orbi units All three goCoax adapters Ethernet cables Coax ports/locations If I place the router and satellite in the same room and connect them directly via Ethernet, the satellite immediately comes online with a Wired/Good status. If I move the satellite back to the remote room and connect it through the MoCA network, it becomes Disconnected again. From my perspective, everything is connected correctly, but I clearly seem to be missing something. Has anyone experienced a similar issue with Orbi + MoCA or have any suggestions on what I should investigate next? Thanks in advance for any advice! 😊427Views0likes39CommentsEnd of service replacement
Hi -- I received a notice that my current Orbi AC3000 system is no longer supported, so I'm looking to replace it with a newer Orbi 770. However, I have a number of IoT devices connected to my current system including a Wemo device that Belkin no longer supports, so that it cannot be reset and connected to a different network. Q: If I rename my new Orbi to match the old network name and give it the same login, will all of my IoT devices reconnect? Thanks! -- LouSolvedRBE770 v1 satellite stops accepting WiFi clients – reboot immediately fixes it – V10.5.20.10_2.2.51
Hi all, I am experiencing a recurring issue with my Orbi 770 system and, after quite a bit of troubleshooting, this does not appear to be a normal roaming, coverage or client-side issue. Before suggesting the usual troubleshooting steps, please read the details below, as I have already checked and tested quite a few things. HARDWARE / SETUP Router: RBE771 v1 Satellite: RBE770 v1 Firmware on both: V10.5.20.10_2.2.51 Both labels state RBE771 / RBE770, with no "v2" designation. System is running in AP Mode. Main internet connection: 1 Gbit fibre. ISP router WiFi is disabled. The RBE771 is downstairs. The RBE770 satellite is on the first floor in my office. Devices on the second floor normally rely heavily on the satellite. The satellite reports its status as "Good". The satellite backhaul is shown as 5 GHz + 6 GHz. A desktop PC is connected by Ethernet directly to the RBE770 satellite. THE ACTUAL PROBLEM After the system has been running for a while, sometimes one or several days, all wireless devices stop connecting to the RBE770 satellite. They all move to the RBE771 router downstairs instead. This affects different kinds of clients and different bands. I have seen 2.4 GHz, 5 GHz, 6 GHz and WiFi 7 / MLO-capable clients all connected to the downstairs router while zero wireless clients are connected to the satellite. This causes a real problem for devices upstairs, especially on the second floor, because their connection to the downstairs router is weak and they start losing connectivity. The important part is this: The satellite itself does NOT appear to go offline. While the problem is occurring: - RBE770 still appears in the Orbi interface - Backhaul status still shows "Good" - My Ethernet-connected desktop behind the RBE770 continues to have a working network/internet connection - Only the wireless clients appear to stop using or being accepted by the satellite So the RBE770 is still forwarding Ethernet traffic and maintaining its backhaul connection. REBOOT TEST Today I deliberately tested this. Before rebooting the satellite: - Virtually every wireless client was connected to the RBE771 downstairs - The RBE770 had no wireless clients - My wired desktop was still connected through the RBE770 - Satellite status was still "Good" I then rebooted only the RBE770 satellite. I did NOT reboot the router. After the satellite came back online, wireless clients immediately started connecting to the RBE770 again. So the behaviour is reproducible: RBE770 stops serving/attracting wireless clients -> Satellite-only reboot -> Clients immediately reconnect to the satellite This strongly suggests to me that this is not simply a case of "sticky clients" refusing to roam. If it were normal roaming behaviour, rebooting only the satellite should not suddenly cause multiple unrelated devices to start using it again immediately. WIRELESS / MLO SETTINGS ALREADY CHECKED I have also checked Advanced Wireless Settings. Current relevant settings include: Enable 20/40 MHz Coexistence: enabled 2.4 GHz Preamble Mode: Automatic 5 GHz Preamble Mode: Automatic Under MLO Backhaul: "Enable 200 MHz Bandwidth" is NOT enabled. So before anyone suggests disabling the 200 MHz MLO backhaul option: it is already disabled. The Orbi interface does nevertheless show the satellite backhaul as 5 GHz + 6 GHz, which I understand is normal for the WiFi 7 enhanced/MLO backhaul architecture. I have deliberately not started randomly changing every wireless parameter, because rebooting