readycloud portal
8 TopicsPhotos will not upload from my iPhone anymore.
I have uploaded almost all my photos in one morning it just stopped. It will no longer upload even though it says the drive. I’ve chosen the destination folder and it says “waiting for device.” Any help would be appreciated because I need to make sure they’re all backed up before I start deleting picturesReadycloud files aren't available through the browser - R7000
I setup Readycloud on my R7000 using a 250gb Samsung SSD but I can't access my files through the web interface (the only option available for my Macbook). The Android app on my phone works great remotely (but only the app - no files are visible when using the browser). I've tried using the latest versions of both Chrome and Safari multiple times over the past month to no avail. Any help would be GREATLY appreciated. Thanks! -- Device: Nighthawk R7000 Firmware: Firmware V1.0.7.2_1.1.93 OSX 10.11.6/Macbook Pro Android 6.0.1/Nexus 6 Android App (works fine) Android Browser (no files- same as desktopSolved2.7KViews0likes4CommentsReady Cloud Folder Not Available
Currently I am using a R7000 Night hawk Router. I have a ready cloud account and WD 1 TB external Drive connected. The folders are simply not showing when I log into ready cloud. I can see the volume on my network within my home...I can even access if through ftp and https if necessary, but the folders do not appear when trying to access through the readycloud. I have tried removing the volume, renaming the share drive and recreating it. I have even changed the name of the ready cloud accouint with a different email address...Solved3.1KViews0likes4CommentsR8000 & Readycloud Registration failed
Hi Fora, I have recently updated my R8000 to firmware version V1.0.3.4_1.1.2 and figured I'd give the Readycloud a try. So I was able to logon online and even with the app, but as soon as I try to connect my R8000 with the EXACT same username and password (please don't ask me if I'm sure :-) ) it gives me the following error: Registration failed. Please check your user name and password and try again. Anybody any ideas what I am doing wrong or what might be going on? In eager anticipation of your replies SergeSolved10KViews0likes22CommentsCant register my router to the readyCLOUD account
I am trying to get readyCLOUD up and running. I have created an account on readyCLOUD but when I try to register my router in the router interface with the login and password from readyCLOUD it doesnt work. About 20 secs after entering username and password it simply says that registration failed and that I should check my username and pw. I have now tried it several times, chaning the password a few times as well. Nothing works.Solved9.2KViews0likes18CommentsR7000/Add additional ReadyCloud users-NO ReadyNAS
Hello! I'm having a ton of trouble trying to find a way to add ReadyCloud accounts to my r7000 that has a compatible Seagate USB. I do NOT have a ReadyNAS. Been through tech support and they finally ended the call and sent my 2 links via email that linked to KB docs that only deal with ReadyNAS and that I already read. Thanks in advance for any help the community can provide!! Here's where I'm stuck. I registered my drive and MY ReadyCloud account works perfectly! However, I want to add my wife as well and that's not happening. We're headed to Disney World in a couple of weeks and I just want her to be able to upload her photos from the resort to the attached storage. That's it!! Again, my account works just fine from my iPhone, I just want the same for her.Solved5.1KViews0likes5CommentsR7900 - ReadyCloud WEB Preview Not Working
I am brand new to ReadyCloud and using it for the first time. I have a Seagate Portable Drive USB3 attached to my R7900 NightHawk and I can get the device from a WEB browser, phone, and tablet. However, when I try to preview image files (*.jpg) nothing happens! No preview, no error, no nothing! I can download the files and then view them but I can't preview them online. I sent myself a link to access a folder on the drive. Opening the link and navigating the folder path as well as listing the files works great. Just no preview. I've tried this in Edge, IE 11, and Chrome. Video of my action. Any assistance is appreciated, WoodySolved3.6KViews0likes1CommentI am unable to download the larger files using ReadyCloud. Please Help Me!
I have a Nighhawk R7000 router. After I first set up my ReadyCloud I was able to download some of the larger files stored on it. Recently I found out it is limiting them to a very small size. I would like to be able to use it as it worked in the beginning. I am not sure if something changed on the last firmware update or why it is not working now, but would really appreciate someone's help. Thanks So Much!!!Solved3.8KViews0likes9Comments
