unmanaged switches
12 TopicsXS508M Crashed. No Longer Have Any Confidence in This Device
My XS508M stopped working whilst I was away for work which is when I need my office network working reliably so caused me a lot of issues. Basically I use this as my main switch. My WAN router and my NAS (which hosts a number of key services) connect to it. All other switches, servers and clients are off that switch, so the loss of that switch meant all other LAN traffic stopped, as well as no incoming internet traffic which was what knackered me. When I returned and started my investigation, I was careful not to do anything that might lose the root cause so I fired up a laptop (no DHCP), set a static IP and then tried to connect to different appliances/devices. It was clear the XS508M was dead, anything connected to it was down and as it is unmanaged, nothing else I could do but unplugging/reconnected the AC lead, which immediately resulted in the entire LAN coming back to life and being contactable from the WAN once more. Since it is unmanaged I obviously cannot get any logs, cannot upgrade/downgrade the FW, what else can I do to determine the cause? Has anyone has this with a XS508M? Is this an unreliable switch? If it is not totally reliable, I will need to replace it, what a waste of money. What else should I use?456Views1like7CommentsNETGEAR GS108 keine Verbindung zum Router
Hallo Zusammen, ich habe z.Zt. einen Netgear FS108v2 Switch über ein LAN-Kabel (ca. 15m) mit der FritzBox 7590 verbunden. Diese Verbindung funktioniert. Nun möchte ich den FS108v2 (der nur 100MB Übertragungsgeschwindigkeit hat) mit einem Netgear GS108v4 austauschen, da der neue Switch eine Übertragungsgeschwindigkeit bis zu 1000MB hat. Leider muss ich feststellen, dass anscheinend keine Daten von der FritzBox an den neuen Switch angezeigt werden. Es leuchtet keine Übertragungslampe. Weder die linke noch die rechte LED. Zum Testen habe ich auch mal den GS305E Switch angeschlossen. Leider mit dem gleichen erfolglosen Ergebnis. An dieser Stelle möchte ich nochmal betonen, dass eine Datenübertragung mit dem FS108v2 Switch funktioniert. Vielleicht kann mir jemand sagen woran das liegt, dass der neue Switch keine Daten empfängt bzw. verarbeitet. Mit freundlichen Grüßen DetlevSolved1.4KViews0likes5CommentsSwitch GS308 unmanaged 1x Port bricht Verbindung ab, LED leuchtet weiter
Hello, maybe someone can help me: I am trying to connect a device via the switch that requires constant Internet access. The device was previously always connected directly to the router (Fritzbox) - ran without any problems for about 3 years! Now the device is connected to any port and I am trying to bring the Internet permanently to the device via the switch. The connection is established normally, the LED on the switch and the LED on the device show "OK", the connection is established. After about two days, the LED on the switch continues to show "OK", but the device shows "Connection lost", the connection no longer exists. Even if I try to use this port with a notebook, the port appears to be dead. Only after restarting the switch can the port be used normally again. Translated with DeepL.com (free version) Hallo, vielleicht kann mir jemand helfen: Ich versuche über den Switch ein Gerät anzuschließen, welches ständiges Internet benötigt. Das Gerät war vorher immer direkt am Router (Fritzbox)- lief problemlos circa 3 Jahre! Nun hängt das Gerät an einem beliebigen Port und ich versuche über das Switch das Internet dauerhaft zum Gerät zu bringen. Die Verbindung baut sich ganz normal auf, die LED am Switch und die LED am Gerät zeigen "OK" an, die Verbindung steht. Nach etwa zwei Tagen zeigt die LED am Switch weiterhin "OK" an, das Gerät allerdings "Verbindungsabriss", die Verbindung besteht nicht mehr. Auch wenn ich mit einem Notebook versuche über diesen Port zu gehen, der Port scheint tot. Erst nach Neustart des Switch lässt sich der Port nochmals ganz normal nutzen. Wenn ihr Hilfreiche Tipps habt, oder Alternativbeiträge- ich danke euch im Voraus!Solved2.2KViews0likes3CommentsGS116E ProfSafe Plus Switch | eine LED leuchtet grün am 2. Port
