Jeff837's avatar
Jeff837
Initiate
Jan 07, 2018
Nearby device will not connect to satellite
I have the main router on Floor 1, and the satellite on Floor 2, which is 5 feet from the front door.  I have installed a Ring Doorbell on the front door.  However, it only connects directly to the router a floor away, rather than to the satellite a few feet away (as shown in the Attached Devices screen).  Yet the doorbell often reports poor network connectivity.
Why is it doing this?
How can I force the Ring Doorbell to connect to the nearby satellite?
  • The Attached Devices screen is wrong on the latest firmware release--it shows almost everything connected to the router, regardless of the real connection.  So, your dorobell might actually be connected to the satellite. You need the new v2.1.2 beta to correct the attached devices bug.
    https://community.netgear.com/t5/Orbi/OrbiOS-2-1-1/td-p/1476960
    Power-cycle the doorbell after you reboot Orbi and the doorbell should connect to the nearest AP.
    • webminster's avatar
      webminster
      Luminary
      Curious about your settings for beamforming and MU-MIMO... thought I'd heard rumors that one or the other of those could cause issues with Ring.   I have them turned off, and my Ring connects at 5G to my satellite on same floor, about 25 ft. away.
      • aaz's avatar
        aaz
        Virtuoso
        I have both beamforming and MUMIMO on and my two ring doorbells connect just fine.
  • Anonymous's avatar
    Anonymous
    I have the same problem with my Skybell doorbell, if I update the firmware or restart the router, the doorbell will always reconnect on the router, I need to do an soft reset on doorbell for force the device to connect on the satellite, a method for to force specific device to connected on the router or satellite is missing and should be a good thing
    • FURRYe38's avatar
      maybe the Doorbell maybe choosing the "better" signal and thinks the router signal is better than the Satellite.
      What version of FW are you using?
      • Glennr's avatar
        Glennr
        The problem is two fold.  One, Orbi is NOT a mesh nework and two, Netgear has not figured out how to show the correct connections.  There was a firmware that was supposed to fix it but it was "recalled".  The latest 2.1.3.4 still has the connection display problem.  One way to test this is to connect something by cable to a port on the satelite.  If that shows as connected to the main Oribi you will have the answer.
    • st_shaw's avatar
      st_shaw
      Master
      This happens because the Orbi router always comes up before the satellites upon a reboot or power cycle of the Orbi system. Devices that do not roam, such as OSX laptops or desktops and many IP cameras, will connect to the first device they see and never switch. There is no way to force devices to connect to a given Orbi unit, so to connect to the nearest Orbi, you may need to power cycle your non-roaming devices after every time Orbi reboots.
      • Glennr's avatar
        Glennr
        Some non-roaming devices like doorbells are not easily power cycled.  I wonder if power cycling just the router might do it?
    • Sal364's avatar
      Sal364
      Initiate
      I’m 30 feet from the router and 5 ft from the satellite and FaceTime and other programs say poor connection. All firmware is up to date. This is happening with android iPad and iphonex
      • Glennr's avatar
        Glennr
        Find a free phone app for signal strength for one of your devices.  It might help you find the issue.
  • FURRYe38's avatar
    Did you reset both router and satellite after updating then setup from scratch?
      Anonymous
      Any reason to setup at scratch after an firmware upgrade?
  • I seem to have this same issue with ring products connecting to router and not satellite.  My Router is on floor 1 and my satellite is on the ground floor about 20 feet away from the Ring Chime Pro, yet my chime pro is connecting to the Router when I would have expected it to connect to the satellite.
    The RSSI on the Ring Chime Pro is also no better than it was before I setup the Orbi, showing in the region of -60.  I have a Spotlight cam and doorbell connected to the chime pro.
    I am running the latest firmware version V2.1.4.10.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello wilbo83
    Do you have fast roaming enabled on orbi if not could be the reason why the devices are sticking to the main routers connection.
    DarrenM
    • wilbo83's avatar
      wilbo83
      I didn't have it turned on but logged in and turned it on, left it for a few hours like that and checked the connection between the Ring Chime Pro quite a few times and it remained connected to the Router.  Perhaps that has the strongest signal, just seems strange when the satellite is on the same floor in the next room as opposed to the router being 1 floor away diagonally.
      • cheshbr's avatar
        cheshbr
        Apprentice
        It is usually necessary to power-cycle the device connected to the wrong Orbi.  Try disconnecting, then reconnecting, the power to the Ring device, then refresh the Connected Devices list to see if it roamed to the correct Orbi.  Portable devices like phones, iPads, laptops, watches etc will roam from one Orbi to another as you take them around your house.
        This can be confirmed by referring to the BSSID MAC address of the connected Orbi when using an app like Network Analyser. (A MAC address is the Machine Access Code of a network device. It is a 12 digit code showing pairs of numbers separated by colons). Don’t worry about the 12 digit code itself, just note when it changes because that’s the point at which your portable device roams from one Orbi to the other.
        By contrast, a fixed device, like a printer, smart light bulbs, a smart TV, and your Ring don’t roam around your house, so the Orbi they lock onto is sticky and won’t release the attached device unless you force it to “roam” by switching it off and on again.
        The Netgear Genie’s Network Map is your friend here too.  Touch the icon for each connected device on the map and look at signal strength. A good connection shows 100% unless it is a long way to your nearest Orbi.
        So power your Ring device off and on again, ,view the outcome on the attached devices list on the Orbi web interface, and check it on the Genie’s  Netwok Map
        Good luck
  • I just installed my Orbi RBK50 and had the same issue with my Ring Pro connecting to the router.
    All I had to do was power cycle the Orbi Router.
    The Ring Pro is now on my satellite and my RSSI signal has improved.
    • FURRYe38's avatar
      What are you expecting?
      A little more information will be needed here.
      Chris1984 wrote:
      I am expecting the same issue!
      • Chris1984's avatar
        Chris1984
        Tutor
        Basically i have a nest door bell next to my orbi satellite (it is only 2 meters away) and the nest camera is connecting to my main orbi router that is situated over 10m away and is onanother floor. Moreover the connection is poor it is 30%.
        Thanks
        Chris
