carlos45's avatar
carlos45
Netflix / Amazon Prime not connecting
We have recently reconfigured our router / modem set up with orbi system acting as a router and the nighthawk set to modem only. This has worked perfectly for the last few weeks
We however just realised that our Sony smart tv’s will not connect to Netflix or Amazon prime. The tv will also not connect to either of their websites either. All other internet sites and apps are working...eg YouTube on both tv’s
Also we have no problems connecting to Amazon / Netflix on other apple devices (tablet / MacBook )
Finally, we did struggle accessing PlayStation Onlinr Services which was eventually solved by changing the MTU figure In the custom set-up (Reddit gave us the solution)
Any thoughts would be appreciated
Carl
  • What FW is currently loaded?
    Is Armor or Circle  or IPv6 enabled on the RBR? Try disabling these 3 and see if this changes anything.
    Has a factory reset and setup from scratch been performed since last update?
    If your on a DSL ISP service, try setting the MTU value to 1472 or 1492 for DSL ISP services.
  • FURRYe38's avatar
    • carlos45's avatar
      carlos45
      Thanks for the reply.
      If by FW you mean firmware then everything is up to date
      Circle has not been enabled on the Orbi.
      We have factory reset the tv and performed the usual soft and hard reboots.
      Yes I believe we are on a DSL ISP service. Re the MTU ..is this something I can change on the Orbi / Modem or is it configured on the tv.
      I needed to change the MTU to access PlayStation online services however this was done thru the PlayStation as opposed router / modem.
    • carlos45's avatar
      carlos45
      Problem was solved by changing MTU setting to 1472. It was previously 1492.
      Hopefully all other internet functionality is fine.
      Thank you for your help
      • FURRYe38's avatar
        Glad you got it working. Enjoy. :smileywink:
  • CrimpOn's avatar
    CrimpOn
    How are the TV sets configured with regard to the network?
    i.e. Are they set up to use DHCP to get their network information?
    (IP address, subnet mask, gateway, DNS)
    Have the TV sets been powered off and back on after the network reconfiguration?
    • carlos45's avatar
      carlos45
      Yes DHCP is used.
      All other internet access for the tv is fine. You tube etc
    Try going into your TV settings, do a soft boot or soft reset. There should be instruction in your manual. Then remove and reconnect the WIFI network.
