orbi 870 series
56 TopicsRBE871, IPv6 failures on Gigaclear & old, old firmware
Still no update -- a year after the previous release -- for this issue? Snails pace doesn't begin to cover this abysmal lack of urgency. RBE871 (Orbi Router) Firmware Version 10.5.20.4 The firmware that would resolve the IPv6 failure I was assured was due "real soon now". I'm hoping it won't take another year for Netgear to fix this.satellite turning off the wifi when connected to Ethernet
Having a similar issues on my 871 with the satellite turning off the wifi when connected to Ethernet. I have them in AP mode, current firmware, reset thousands of times, set the units up within 10 feet of each other after reset to link. App on computer is working, shows connected by Ethernet on one satellite and the other showing connected by wifi. It shut off the wifi to the Ethernet connected satellite and the other one has the wifi working and taking up the slack of the lost wifi signal. Wifi speed at the Ethernet satellite drops to half will not connect to phone or any other wifi connection. But it is keeping the Ethernet connected devices working. App shows32Views0likes2CommentsConsistent Internet drops
Hi - I recently purchased the Orbi 870 series (router plus 3 satellites) and I currently have 2 satellites hard wired to the 871 router and 1 satellite connected wireless. On a regular basis my internet connection will slow to a crawl (download speeds of 1-2 MB and upload speeds the same) for several minutes. I have had to power cycle the router or occasionally the closest satellite to resolve the issue. Sometimes other satellites and router do not have the issue and it is isolated to one satellite. This happens fairly often to me, but I could not find anyone else with the exact same issue. I upgraded to Orbi 870 from an Alien Amplifi system and I absolutely loved Alien, but they stopped making them so I needed to transition to something that had longer term support. My home internet is a 2GB plan with kinetic and when the Orbi is working it is fantastic, but this dropping/slowing has been happening so often that it has become really frustrating since both my wife and I work from home most days. Here is my system info: RBE871 - Router RBE870 - Satellite #1 - Wireless RBE870 - Satellite #2 - Hard wired RBE870 - Satellite #3 - Hard wired Kinetic 2GB Internet I have looked at logs and verified I am on the latest firmware, but this issue has been persistent and there doesn't seem to be any obvious causes so I am here for some help. Let me know if I need to provide some more information/screenshots/etc... Thanks, Trent301Views0likes22Comments870 with DNS issue
I'm having issues with DNS on my RBE870 with 1 satellite. I have fiber to the house from Visionary Broadband. All my cables are cat 6A shielded (including ethernet to the satellite). The 870 is connected directly to the modem (fiber to IP device). Router is set to use the modem DNS servers (google). Everything will be fine for a couple of hours after a router reboot and then suddenly you can't surf. When this happens I can ping any actual IPs but not any site like the url for google or yahoo. This happens on phones, Macs, Windows and tablets. If I add DNS servers to the computers/phones/tablets everything is fine. I have tried adding DNS severs to the router with no change (Cloudflare/Quad9/Open DNS/Google). Router & Satellite both have the most current firmware (V10.5.20.4_1.3.5). Anyone have any ideas? Thanks JaySolved204Views0likes17CommentsOrbi 872, IPv6 & Gigaclear
Is there anyone on a Gigaclear service using IPv6 on this model Orbi and can help with the settings needed? I've a case open with Gigaclear at the moment. I have a fixed IPv4 address. Using a Linksys Velop router the IPv6 assignment was picked up quite happily (I think this was set to Auto or DHCP or similar but I don't have the router now as it had to be replaced and the Orbi took over, so can't check exactly) and the line based all the tests at https://test-ipv6.run/ and https://test-ipv6.com/ The Orbi however doesn't even see the IPv6 coming down the wire towards the WAN interface although Gigaclear confirm it's live on my line and the WAN interface stays resolutely blank (see the screen shot below) I've tried all the various sensible settings under the IPv6 tab on the Orbi web interface but nothing works (ONT and router rebooted on each change and re-tested). Anybody with this router and a Gigaclear line able to say "oh yes, it's this!" and has a working IPv6 setup would be really helpful? TIA! Chris B340Views0likes18CommentsOrbi 870 Firmware Updates
It seems the last firmware update was in the later half of 2025 i.e. Sep/October. Just wondering if another one is planned soon? 1 year between updates seems like an awfully long time. Does anyone have knowledge on when the next 870 update will be / what it should address? I noticed one of my nodes backhaul degrades over time - I manually restart it from time to time but I hope there is a firmware fix.263Views0likes1CommentAccessing orbilogin.local shows an error "certificate is using a broken key size" in Safari MacOS
The attached screen shot shows the error when trying to access the admin interface at orbilogin.local on my network using Safari in MacOS Sequoia. It seems to be related to another Netgear domain: routerlogin.net Issued by: routerlogin.net Expires: Sunday, 8 October 2124 at 08:55:21 British Summer Time @ "routerlogin.net" certificate is using a broken key size Apart from setting to "Always Trust" which I'm loath to do, is there a workaround for this certificate issue? Neither the Netgear forums nor a Google search give anything particularly relevant. TIA Chris320Views0likes17CommentsHow many satellites for WiFi 7 in tall old home?
I have an Orbi RBR50 with three satellites in my 3-story, 125-year-old home with lathe plaster walls. The RBR50 is on the 2nd floor, satellites on the 1st and 3rd floors and an outdoor unit in the garage for summertime patio use. Now that the RBR50 system is no longer supported, I'm looking at WiFi 7 systems and wondering if I still need as many units to overcome the old walls.Solved159Views0likes7CommentsOrbi RBE872 ordered, supplied as RBE871
Can anyone confirm whether the RBE871 is a UK Netgear supplied device or is this some sort of grey-import? The UK Netgear site doesn't show the 871 for sale but does offer the 872. I'm based in the UK (England) and am about to raise a complaint with Amazon UK, as both times I've ordered this model (see screen shot) which it's claimed is the RBE872 model, the item I received whilst new, un-opened and shrink-wrapped etc claims on the boxes (outer & inner) to be an 872 yet when opened, the base of the unit and the web interface both quite clearly show it as an 871 unit. Can anyone throw any light on how/why this might be? Is there some subtle numbering distinction I'm not aware of that means they're actually one and the same unit or am I simply being conned? TIA ChrisSolved133Views0likes2Comments
