bsholbrook
Dec 16, 2016Apprentice
iOS devices
Running the Orbi formware 1.40.0.18 I've now experienced a couple of cases where an iOS device will infrequently get dropped off the network going from full signal to no wifi for upwards of 30 seconds. Mu-Mimo and beam form have both been turned off when this occurred.
- Just bought Orbi last week. I also have the "drop" problem on my iPhone and iPad. Find the link here. Did anyone find any solutions? Really appreciate it.
FYI. My iPhone was disconnected three times in the last 2 hours. Sometimes, a "please select a wifi network" window popped up. Sometimes, it just "quietly" became LTE with no wifi. Either way, I can always reconnect by going to setup and choose my wifi (it's always there with full strength signal)... very strange and frustrating. Please help.- bugmastaGuide
i have not seen a fix yet and i still have the same problem at my house.
- DarrenMSr. NETGEAR Moderator
NETGEAR is aware of an issue affecting some users where wireless client devices frequently disconnect/reconnect from the Orbi WiFi network. We’re actively working on the issue and hope to have a solution soon.
I have seen a small fix from some users saying that they lowered the power level of the wireless on the 2.4 ghz band.
DarrenM
Could you please share how to lower the power level of the wireless on the 2.4 ghz band? Like to try.
- bsholbrookApprenticeCurrently Working with engineering, hopefully debug data will help them work issue.
- kenquickGuide
Great to know. I have been doing the same thing since Jan and am about at the end of my rope. At least It is not just my network. I will try to update you also.
- RomainSInitiate
airplay with denon AV receiver (4520) got dropout every 2 seconds !!!!!!!!! with my ipad, my iphone 7 and my iphone 5 same issue
before i had an apple ariport router working perfectly
i am very very very disappointed
Please, netgear could you give us the date when you will release the hotfix !!!!!
thanks in advance
- bsholbrookApprenticeNot able to get into router at the moment, from memory I believe the setting is cts or rats or similar and you want to set the value down from 2347 to 2346. Hopefully this is close enough instructions to get you where you need to be to make the change
Still follow the threads after returning the orbi because of ios issues with the orbi.
I hope Netgear is coming with a fix but the wait is already a long time now. May'be have to switch to an alternative
- kenquickGuideI just bought the Linksys Velop which is working good. After 3 months of working with tech support and no results I cannot wait any longer. Too bad the orbi features were better
- Sevo123ApprenticeJust got the orbi rbk53 2 days ago and set up everything updated to most current firmware but wow signal keep dropping constantly! Netgear has to fix this ASAP and add ability go actually have these satellites be mesh and communicate with eachother. If not im going to velop linksys! - on side note netgear rep told me mesh capability is in works with firmware upgrade. But this wifi dropping is a disaster. And yes this is using a 7 plus. Smh fix this netgear
I posted a reply to this in another similar iOS thread. Here's the link. Hopefully it works for you too.
- kenquickGuideDon't wait. I have been working on my case for a 3 months and no fix in sight. Collect more debuts etc over and over. Finally bought Velop and everything was good in 8 min. I would have like the features if orbi, along with extra Lan ports. But a $20 switch fixed that. Could not take wife and kids complaining. Really sucked for buying the most expensive option. Netgear needs to stop beta testing us.