only the satellite restoring all wireless clients is a much stronger indication of a satellite-side software/radio issue than a basic RF configuration problem. OTHER THINGS ALREADY INVESTIGATED / TESTED During earlier troubleshooting I have also: - Rebooted both router and satellite - Tested different security settings, including WPA3 - Checked Smart Connect behaviour - Checked satellite placement - Verified the satellite reports "Good" connectivity - Tested client behaviour on different floors - Observed clients on 2.4 GHz, 5 GHz and 6 GHz - Confirmed that the issue returns after the system has been running for some time - Confirmed that rebooting the satellite temporarily solves the problem Previously I also experienced situations where devices upstairs would insist on connecting to the router downstairs rather than the much closer satellite. The important difference now is that I have been able to verify that, when the fault occurs, essentially all wireless clients disappear from the satellite at the same time, while Ethernet through that same satellite keeps working. FIRMWARE / V1 VERSUS V2 I am aware of firmware 12.1.7.23. However, my hardware is the original RBE771 / RBE770 v1, not the RBE771v2 / RBE770v2. Therefore I will NOT attempt to flash 12.1.7.23 onto these units. My current public v1 firmware is: V10.5.20.10_2.2.51 There is another recent thread describing very similar behaviour: "Satellites won't connect iPhone / Sonos to WiFi after 12 hours" That user also appears to be running the RBE770/771 v1 series on V10.5.20.10_2.2.51. This is one of the reasons I suspect there may be a firmware issue affecting the satellite's wireless/fronthaul functionality. WHAT I AM LOOKING FOR I would particularly like to hear from NETGEAR staff or anyone with direct experience of this issue. Specifically: Is this a known issue in V10.5.20.10_2.2.51 on the RBE770/RBE771 v1? Is there a known condition where the satellite's 2.4/5/6 GHz client radios or fronthaul stop functioning while the backhaul and Ethernet bridge remain operational? Is there a newer beta or engineering firmware build for the RBE770/RBE771 v1 that addresses this? Is a new public firmware release for the 770 v1 series currently being tested? Are there specific debug logs or radio-status pages I should capture while the fault is occurring, before rebooting the satellite? I am happy to reproduce the problem again and collect debug information while the satellite is in the failed state. What I do NOT want to do is schedule a daily reboot of the satellite as a workaround. A WiFi 7 mesh system should be able to keep its satellite radios operational continuously. If NETGEAR engineering has a test build available for the RBE770/RBE771 v1, I am more than willing to test it and provide feedback. Thanks.316Views0likes6CommentsOrbi 770 satellite drops clients when IOT or Guest networks are activated
I’ve a 770 mesh system with router and one satellite. It’s V1 hardware running the latest (10.5.20.10) firmware. Repeated tests confirm that the satellite stops serving all connected clients (both wired and wireless) soon after either of the Guest or IOT networks are activated. At this time the router status page indicates that the satellite is connected (both 5ghz & 6ghz) but the connections of all satellite clients are greyed out / disconnected. This behaviour will manifest even if any of the following are done: - satellite placed within 5m of the router followed by reboot of both - satellite within 5m of router and factory reset of satellite followed by reconnection - only one of IOT / Guest networks enabled - wired clients disconnected - wifi channels changed from default Once the problem occurs the only way to recover reliable operation of the satellite appears to be to factory reset the firmware on both router / satellite and then set the system up again from scratch. Has anyone else encountered this problem? I’ve raised a bug report with Netgear but so far no response.251Views0likes10CommentsOrbi 770 unstable
I have a relatively new 770 router and 2 satellites. It has become completely unstable, dropping satellites, dropping internet connection to provider router. Simply stopping. I’ve rebooted, I’ve done factor reset and restart . It works for a couple of days then stops. before I boot it out to the rubbish tip has anyone got any ideas196Views0likes8CommentsWhat about v1? No firmware updates since January 2026
What about v1? No firmware updates since January 2026, ironically when I bought it on post Black Friday sale for $1000 for 2 satts and a router. Tons of vulnerabilities need to be patched on these devices. What’s the timeline for next firmware release?125Views0likes2Comments
