rs90
6 TopicsRS700 pinging Google DND every 4-5 secs on AP Mode
I am currently using my RS700S in AP mode behind a pfSense firewall. I noticed the router is pinging 8.8.8.8 and 8.8.4.4 every 4-5 secs showing up in block alerts, more of nuisance than anything with it flooding the logs rather than any connectivity. I assume it's trying to check for an internet connection, but there needs to be a way to block/stop the RS700S when in AP mode. I assume this is not just the RS700 but other models probably doing the same as a lot of them share similar core firmware.980Views0likes10CommentsRS90-Can't connect to a Chromecast/Google Streamer?
Picked up the RS90 earlier today and got everything set up pretty easily. Only issue is that the Chromecast and Google Streamer won't seem to connect. I managed to get the Chromecast connected earlier, but it didn't last all that long and eventually disconnected. Is there a setting I've screwed up somewhere? Or is Google just not compatible with Wifi 7 or something? I believe I'm on the latest firmware (v1.1.1.94), and everything else seems to be running fine, so any suggestions are super appreciated. Thanks!Solved175Views0likes3CommentsWi-Fi signal drops out for seconds
I'm currently having issues similar to what you're talking about. Wi-Fi signal drops out for seconds, whether I'm playing a mobile game like Evony TKR, or in a Microsoft Teams meeting. It's been super problematic for me recently and have been looking for solutions. I have the RS90195Views0likes2CommentsIs there beta firmware for the RS90
Hi, is there beta firmware for the RS90 ? I just upgraded to this router. I am on FiOS 1 Gbps symmetrical down / up and am getting consistent 7-900 Mbps down but seem to be capping at 30 Mbps up. Did not have this problem with my previous and much older RAX54. I am on firmware 1.0.1.80 Any fixes you can suggest ?Solved388Views0likes8CommentsRS90 LAN LED flashing red/orange
I'm not sure whether of the color ... it's either red or orange and flashing. The closest solution I can find was to update the firmware. I checked and it's the latest version. Devices connecting via ethernet are working. Any help appreciated!Solved369Views0likes3Comments