hallo netgear, das Thema war bereits vorhanden,, aber geschlossen. Die 10MBit LED am Port zwei leuchtet dauerhaft, keine Verbindung zu den weiteren Ports, keine Verbindung zu den angeschlossenen Geräten. Bitte Hilfe Gruß ChristophSolved1.8KViews0likes4CommentsIch habe ein RMA Nummer erhalten, aber wie geht es jetzt weiter
Guten Tag, ich will nicht ungeduldig erscheinen aber wie geht es weiter wenn man eine RMA Nummer erhalten hat? Ich wollte per email nachfragen aber mein Ticket wurde schon geschlossen obwohl ich noch keinen Ersatz erhalten habe, und der RMA nicht abgeschlossen ist.Solved1.5KViews0likes2CommentsSwitch GS108Ev3 kein Zugriff mehr auf Konfiguration nach Firmware Update
Hallo, habe drei GS108Ev3 Switches, bei denen ich ein Firmware-Update durchführen wollte. Bei zwei Switches klappte es problemlos, nur der dritte GS108Ev3 Switch führte zwar das Firmware-Update durch, aber seither komme ich weder über das ProSafe-Plus-Konfigurationsprogramm noch über den Fritz-Router auf die Konfigurationseinstellungen dieses einen Switches. ProSafe-Plus meldet mir, dass ich nochmals das Firmware-Update durchführen soll. Gebe ich den Pfad zur Datei an, erhalte ich die Fehlermeldung: "Der Switch und die Manager-IP-Adresse befinden sich nicht im selben Subnetz." IP-Einstellungen aktualisieren, um die Subnetz-Einstellungen zu aktualisieren, klappt nicht - Fehlermeldung Auch ein Hardware Reset ist nicht möglich - schon zig Varianten mit dem Taster probiert. Das Netzwerk über den Switch läuft allerdings, nur konfigurieren und reseten kann ich ihn nicht mehr. Hat jemand eine Idee, was zu tun ist?Solved2.3KViews0likes3CommentsGS324P - Firmwareupdate & Web UI
Hallo Community, vielleicht kann mir jemand etwas behilflich sein. Seit neuestem habe ich einen GS324P unmanaged switch. Frage1: Gibt es bei diesem Gerät ein Web UI? Falls ja: wie kann es aufrufen (192.168.0.239 funktioniert nicht) Frage2: Wie kann der Firmware upgedated werden? Frage3: Kann man etwas gegen den lauten Fan-Geräusche unternehmen? Danke & beste Grüße! TomSolved667Views0likes2CommentsXS508M-100EUS an FritzBox 6591 Cable (kann auf Switch nicht zugreifen, da ich ihn nicht finde)
Hallo liebe Community, ich habe folgende Situation FritzBox 6591 Cable (Port1) daran habe ich über RJ45 den Switch XS508-100EUS (Port7) angeschlossen. Der Switch "routet" auch und scheint zu funktionieren. Ich habe aber keine Möglichkeit, den Switch im Netzwerk zu finden. Weder finde ich die Switch über die FritzBox in Netzwerk noch finde ich den Switch mit dem Programm von Netgear Switch Discovery Tool. Auch wenn ich den Switch direkt mit meinem iMac über RJ 45 verbinde und das Tool von Netgear starte, findet er den Switch nicht. Hat jemand irgendeine Lösung, was ich falsch mache? Vielen Dank im Voraus für Eure Hilfe. HolgerSolved1.2KViews0likes2CommentsGS108 stellt keine dauerhafte Verbindung zum Router her
Guten Tag, ich habe den Netgear GS108 mit meiner Fritzbox 7490 verbunden und an dem Switch sind die Netzwerkendgeräte angeschlossen. So zum Beispiel ein Amazon FireTV. Nun bekommen die Geräte, welche an den Switch angeschlossen sind, keine Verbindung zu Netzwerkgeräten, die direkt an die Fritzbox angeschlossen sind, und auch nicht zum Internet. Wenn ich den FireTV direkt mit der Fritzbox verbinde, funktioniert alles normal. Einen anderen Port der Fritzbox habe ich schon mal ausprobiert, dass ändert jedoch nichts. Interessanterweise wird aber offenbar nach dem Einschalten des Switches kurzzeitig eine Verbindung etabliert und ich kann den FireTV anpingen. Versuche ich dies nach einigen Minuten erneut, so kommt keine Verbindung mehr zustande. Was kann da die Ursache sein?Solved1.3KViews0likes1Comment
