gr8sho
Dec 13, 2019Virtuoso
Firmware v2.5.1
New version available. Based on the description, doesn’t seem worth the disruption.
New Version: V2.5.1.8
Release Notes:
[Bug Fix] Fixes JP/AU/CA region can't firmware update issue. [Bug Fix] Fixes Armor activation failed due to device offline issue.
Release Notes:
- MikeG63Apprentice
I shall wait until it's officially posted on the Supprt pages and then take a view.
No meantion of device naming problem. Hmmm. :smileyfrustrated:
Release Notes:
[Bug Fix] Fixes JP/AU/CA region can't firmware update issue. [Bug Fix] Fixes Armor activation failed due to device offline issue. - rhino-1Tutor
The first issue I'm experiencing with firmware 2.5.1.8 is the inability to turn on remote management from the app. I can enable it from the web interface but the app does not allow me to enable it so I can access my Orbi remotely from the app. I did a full restore back to factory settings before applying the update.
I receive the following error:
"Some error occured while enabling/disabling remote management"
My community forum page has an orange banner across about "an issue with Remote Management fucntionality." (That won't go away when I click on the 'x', but that's another issue.) They say it's fixed, unless it's not fixed.
 - tomschmidtVirtuoso
For those that have installed v2.5.1.8 firmware, have you checked to see if the https certificate is updated to be properly signed by a certificate authority? Does opening https://orbilogin.net/ open as a secure web site in your web browser? Can you check the certificate for when it will expire again?
- gr8shoVirtuoso
tomschmidt wrote:For those that have installed v2.5.1.8 firmware, have you checked to see if the https certificate is updated to be properly signed by a certificate authority? Does opening https://orbilogin.net/ open as a secure web site in your web browser? Can you check the certificate for when it will expire again?
Chrome complained, so it still appears broken to me.
I would post about this in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Ensure the Orbi app is up to date as well.
rhino-1 wrote:The first issue I'm experiencing with firmware 2.5.1.8 is the inability to turn on remote management from the app. I can enable it from the web interface but the app does not allow me to enable it so I can access my Orbi remotely from the app. I did a full restore back to factory settings before applying the update.
- DWHITE4245Aspirant
2.5.1.8 no longer seems to be available from the Downloads area. I get 'File not found'.
Any one interested or users with Orbi that have units outside of there warranty period, can give Voxels FW for Orbi 50 series systems only, a try:
This is based off the new v2.5.1.8 stock NG FW.
Enjoy. :smileywink:
- SW_Prodigy
Interesting observation from Voxel:
Voxel wrote:
2.5.1.8 was released after I prepared my version... I do process this version (GPL sources) since yesterday (2.5.1.8) and I've seen the changes in device name processing (net-scan package is disabled and attached-devices package is used now)...- FURRYe38Guru - Experienced User
Wonder what the differences is.
SW_ wrote:Interesting observation from Voxel:
At somepoint NG may put up FW version up on there update servers that users can press the check for update button to see if something is there and the Orbi may find something. It's up to NG to post FW updates on there servers, or not.
When it's not detected then it's up to users to manually update FW if they choose too. NG seems to be more flexible in this regard. It was just a couple of years ago that NG was pushing each and every FW update which for some users, broke the Orbi operation, thus making users angry. So with all the feedback, NG has relented now and give users more control over FW updates. So lets not look a gift horse in the mouth. Users can update manually, or not. Theres an old saying, "If its not broke, don't fix it!!!"
 - Before I updated to V2.5.1.8 I could see all of my 84 attached wi-fi devices. Since the update, I never see more than 4 attached devices. I have rebooted the router and the three satellites 3 times. Nothing changes! HELP! What happened?
Clear all browser caches, exit the browser then relauch and open the page.
Does a different browser exhibit the same thing?
Try a factory reset on the RBR and setup from scratch.
isareeves wrote:
Before I updated to V2.5.1.8 I could see all of my 84 attached wi-fi devices. Since the update, I never see more than 4 attached devices. I have rebooted the router and the three satellites 3 times. Nothing changes! HELP! What happened?- Thank you... I tried all of your suggestions. Still no luck. ☹️
isareeves, are you using the iOS app, Android app, or web interface to see the attached devices? There have been some users reporting that the iOS app has issues properly displaying the devices under the v2.5.1.8 firmware, but the web interface and Android app show them properly. If you are using the iOS app, then check your device list using the web interface. If that is your issue as well, there is a thread on the iOS issue under the Application forum. See https://community.netgear.com/t5/Orbi-App/Orbi-iOS-App-not-working-after-router-upgrade-to-2-5-1-8/m-p/1853404
isareeves wrote:
Before I updated to V2.5.1.8 I could see all of my 84 attached wi-fi devices. Since the update, I never see more than 4 attached devices. I have rebooted the router and the three satellites 3 times. Nothing changes! HELP! What happened?- Thank you... I use my Orbi with IOS 13.3.1... my devices still do not show up correctly after clearing my cache, reinstalling the app (which I found out was a huge mistake), nor on Chrome or Safari (after clearing the cache). I was about to wipe everything out and start clean until I read that it most likely not make a difference, since I would be restarting on the same version of the firmware. I am too frustrated to try anything else. I guess I will wait for a new firmware update.
 - bolingdeGuide
Ever since upgrading (automatically) to v2.5.1.8 everything on the network has been dropping connection. I mean everything because it's roku's, PC's (windows), phones (android), xbox connected to the satellite. It' fairly often (maybe every 15 minutes) and lasts for maybe 5-15 seconds. Never had any problems before.
I was going to roll back to v2.3.5.30 but when I go to the manual update page it only gives me the option to "check" one satellite so it worries me to try and roll back.
Two questions.
1. Is anyone else having problems with v2.5.1.8
2. Why would only one satellite be showing up on the manual upgrade page.
- gr8shoVirtuoso2.5 has been out for months.
For expediency, consider a factory reset. - FURRYe38Guru - Experienced User
No issues since v2.5.1.8 loaded on my RBK50. No DNS timeouts, blocked web sites, wifi or internet drops. Device naming is fixed on this version. Though on RBS in a web browser, it shows "unknown" for device names. Most stable version to date.
Factory reset is recommended then setup from scratch. I reset mine after each update and save a new backup configuration to file for safe keeping.
bolingde wrote:Ever since upgrading (automatically) to v2.5.1.8 everything on the network has been dropping connection. I mean everything because it's roku's, PC's (windows), phones (android), xbox connected to the satellite. It' fairly often (maybe every 15 minutes) and lasts for maybe 5-15 seconds. Never had any problems before.
Two questions.
- bolingdeGuideThanks for suggesting factory reset,, but I'll think I'll hold off that mess for awhile.
None of the other really matter because it was all working before v2.5.1.8
